Airmatch Deployment AOS10
  • 1.  Airmatch Deployment AOS10
    Posted 6 days ago
    Hi, we are looking to turn on Airmatch to start using this, however as it's done at Global level have concerns over how it will effect the AP's across all the groups. Ideally we only want to use it on the AOS10 Test AP group, is this possible?
  • 2.  RE: Airmatch Deployment AOS10
    Posted 4 days ago
    Airmatch only works with AOS10 APs and it is basically the next generation of Aruba radio management.
    check this this detailed info on Airmatch
  • 3.  RE: Airmatch Deployment AOS10
    Posted 3 days ago
    Excellent thanks, so it will only effect the AOS10 groups and aps and ignore the rest?
  • 4.  RE: Airmatch Deployment AOS10
    Posted 3 days ago
    yes thats correct
