ap-615 with 7205 controller wlan ssid 6 ghz not available
This thread has been viewed 28 times
  • 1.  ap-615 with 7205 controller wlan ssid 6 ghz not available
    Posted May 02, 2023 12:06 PM
    Hello everyone,
    I have a 7205 controller in fw 8.1101 with ap-615. wlan ap group and ssid are activated 6 ghz, but the led on the ap 615 isn´t turn on n and a registration with ax laptop logs in wlan ssid with  5 ghz deployment.
    someone had an idea? Thanks
  • 2.  RE: ap-615 with 7205 controller wlan ssid 6 ghz not available
    Posted May 02, 2023 12:13 PM
    A 6ghz SSID requires either WPA3 or OWE to broadcast.
  • 3.  RE: ap-615 with 7205 controller wlan ssid 6 ghz not available
    Posted Jun 05, 2023 04:46 AM
    You must set Flex Dual Band Mode: to include 6Ghz, unless you want AM to deside,
    but then you need at least 3 ap-615, within a client coverage.
    Steinar
  • 4.  RE: ap-615 with 7205 controller wlan ssid 6 ghz not available
    Posted Jun 05, 2023 10:01 AM
    there are some guidlines you have to follow by using 6GHz Band:
    • 6GHz only supports WPA3 (no transition or opmode mode!)
    • use the most recent DRT file
    • you have to have another SSID configured on 2.4 and/or 5GHz for the Reduced Neighboring Report
    • you have to set the country code
  • 5.  RE: ap-615 with 7205 controller wlan ssid 6 ghz not available
    MVP EXPERT
    Posted Jun 05, 2023 08:48 AM
    Have you got the output of 'show ap bss-table' ? This will confirm if the AP is broadcasting or not. Also, what is the country code of the AP and Controller?
  • 6.  RE: ap-615 with 7205 controller wlan ssid 6 ghz not available
    Posted Jun 28, 2023 07:44 AM
    Hi guys, Problem ist solved.
    I´ve forgot the regulatory domain
