Contributor I
visualcfg and ap arm
Hello
I am running VisualCfg 0.9.14 and I was trying to process the ARM State from a file.   I have a "show ap arm state" from an AOS 6.5.4.8 but the VisualCfg tool doesn't like it at all.
Anyone know whether this should work?
regards
Arne
tbn
Re: visualcfg and ap arm
It should work. At least it works on my lab AOS 6.5.4.9. If you can share the original text file you are trying to import, I will be happy to look at it. Please unicast to the email provided in the menu Help->About.
-Thomas
