terminate more APs on a OS8 Cluster
  • 1.  terminate more APs on a OS8 Cluster
    Posted Mar 18, 2020 04:39 AM
    we have OS8 with Mobilty Master and 2 7030 controllers in a cluster.
    The 7030 controllers can only handle 64 APs, is it possible to terminate more than 64 APs in a cluster with 2 controllers?
    I know that features like the cluster upgrade will be dropped, but theoretically the controllers can hold 2x64APs...
    Thanks a lot
  • 2.  RE: terminate more APs on a OS8 Cluster
    Posted Mar 18, 2020 05:27 AM
    Yes.
  • 3.  RE: terminate more APs on a OS8 Cluster
    Posted Mar 18, 2020 05:29 AM
    is there any config to change, when I want to terminate more than 64 APs?
  • 4.  RE: terminate more APs on a OS8 Cluster
    Posted Mar 18, 2020 05:46 AM
    No, but APs over 64 will not have standby redundancy.
