Aruba Airwave
Alerts Interface flapping
  • 1.  Alerts Interface flapping
    Posted Nov 02, 2023 11:04 AM
    Hello fellow AirHeads!!
    I have an issue where I'm getting alerts for an interface flapping in quick secession. When looking at all the interfaces in the MM cli there are no interfaces flapping in the logs. Also, the show network cmd doesn't display any data.
    My question is, how can I use the only information the alert gives me, the ifindex, to find the actual interface that is trigging the alert? The current version is 8.2.13.0
    AP Status wlsxVlanInterfaceEntryChanged wlsxTrapVlanId.0: 1, wlsxTrapTime: 11/2/2023
    7:41:59 UTC-4, wlsxTrapTableEntryChangeType.0: modify(3),
    wlsxTrapTableGenNumber.0: 306459
    AP Status wlsxVlanLinkDown wlsxTrapVlanId.0: 1, wlsxTrapAdminStatus.0: enabled(1),
    wlsxTrapOperStatus.0: down(2), wlsxTrapTime: 11/2/2023 7:41:59 UTC-4
    Software linkDown ifIndex.16386: 16386, ifAdminStatus.16386: up(1),
    ifOperStatus.16386: down(2)
    Thanks for your help in advance
  • 2.  RE: Alerts Interface flapping
    Posted Nov 03, 2023 11:08 AM
    This looks like the VLAN interface is going up/down in operational state. If there are no interface (and no clients) in a specific VLAN, the VLAN will go 'operationally down'. What you can do is set the VLAN state to 'operstate up'. I think this can be only done from the CLI:
    (MM01) [] (config) #interface vlan 1
    (MM01) ^[] (config-submode)#operstate
    operstate               Interface Operation state
    (MM01) ^[] (config-submode)#operstate up
    That will keep the VLAN 'up' regardless if there are interfaces or clients in the VLAN.
  • 3.  RE: Alerts Interface flapping
    Posted Nov 13, 2023 12:22 PM
    Thank you Herman for the advise. Unfortunately, it did not resolve my issue. Is there a way I can use the ifindex to find the interface throwing the alert?
  • 4.  RE: Alerts Interface flapping
    Posted Nov 24, 2023 10:45 AM
    I would not know how. Best to work with Aruba TAC to find that out.
