Cloud Managed Networks
AOS CX suppressing ZTP logs
This thread has been viewed 24 times
  • 1.  AOS CX suppressing ZTP logs
    Posted Feb 01, 2023 03:37 PM
    Any way to suppress these ZTP logs?  We are not using ZTP as these switches are all centrally managed.
    2023-02-01T12:43:23.684098-05:00 XXXXXXXXXXXXX dhcp_options[3779234]: Event|8723|LOG_INFO|AMM|1/1|ZTP: Aruba Central location option not provided
    2023-02-01T12:43:23.684034-05:00 XXXXXXXXXXXXX dhcp_options[3779234]: Event|8713|LOG_INFO|AMM|1/1|ZTP: Config file not provided
    2023-02-01T12:43:23.683963-05:00 XXXXXXXXXXXXX dhcp_options[3779234]: Event|8712|LOG_INFO|AMM|1/1|ZTP: Image file not provided
    2023-02-01T12:43:23.683827-05:00 XXXXXXXXXXXXX dhcp_options[3779234]: Event|8714|LOG_INFO|AMM|1/1|ZTP: TFTP server option not provided
    2023-02-01T12:32:03.236452-05:00 XXXXXXXXXXXXX dhcp_options[3777690]: Event|8723|LOG_INFO|AMM|1/1|ZTP: Aruba Central location option not provided
    2023-02-01T12:32:03.236390-05:00 XXXXXXXXXXXXX dhcp_options[3777690]: Event|8713|LOG_INFO|AMM|1/1|ZTP: Config file not provided
    2023-02-01T12:32:03.236325-05:00 XXXXXXXXXXXXX dhcp_options[3777690]: Event|8712|LOG_INFO|AMM|1/1|ZTP: Image file not provided
    2023-02-01T12:32:03.236198-05:00 XXXXXXXXXXXXX dhcp_options[3777690]: Event|8714|LOG_INFO|AMM|1/1|ZTP: TFTP server option not provided
    2023-02-01T12:18:25.716841-05:00 XXXXXXXXXXXXX dhcp_options[3775801]: Event|8723|LOG_INFO|AMM|1/1|ZTP: Aruba Central location option not provided
    2023-02-01T12:18:25.716776-05:00 XXXXXXXXXXXXX dhcp_options[3775801]: Event|8713|LOG_INFO|AMM|1/1|ZTP: Config file not provided
    2023-02-01T12:18:25.716712-05:00 XXXXXXXXXXXXX dhcp_options[3775801]: Event|8712|LOG_INFO|AMM|1/1|ZTP: Image file not provided
    2023-02-01T12:18:25.716576-05:00 XXXXXXXXXXXXX dhcp_options[3775801]: Event|8714|LOG_INFO|AMM|1/1|ZTP: TFTP server option not provided
    2023-02-01T12:06:09.830714-05:00 XXXXXXXXXXXXX dhcp_options[3774127]: Event|8723|LOG_INFO|AMM|1/1|ZTP: Aruba Central location option not provided
    2023-02-01T12:06:09.830650-05:00 XXXXXXXXXXXXX dhcp_options[3774127]: Event|8713|LOG_INFO|AMM|1/1|ZTP: Config file not provided
    2023-02-01T12:06:09.830577-05:00 XXXXXXXXXXXXX dhcp_options[3774127]: Event|8712|LOG_INFO|AMM|1/1|ZTP: Image file not provided
    2023-02-01T12:06:09.830444-05:00 XXXXXXXXXXXXX dhcp_options[3774127]: Event|8714|LOG_INFO|AMM|1/1|ZTP: TFTP server option not provided
    2023-02-01T11:51:27.763108-05:00 XXXXXXXXXXXXX dhcp_options[3772098]: Event|8723|LOG_INFO|AMM|1/1|ZTP: Aruba Central location option not provided
    2023-02-01T11:51:27.763046-05:00 XXXXXXXXXXXXX dhcp_options[3772098]: Event|8713|LOG_INFO|AMM|1/1|ZTP: Config file not provided
    2023-02-01T11:51:27.762983-05:00 XXXXXXXXXXXXX dhcp_options[3772098]: Event|8712|LOG_INFO|AMM|1/1|ZTP: Image file not provided
    2023-02-01T11:51:27.762853-05:00 XXXXXXXXXXXXX dhcp_options[3772098]: Event|8714|LOG_INFO|AMM|1/1|ZTP: TFTP server option not provided
  • 2.  RE: AOS CX suppressing ZTP logs
    Posted Feb 02, 2023 03:31 PM
    Not sure how I missed this...  https://www.arubanetworks.com/techdocs/AOS-CX/10.08/HTML/cli_6200/Content/Chp_RSyslog/RSyslog_cmds/logging%20filter.htm
    Create a log filter and apply the filter to syslog:
    logging filter remote_syslog_drop
         1 deny event-id 8712-8714,8723,8726
  • 3.  RE: AOS CX suppressing ZTP logs
    Posted Feb 06, 2023 05:27 AM
    If you don't use Aruba Central, you may just stop the central discovery and connection. Seems better to me than suppressing the logs. But be aware that once you want to use central, that the command needs to be reverted.
  • 4.  RE: AOS CX suppressing ZTP logs
    Posted 13 days ago
    Hello Herman,
    same Problem here with 6300 VSF. I have tried your suggested solution, but the log messages remain. (disabled 7:54, newest logs on top:)
    2024-04-17T08:05:24.947162+02:00 6300 dhcp_options[3443154]: Event|8723|LOG_INFO|UKWN|1|ZTP: Aruba Central location option not provided
    2024-04-17T08:05:24.947111+02:00 6300 dhcp_options[3443154]: Event|8713|LOG_INFO|UKWN|1|ZTP: Config file not provided
    2024-04-17T08:05:24.947060+02:00 6300 dhcp_options[3443154]: Event|8712|LOG_INFO|UKWN|1|ZTP: Image file not provided
    2024-04-17T08:05:24.946956+02:00 6300 dhcp_options[3443154]: Event|8714|LOG_INFO|UKWN|1|ZTP: TFTP server option not provided
    2024-04-17T07:54:44.644553+02:00 6300 hpe-restd[1020]: Event|4641|LOG_INFO|AMM|-|Aruba Central is disabled.
    Any other idea how to fix this?
    Greetings
    Stecker
  • 5.  RE: AOS CX suppressing ZTP logs
    Posted 13 days ago
    The first response to the original ask has instructions how to suppress the log messages. Did you try that?
  • 6.  RE: AOS CX suppressing ZTP logs
    Posted 12 days ago
    Yes, i implemented this as workaround
  • 7.  RE: AOS CX suppressing ZTP logs
    Posted 13 days ago
    Hello Herman,
    after one day still the same entries:
    2024-04-18T07:01:06.926963+02:00 6300 dhcp_options[960248]: Event|8723|LOG_INFO|UKWN|1|ZTP: Aruba Central location option not provided
    2024-04-18T07:01:06.926898+02:00 6300 dhcp_options[960248]: Event|8713|LOG_INFO|UKWN|1|ZTP: Config file not provided
    2024-04-18T07:01:06.926844+02:00 6300 dhcp_options[960248]: Event|8712|LOG_INFO|UKWN|1|ZTP: Image file not provided
    2024-04-18T07:01:06.926724+02:00 6300 dhcp_options[960248]: Event|8714|LOG_INFO|UKWN|1|ZTP: TFTP server option not provided
