Mobility Master is usually Access. Its a management platform mostly
APs only need trunk if you want to drop off client traffic on the AP uplink port. Otherwise, all access ports to allow the AP to tunnel to the controller
The controller is 100% where you will want to deploy trunks for the connectivity. Spinning up new VLANs/Subnets will require this.
Dustin Burns
ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022
Original Message:
Sent: Dec 06, 2022 02:08 PM
Subject: About Trunk or Access port for Controller, MM, and AP
hi all,
i have tried to find any explanation about when to use trunk or access port on Controller, MM and AP, but until now i got nothing. so if i have 2 controller, 1 MM, and some of AP, and i want to have multiple SSID with different VLAN on each SSID, what is the best setting for the port on all devices, is it trunk or access ?
