AP303 : connection not stable with old hardware
  • 1.  AP303 : connection not stable with old hardware
    Posted Jul 08, 2024 10:24 AM
    i changed some old Cisco controller AP with AP303 and now some hardware that were ok are disconnecting (they are connected using "telnet"). These are some Windows CE Motorola MT2090 using 802.11G.
    Are there some parameters i can optimize ?
    Thanks for you help
    Here is the config
    version 8.12.0.0-8.12.0
    virtual-controller-country FR
    virtual-controller-key blabla
    name Cluster
    virtual-controller-ip 192.168.x.y
    terminal-access
    ntp-server 194.2.0.28
    clock timezone Paris 01 00
    clock summer-time CEST recurring last sunday march 02:00 last sunday october 03:00
    rf-band all
    allow-new-aps
    allowed-ap mac
    allowed-ap mac
    allowed-ap mac
    allowed-ap mac
    allowed-ap mac
    allowed-ap mac
    arm
     wide-bands none
     min-tx-power 9
     max-tx-power 127
     band-steering-mode prefer-higher-band
     air-time-fairness-mode default-access
     channel-quality-aware-arm-disable
     client-aware
     free-channel-index 40
     scanning
     client-match
    rf dot11g-radio-profile
     max-distance 0
     max-tx-power 9
     min-tx-power 6
     disable-arm-wids-functions off
    rf dot11a-radio-profile
     max-distance 0
     max-tx-power 18
     min-tx-power 12
    mbssid-group-profile _MBSSID1_
    syslog-level warn ap-debug
    syslog-level warn network
    syslog-level warn security
    syslog-level warn system
    syslog-level warn user
    syslog-level warn user-debug
    syslog-level warn wireless
    extended-ssid
    web-server
     ssl-protocol tlsv1_2
    hash-mgmt-password
    hash-mgmt-user admin password hash blabla
    wlan access-rule default_wired_port_profile
     index 0
     rule any any match any any any permit
    wlan access-rule wired-SetMeUp
     index 2
     rule masterip 0.0.0.0 match tcp 80 80 permit
     rule masterip 0.0.0.0 match tcp 4343 4343 permit
     rule any any match udp 67 68 permit
     rule any any match udp 53 53 permit
    wlan access-rule SERI_data
     index 3
    wlan access-rule SERI_data-5G
     index 4
    inbound-firewall
     rule any any any any match 17 67 68 permit
     rule any any any any match 17 546 546 permit
     rule any any any any match 1 any any permit
     rule any any any any match 58 any any permit
     rule any any apip 0.0.0.0 match 6 22 22 permit
     rule any any any any match any any any permit
     rule any any any any match any any any deny
    wlan ssid-profile SERI_data
     enable
     index 1
     type employee
     essid SERI_data
     wpa-passphrase blabla
     opmode wpa-psk-tkip,wpa2-psk-aes
     max-authentication-failures 0
     rf-band 2.4
     captive-portal disable
     dtim-period 1
     broadcast-filter arp
     dmo-channel-utilization-threshold 90
     local-probe-req-thresh 0
     max-clients-threshold 64
     max-retries 3
     temporal-diversity
     high-throughput-disable
     very-high-throughput-disable
     high-efficiency-disable
    wlan ssid-profile SERI_data-5G
     enable
     index 2
     type employee
     essid SERI_data-5G
     opmode wpa2-psk-aes
     rf-band 5.0
     dtim-period 1
    auth-survivability cache-time-out 24
    wlan external-captive-portal
     server localhost
     port 80
     url "/"
     auth-text "Authenticated"
     auto-whitelist-disable
     https
    blacklist-time 3600
    auth-failure-blacklist-time 3600
    ids
     wireless-containment none
    wired-port-profile wired-SetMeUp
     switchport-mode access
     allowed-vlan all
     native-vlan guest
     no shutdown
     access-rule-name wired-SetMeUp
     speed auto
     duplex auto
     no poe
     type guest
     no dot1x
    wired-port-profile default_wired_port_profile
     switchport-mode trunk
     allowed-vlan all
     native-vlan 1
     shutdown
     access-rule-name default_wired_port_profile
     speed auto
     duplex full
     no poe
     type employee
     no dot1x
    enet0-port-profile default_wired_port_profile
    uplink
     preemption
     enforce none
     failover-internet-pkt-lost-cnt 10
     failover-internet-pkt-send-freq 30
     failover-vpn-timeout 180
    airgroup
     disable
    airgroupservice airplay
     disable
    airgroupservice airprint
     disable
  • 2.  RE: AP303 : connection not stable with old hardware
    Posted Jul 10, 2024 05:25 PM
    First have a look into the Cisco configuration, specifically SSID and RF settings. if you are not doing any RF survey.
    then you can fine-tune the tx-power and data rates.
    Harendra
    ACEX165
  • 3.  RE: AP303 : connection not stable with old hardware
    Posted Jul 12, 2024 02:40 AM
    Hi NHN,
    i forgot to say that this is not a distance issue or so. In fact even when close from access point, not moving, we loose the connection.
    We also have wireless printers (for stickers) that we have to always ping, if not they loose the connection.
    In fact another thing is odd : if i ping the MT2090 i have many loss, but if i ping them 6 times per second or more it is better.
    It is like the AP had to be always woken up
    Have a nice day
