Highlighted
outdoor AP surge protection
We are about to install some outdoor APs in our enviroment and the question of surge protection has come up. the plan is to use POE injectors with some type of surge protection to protect the backend switch. The POE powerdsign for outdoor use with built in surge protection is a little pricey and we are hoping to gain ideas from the Airhead community.
thank you
Highlighted
Contributor II
Re: outdoor AP surge protection
I have been using Cambium Network, they have a very decent pricing and they are quiet good.
https://cdn.cambiumnetworks.com/wp-content/uploads/2018/07/SS_GigabitEthernetSurgeSuppressor_03272018.pdf
Highlighted
MVP Expert
Microsemi also makes gig rated inline surge suppressors as well
https://www.amazon.com/Microsemi-PD-OUT-SP11-Standard-Protector/dp/B00S5B2I4M
Jerrod Howard
Distinguished Technologist, TME
