Wired Intelligent Edge
last person joined: 39 minutes ago
AOS-CX not starting on Eve-NG with Proxmox
This thread has been viewed 35 times
  • 1.  AOS-CX not starting on Eve-NG with Proxmox
    Posted Nov 27, 2023 04:56 PM
    I'm desperately trying to start a virtual lab for AOS-CX on EveNG.
    After all my debugging, I can't start the AOS-CX : the devices either doesn't start at all, or it starts but stays on a black screen when opening console.
    I have a Lubuntu VM with EveNG 5.0.1-13 installed on it. This VM is hosted on a Proxmox Server.
    The VM has 64Gb of RAM, CPU is set to 12Vcores with direct CPU access (host mode)
    I have followed the EveNG tutorial to export ova to qcow2 and then place it in /opt/unetlab/addons/qemu/[arubacxversion]
    The file is exactly named virtioa.qcow2
    I have tried those versions : arubacx10.05, .06, 07, .12, .13
    None of them seem to boot up properly, I have no relevant error log on every log file that eveNG has to offer.
    What can I do?
  • 2.  RE: AOS-CX not starting on Eve-NG with Proxmox
    Posted Nov 27, 2023 05:02 PM
    Hi Clement,
    EVE-NG running on Proxmox, as of today, it is not a supported platform for the CX Simulator. And unfortunately, I don't have a Proxmox server to test it myself.
    If anyone in the community can test it, please share your experience here.
    Regards.
  • 3.  RE: AOS-CX not starting on Eve-NG with Proxmox
    Posted Nov 27, 2023 05:37 PM
    Follow this guide, you should be ok. ;)
    https://egstory.net/wp-content/uploads/2021/05/Aruba-AOS-CX-Simulator-EVE-NG-Deployment-Guide.pdf
    Patrick
    Attachment(s)
  • 4.  RE: AOS-CX not starting on Eve-NG with Proxmox
    Posted Nov 28, 2023 02:29 AM
    Sorry but that's exactly the guide I followed as mentionned in my first message, and it didn't help me.
  • 5.  RE: AOS-CX not starting on Eve-NG with Proxmox
    Posted Apr 14, 2024 02:15 PM
    I have CX  10.13 running on EVENG on Proxmox.
    On Proxmox, VMs do not support nested virtualization  and you need to enable it.
    1 - First, your Promox server need to have nested virtualization enabled, you can confirm it with the command below (the response has to be Y):
    cat /sys/module/kvm_intel/parameters/nested
    Y
    2- The EVENG VM it self to support nested virtualization:
        - Shutdown the EVENG VM,
        - Go the CPU setting of the EVENG VM and make sure Type is set to host and not something else (just like the Screenshot below)
     - Start your EVENG VM, then you should be fine and start building your labs.
    Good Luck
    Achraf Harkati
