Highlighted
upgrade 7205 controller from 6.5.4.2 to latest (8.2.1) firmware
Is there document describing the procedure?
I thought i just upload an image of the firmware under maintenance/Image Mamagement.
But i see heavy download of an OVA that should contain a migration tool ??.
Kind Regards
Gerard
Accepted Solutions
Highlighted
Moderator
Re: upgrade 7205 controller from 6.5.4.2 to latest (8.2.1) firmware
You should be able to upgrade an individual controller unless you have it setup in an MD cluster.  It might be worth it to try opening a TAC case since they've run through this before.  I haven't tried any MM/MD setups in my testing yet.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
View solution in original post
All Replies
Highlighted
Moderator
OVA is for the initial install.
When the choices are listed as:
ArubaOS_VMC_8.2.1.0_64044
ArubaOS_VMC_8.2.1.0_64044.iso
ArubaOS_VMC_8.2.1.0_64044.ova
You'd need the image w/o the extension for a fw upgrade (so in the example above, the non-ova/non-iso image.
Rob Gin
Highlighted
MVP Guru
Hey, take a look at the below in the first instance. Upgrading to AOS8 will wipe the configuration, so you will need to ensure you have the relevant backups.
https://community.arubanetworks.com/t5/Technology-Blog/Migrating-to-ArubaOS-8-What-to-Expect-and-How-to-Get-Started/ba-p/412058
You will need the below if you wish to upgrade the 72xx series:
ArubaOS_72xx_8.2.1.0_64044
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
Highlighted
hmm don't know if understand, i should be able to upgrade ONYL my 7205 controller don't i?
I don't want to step up to the MM controller
HOW can just upgrade my 7205 controllers?
Kind Regards
Gerard
Highlighted
Can't seem to figger out where i can download the firmware?
Rgrds
Gerard
p.s. Is there realy now way to step-by-step upgrade and save the config ?
Highlighted
Moderator
Rob Gin
Highlighted
Kind Regards
Gerard
Gerard, the link to download the 8.2.1 software image for your 7205 is below:
https://support.arubanetworks.com/DownloadSoftware/tabid/75/DMXModule/510/Command/Core_Download/Default.aspx?EntryId=29395
You need to sign into the support site with valid credentials in order to download the software.I agree with Rob, if you haven't worked with 8.x previously, you'll want to have a TAC case open before upgrading an operating network from 6.5 to 8.x.
Charlie Clemmer
Aruba Customer Engineering
Highlighted
Hola a todos tengo varias consultas por favor si me podrian ayudar:
1.- Tengo un 02 equipos aruba 7205, que trabaja uno como master y otro como Slave, con 25 aps, se puede actualizar sin perder la configuración?
2.- Que versión firmware es la mas estable?
3.- Si se pudiera actualizar sin perder la configuración que imagen me descargo ya que hay varios.
4.- Existe algún video o instructivo donde te expliquen como actualizar?
Ya de antemano por su apoyo.
Highlighted
This should be a new thread rather than adding to an old thread. There is much more information that needs to be collected in order to provide proper advise.
Charlie Clemmer
