AOS 8.10.0.10 and AP-325
This thread has been viewed 19 times
  • 1.  AOS 8.10.0.10 and AP-325
    Posted 14 days ago
    I am planning to update a 7205 controller to 8.10.0.10 and I still have some AP-325s I looked though the release notes and could not find anything in regard to updating the AP 325 with the apflash command is that not required with this AOS release?
    Thanks in advanced
    MJF
  • 2.  RE: AOS 8.10.0.10 and AP-325
    Posted 14 days ago
    There shouldn't be a need to use the apflash command unless you are troubleshooting with TAC and they instruct you to do so. Upgrade as you normally would.
    If you're looking to upgrade to the latest 8.10 version, 8.10.0.11 was released a few days ago.
  • 3.  RE: AOS 8.10.0.10 and AP-325
    Posted 13 days ago
    Thanks!
  • 4.  RE: AOS 8.10.0.10 and AP-325
    Posted 13 days ago
    Just to confirm the AP-325 is supported on 8.10.0.11.  The release notes does not mention that.  Page 11.
  • 5.  RE: AOS 8.10.0.10 and AP-325
    Posted 13 days ago
    Yes, the AP-325 is supported in 8.10 including 8.10.0.11.
  • 6.  RE: AOS 8.10.0.10 and AP-325
    Posted 13 days ago
    Thank you.
  • 7.  RE: AOS 8.10.0.10 and AP-325
    Posted 13 days ago
    If you are referring to ARUBA-SA-20220922-PLVL02 :: Older AP-320 Series Access Points ArubaOS Upgrade and AP Firmware File Size Limitation (Rev-1), that procedure only has to be done once on the AP.
    Carson Hulcher, ACEX#110
