Hi Guys,
I tried to make a working Airgroup solution in a lab environment. After it will success, I need to deploy it in production environment.
I read Aruba documents and made settings to made Airgroup to work between printer and user VLAN. So as I said users and printers use separate VLAN and SSID, traffic is not allowed between the two networks. Tests show that user devices found Airgroup printers, but printing job was not successful. Printer server services and client lookups shown on Aruba dashboard. Currently Airgroup is enabled on all VLANs and all user roles, initially I didn't set filter (disallowed VLANs/roles) in the configuration.
I tried to connect client to printer VLAN also (same SSID as printer use), in this case printing works fine.
Can anyone help me what can be the cause of this, what should I check or modify to make it to work? (AOS 8.6.0.18)
Thanks!
