controller is aruba 6000US. 6.4.4.8. They can connect, but can't even ping gateway. i asked them to release and renew, they got message cannot not perform while disconnected. had them configure static and they still cannot ping gateway. but they are connected.
Is there an Access control entry that denies ICMP in the user role of the user?
This can be checked using " show rights <role the user is in> "
--Give Kudos: found something helpful, important, or cool? Click Kudos Star in a post.--Problem Solved? Click "Accepted Solution" in a post.
It ended up being some kind of bug. When we moved the connection to another interface, things started working again.
