Network Management
AirWave installation stuck in Nutanix
  • 1.  AirWave installation stuck in Nutanix
    MVP
    Posted Sep 19, 2023 03:34 AM
    I am trying to install AirWave 8.3 in a Nutanix environment and is stuck on "Setting recovery username". Please see attached screenshot. Have anyone faced this issue? How can I fix this?
  • 2.  RE: AirWave installation stuck in Nutanix
    Posted Sep 19, 2023 11:48 AM
    During installation in VM, you should not do CTRL-ALT options displayed to go to detailed package installation, stay where you are wait for it to prompt for amp recovery password, issue is once you switch to other screen, you can't comeback to original screen.
    Regards
    Gowri Amujuri
  • 3.  RE: AirWave installation stuck in Nutanix
    MVP
    Posted Sep 20, 2023 01:38 AM
    Hi Gowri,
    That did the trick. I was able to install it without any issues when I didn't press the CTRL-ALT-F9.
    Thanks you!
  • 4.  RE: AirWave installation stuck in Nutanix
    Posted Jun 17, 2024 07:03 PM
    For others who find this looking for help, CTRL-ALT-F1 returns from the messages view to the installation.
