Remote Access
last person joined: 17 days ago
ACL example for Split Tunnel IPv6
  • 1.  ACL example for Split Tunnel IPv6
    Posted Aug 29, 2022 03:53 PM
    I'm trying to setup some RAPs and since we are a dual-stack (IPv4/IPv6) environment, I'm looking for example IPv6 ACLS to configure a split tunnel.
    Thanks!
    -Neil
  • 2.  RE: ACL example for Split Tunnel IPv6
    Posted Aug 30, 2022 04:18 AM
    This is a good start to see how split tunnel on RAP for IPv6 is supposed to work.
    Then from my lab testing, it looks like the WebUI does not allow you to create a route+srcnat rule, but on CLI you can:
    ip access-list session ipv6-splittunnel
       ipv6 any any svc-https route src-nat
    ... which then in the WebUI shows up as an non-editable acl entry. Looks like what you want to do is supported, but CLI only.
