AOS 10 MAC Filter for Wireless via ClearPass
  • 1.  AOS 10 MAC Filter for Wireless via ClearPass
    Posted 19 days ago
    Looking for someone to point me to a how-to or something similar. Im looking for information on how to create a mac filter for ssid's via ClearPass. Currently in AOS 8 you can make ssid's filter device connections via mac address on the VC local server. But going into AOS 10 that local server feature has been removed. So the next option is to use ClearPass. Im not familiar with ClearPass and was hoping to find direction on how to get a mac address repository setup to when users connect to a ssid ClearPass will grant the connection based on the mac address list.
    Mr. MKP
    Network Administrator
  • 2.  RE: AOS 10 MAC Filter for Wireless via ClearPass
    Posted 19 days ago
    You can do it in a number of ways.
    One simple way would be to add your MAC addresses as users to the local ClearPass. (the password for the users will also be the MAC addresses.
    Then create a MAC auth service to accept authentication requests and to check it against the local database.
  • 3.  RE: AOS 10 MAC Filter for Wireless via ClearPass
    Posted 18 days ago
    you can also use CloudAuth in Aruba Central for MAC auth for both wired and wireless.
