AP 655 POE Power Setup
This thread has been viewed 24 times
  • 1.  AP 655 POE Power Setup
    Posted Sep 21, 2022 10:18 PM
    Is there a guide on how to setup the Aruba 655 to use both POE ports for power with a Class 4 POE Aruba switch (3810)? The Aruba 655 is connected to mobility controllers using AOS 8.
  • 2.  RE: AP 655 POE Power Setup
    Posted Sep 21, 2022 11:03 PM
    If you have LLDP enabled on the switch (default) then the power negotiation should occur correctly. You can configure LACP on the switch ports for redundancy. PoE draw should occur automatically.
    Aruba Instant: Multiple Ethernet Uplink
    ArubaOS: Configuring the AP Wired Port Profile
