AP mgmt-frame send request-beacon messages frequently
This thread has been viewed 23 times
  • 1.  AP mgmt-frame send request-beacon messages frequently
    Posted Jul 02, 2024 03:16 AM
    ArubaOS : 8.10.0.8
    AP : 325,635
    Client : win10
    Client network : AX201,AX211
    network driver : 23.40.0.4 2024/3/10
    Question :
    The user is connected normally and is in the same location without moving. However, the ap will keep sending physical layer messages, causing the user to change ap. If this state continues, the user will be disconnected.
    show ap remote debug mgmt-frame ap-name 6FSW-006 client-mac f0:9e:4a:95:8e:e0
    Controller setting :
    wlan virtual-ap vap-iot(md)
    aaa-profile aaa-iot(md)
    ssid-profile ssid-iot(md)
    wmm-traffic-management-profile wmm(md)
    no mobile-ip
    vlan-mobility
    band-steering
    broadcast-filter all
    dot11k-profile dot11k(md)
    vlan 102
    deny-inter-user-traffic
    wlan dot11k-profile dot11k(md)
    dot11k-enable
    rrm-ie-profile rrm-ie(md)
    rf dot11a-radio-profile rf11a-default(md)
    arm-profile arm11a-default(md)
    max-tx-power 18
    min-tx-power 15
    rf dot11g-radio-profile rf11g-default(md)
    arm-profile arm11g-default(md)
    max-tx-power 9
    min-tx-power 6
    interference-immunity 3
    rf arm-profile arm11a-default(md)
    cm-report-interval 5
    cm-sticky-min-signal 65
    rf arm-profile arm11g-default(md)
    no 80MHz-support
  • 2.  RE: AP mgmt-frame send request-beacon messages frequently
    Posted Jul 02, 2024 12:28 PM
    As expected and indicated by the provided screenshots, the AP is sending beacon reports every 60 seconds to the 802.11k client. Is the client roaming every 60 seconds too?
  • 3.  RE: AP mgmt-frame send request-beacon messages frequently
    Posted Jul 03, 2024 06:19 AM
    How should I inquire? Because when I check the user's roaming history, sometimes it takes 1 minute to change, sometimes it takes more than 10 minutes to switch, and it even takes him longer to switch.
  • 4.  RE: AP mgmt-frame send request-beacon messages frequently
    Posted Jul 03, 2024 04:03 PM
    On AOS-8, show ap client trail-info <client-mac> is what you're looking for.
    https://www.arubanetworks.com/techdocs/CLI-Bank/Content/aos8/sh-ap-clnt-trial.htm
  • 5.  RE: AP mgmt-frame send request-beacon messages frequently
    Posted Jul 03, 2024 09:49 PM
    My laptop has never moved
    At the same time, I also confirmed the signals heard by the APs around the client through the commands in the photo above.
  • 6.  RE: AP mgmt-frame send request-beacon messages frequently
    Posted Jul 08, 2024 02:26 PM
    At the same location, what is the client's perspective of the RSSI to #5 and #6? Does the behavior you're observing happen only at this particular location or also others?
  • 7.  RE: AP mgmt-frame send request-beacon messages frequently
    Posted Jul 18, 2024 07:41 AM
    additionally in knowing the client's view of the available APs, would be curious to know if RRM quiet-ie elements are truly disabled, and what happens if 802.11dh are enabled.
    If there is an MC (Mobility Conductor) involved, or on the standalone MD - this command is helpful to see client signal at  #5 and #6 APs.
    show ap virtual-beacon-report client-mac
      ( have seen cases where clients decide to roam based on very small RSSI differences, channel quality, or beacon loss), since the 2 APs in this case appear electrically/802.11 nearly identical - lose a few beacons or a small power fluctuation, and the client roams. )
    "show rrm dot11k beacon-report station-mac f0:9e:4a:95:8e:e0 " will show info if the STA/AP are truly exchanging data in those beacon reports.
    "show ap arm client-match history client-mac  f0:9e:4a:95:8e:e0 " will show if Client match is playing a role in the roams.
    Shawn Adams
