AP mgmt-frame send request-beacon messages frequently
  • 1.  AP mgmt-frame send request-beacon messages frequently
    Posted 6 days ago
    ArubaOS : 8.10.0.8
    AP : 325,635
    Client : win10
    Client network : AX201,AX211
    network driver : 23.40.0.4 2024/3/10
    Question :
    The user is connected normally and is in the same location without moving. However, the ap will keep sending physical layer messages, causing the user to change ap. If this state continues, the user will be disconnected.
    show ap remote debug mgmt-frame ap-name 6FSW-006 client-mac f0:9e:4a:95:8e:e0
    Controller setting :
    wlan virtual-ap vap-iot(md)
    aaa-profile aaa-iot(md)
    ssid-profile ssid-iot(md)
    wmm-traffic-management-profile wmm(md)
    no mobile-ip
    vlan-mobility
    band-steering
    broadcast-filter all
    dot11k-profile dot11k(md)
    vlan 102
    deny-inter-user-traffic
    wlan dot11k-profile dot11k(md)
    dot11k-enable
    rrm-ie-profile rrm-ie(md)
    rf dot11a-radio-profile rf11a-default(md)
    arm-profile arm11a-default(md)
    max-tx-power 18
    min-tx-power 15
    rf dot11g-radio-profile rf11g-default(md)
    arm-profile arm11g-default(md)
    max-tx-power 9
    min-tx-power 6
    interference-immunity 3
    rf arm-profile arm11a-default(md)
    cm-report-interval 5
    cm-sticky-min-signal 65
    rf arm-profile arm11g-default(md)
    no 80MHz-support
  • 2.  RE: AP mgmt-frame send request-beacon messages frequently
    Posted 5 days ago
    As expected and indicated by the provided screenshots, the AP is sending beacon reports every 60 seconds to the 802.11k client. Is the client roaming every 60 seconds too?
  • 3.  RE: AP mgmt-frame send request-beacon messages frequently
    Posted 4 days ago
    How should I inquire? Because when I check the user's roaming history, sometimes it takes 1 minute to change, sometimes it takes more than 10 minutes to switch, and it even takes him longer to switch.
  • 4.  RE: AP mgmt-frame send request-beacon messages frequently
    Posted 4 days ago
    On AOS-8, show ap client trail-info <client-mac> is what you're looking for.
    https://www.arubanetworks.com/techdocs/CLI-Bank/Content/aos8/sh-ap-clnt-trial.htm
  • 5.  RE: AP mgmt-frame send request-beacon messages frequently
    Posted 4 days ago
    My laptop has never moved
    At the same time, I also confirmed the signals heard by the APs around the client through the commands in the photo above.
