APs flapping, heartbeat timeout
This thread has been viewed 211 times
  • 1.  APs flapping, heartbeat timeout
    MVP EXPERT
    Posted Apr 29, 2022 07:33 AM
    I have a test setup at home runnig Arubaos 8.10
    1 * MM VM
    1 * 7205 hardwar appliance
    2 * AP335s
    have a basic setup with  APs doing  eap-tls auth aganst cppm and that all works just fine.
    Problem is the APs are flapping with "AP is down since 2022-04-29 12:00:44 because of the following reason: Hbt Timeout."
    messages
    All devices are on the same vlan (1) nd same /24 net.
    All devices are pingable from other devices
    From the MM
    (nd7205) [MDC] *#show ap debug client-mgmt-counters
    Counters
    Name Value
    Tunnel DACL 10
    STM Restart Notification to Auth 1
    Action frames: wmm rrm wnm public dls ba vendor unknown 0 0 0 0 0 0 0 0
    Associations Dropped Due to Auth Throttling 0
    PubSub Messages Rcvd 936
    Auth .1x Queue: High, Pending 550, 0
    Reg timer calls 8957
    BSS publish Failures 0
    Tunnel Timeouts 516
    Any ideas where i start looking to resolve the hbt-timeout issue ?
    Rgds
    Alex
    Alex Sharaz
  • 2.  RE: APs flapping, heartbeat timeout
    Posted Apr 29, 2022 08:34 AM
    How are the access points being powered?
    Are they negotiating the correct speed/duplex on the switch?
  • 3.  RE: APs flapping, heartbeat timeout
    Posted May 01, 2022 04:25 AM
    I had a similar issue. It was due to a lack of AP licences. Probably worth to check that.
    Raymond Papaux
  • 4.  RE: APs flapping, heartbeat timeout
    Posted 20 days ago
    Is there a different method to download the image in the AP joining process to the Aruba OS8 controller than TFTP?
  • 5.  RE: APs flapping, heartbeat timeout
    Posted Jun 19, 2023 01:04 PM
    i have the same situation, Switchs are Cisco with LLDP active.
    2 MM Vmware / 2 7210 MC with cluster/ APs 515 / SO 8.10.0.6 / License ok
    MC shows this logs
    Jun 16 11:51:48 2023  stm[3767]: <305061> <5840> <WARN> |stm|  AP AP1_Aruba ip 10.56.30.19 outer_ip 0:0:0:0 down , reason: controller role changed
    Jun 16 11:54:04 2023  stm[3767]: <305061> <3767> <WARN> |stm|  AP AP1_Aruba ip 10.56.30.19 outer_ip 0:0:0:0 down , reason: controller detect heart beat timeout
    Jun 16 11:56:02 2023  stm[3767]: <305061> <3767> <WARN> |stm|  AP AP1_Aruba ip 10.56.30.19 outer_ip 0:0:0:0 down , reason: controller detect heart beat timeout
    Jun 16 11:57:14 2023  stm[3767]: <305061> <3767> <WARN> |stm|  AP AP1_Aruba ip 10.56.30.19 outer_ip 0:0:0:0 down , reason: controller detect heart beat timeout
    Jun 16 11:58:08 2023  stm[3767]: <305061> <3767> <WARN> |stm|  AP AP1_Aruba ip 10.56.30.19 outer_ip 0:0:0:0 down , reason: controller detect heart beat timeout
    Jun 16 11:59:34 2023  stm[3767]: <305061> <3767> <WARN> |stm|  AP AP1_Aruba ip 10.56.30.19 outer_ip 0:0:0:0 down , reason: controller detect heart beat timeout
    Jun 16 11:59:56 2023  stm[3767]: <305061> <3767> <WARN> |stm|  AP AP1_Aruba ip 10.56.30.19 outer_ip 0:0:0:0 down , reason: controller detect heart beat timeout
    Jun 16 12:01:00 2023  stm[3767]: <305061> <3767> <WARN> |stm|  AP AP1_Aruba ip 10.56.30.19 outer_ip 0:0:0:0 down , reason: controller detect heart beat timeout
    Events Airwave:
    Fri Jun 16 11:52:16 2023 System Up
    Fri Jun 16 11:51:58 2023 System AP's associated controller is changed from ArubaWifi_Amu to ArubaWifi_SyA
    Fri Jun 16 11:51:49 2023 System Status changed to 'AP is no longer associated with controller'
    Fri Jun 16 11:51:49 2023 System Down
    Fri Jun 16 10:27:06 2023 System Status changed to 'OK'
    Fri Jun 16 10:27:06 2023 System Up
    Fri Jun 16 10:24:11 2023 System Status changed to 'AP is no longer associated with controller'
    Fri Jun 16 10:24:11 2023 System Down
    There is any solutions or suggest?
  • 6.  RE: APs flapping, heartbeat timeout
    Posted Jun 28, 2023 10:25 AM
    Were you able to fix it @jefferson.monegro ? I´m facing the same issue
  • 7.  RE: APs flapping, heartbeat timeout
    Posted Jun 28, 2023 10:29 AM
    no @luicarri :( im programming an upgrade to 8.10.0.7 and see what happend, or open a TAC Case.
    If you fix it, please let me know, same for me.
  • 8.  RE: APs flapping, heartbeat timeout
    Posted Jun 28, 2023 10:40 AM
  • 9.  RE: APs flapping, heartbeat timeout
    Posted Jun 30, 2023 10:11 PM
    I am having the same issue in version 8.10.0.0. Tried upgrading to 8.10.0.6 but nothing changed. TAC case is opened but the progress is slow. Is there any findings so far?
    2 Virtual MM  / 2 7210 MC with cluster/ APs 515
  • 10.  RE: APs flapping, heartbeat timeout
    Posted Jul 01, 2023 03:27 PM
    @timyuaruba Please PM me your TAC case number.
  • 11.  RE: APs flapping, heartbeat timeout
    Posted Jul 03, 2023 09:42 AM
    Please, let us know if TAC tell you any solutions, thanks
  • 12.  RE: APs flapping, heartbeat timeout
    Posted Jul 05, 2023 09:58 PM
    We have applied multiple changes on the configuration and the issue seems disappear after that, not sure which one is the exact fix to this issue:
    forcing ~300 APs to failover to DR site controllers (around 400 APs in total), disabling the controller cluster, enabling BCMC on user VLAN and also disabling the OSPF on all VLAN interfaces except management VLAN
  • 13.  RE: APs flapping, heartbeat timeout
    Posted Sep 12, 2023 11:27 AM
    btw: I have 8.10.0.7 LSR since first day that was released and still happen...
  • 14.  RE: APs flapping, heartbeat timeout
    Posted Jul 05, 2023 02:51 PM
    I'm also running into the same issue. I've sent a bunch of logs to TAC, but so far haven't been able to find a solution.
    They're asking me to set up an SCP server on the network for an AP NSS dump log...but haven't been able to set up an SCP server for just this case. The AP won't dump the file onto the controller and needs the SCP server apparently.
  • 15.  RE: APs flapping, heartbeat timeout
    Posted Oct 05, 2023 08:45 AM
    Hi, yesterday tried to upgrade first cluster to AOS8.10.0.6 , same issue ...
    Oct 4 23:32:04 2023 :305061:  <17115> <WARN> |stm|  AP nwxxxxxx ip 10.xxxxx outer_ip 0:0:0:0 down , reason: controller detect heart beat timeout
    The weird thing is that around 30 of 100 AP on this cluster could upgrade, but not the others ..
    Anyone got a solution or more feedback from TAC ?
    Danny Bosman
    KBC Group - Belgium
  • 16.  RE: APs flapping, heartbeat timeout
    Posted Oct 05, 2023 11:44 AM
    Is this controller-based?  What is the switching infrastructure between the access points and the controller?  Are the access points dual connected?
  • 17.  RE: APs flapping, heartbeat timeout
    Posted Oct 12, 2023 08:38 AM
    Yes, this is controller based (cluster of 2 controller - L2 connected).
    Due to growth in number of AP, we have 2 subnets for the AP. After some more investigation, it turns out that all AP on subnet "1" are upgraded, but none on subnet "2".  There is a VRRP definition for subnet "1" (used in DHCP options). Local routing between these 2 subnets is provided via cisco switch.
    The 2 controllers each have an ipaddr in each subnet ("1" & "2").
    AP are not dual connected. Most of AP we use on this location are AP305, but also AP315 & 515 are impacted.
    Danny Bosman
    KBC Group - Belgium
  • 18.  RE: APs flapping, heartbeat timeout
    Posted Oct 12, 2023 09:05 AM
    After the initial discovery of a cluster, the dhcp options do not matter:  the access points will write the ip addresses of the controllers in the cluster into flash and they will no longer do discovery.
    Each controller has a single "controller-ip" and regardless of what interface the access point discovers the controller on, the access points will connect to that controller on that ip address.  You need to make sure the "controller-ip" is reachable from both subnets, because that is what the access points will use permanently to connect to your controllers.  It doesn't matter how many ip interfaces a controller has:  there is only one controller-ip...
  • 19.  RE: APs flapping, heartbeat timeout
    Posted Oct 16, 2023 08:50 AM
    This is a working situation in AOS8.6.0.20 , so routing is ok.  Just doing upgrade to 8.10 a lot of failures.
    I'm able to simulate this case in our Lab .
    Could it be related to AOS-218844 , AOS-222351 (release notes 8.11) ? FYI - also in contact with our external support partner
    Danny Bosman
    KBC Group - Belgium
  • 20.  RE: APs flapping, heartbeat timeout
    Posted Oct 16, 2023 08:56 AM
    Please continue to work with your external support partner.  There are quite a few reasons why this could happen and there are combinations of reasons why it could happen.  The fact that you can replicate it in the lab would allow support to resolve this sooner.
  • 21.  RE: APs flapping, heartbeat timeout
    Posted Oct 16, 2023 09:06 AM
    I looked at both of those bugs and they are related to the MM not choosing all of the APs to upgrade during a cluster upgrade.  If you choose a traditional upgrade, where you just upgrade the code on the individual MDs and reboot them, instead of doing a cluster upgrade, you should be able to sidestep those bugs.
    I would show support your data so that they can figure out what could be going wrong.
  • 22.  RE: APs flapping, heartbeat timeout
    Posted Apr 04, 2024 07:46 AM
    Has anybody some update on the root cause as I had the same problem yesterday when upgrading from 8.6.0.22 > 8.10.0.10
    Same type of messages:
    Apr  3 20:02:03 2024  stm[17903]: <305061> <17903> <WARN> |stm|  AP AP-GIVA-1ER-RECEPTION ip 10.94.184.104 outer_ip 0:0:0:0 down , reason: controller detect heart beat timeoutApr  3 20:02:08 2024  stm[17903]: <305061> <17903> <WARN> |stm|  AP AP-BULC--EXPO-ETAGE-4 ip 10.94.171.130 outer_ip 0:0:0:0 down , reason: controller role changed
    Apr  3 20:02:08 2024  stm[17903]: <305061> <17903> <WARN> |stm|  AP RBB-AP-BERN-LAUPEN-A-NEW ip 10.94.95.102 outer_ip 0:0:0:0 down , reason: controller role changed
    Apr  3 20:02:08 2024  stm[17903]: <305061> <17903> <WARN> |stm|  AP AP-CONA-REZ-SHOP ip 10.94.179.141 outer_ip 0:0:0:0 down , reason: controller role changed
    Apr  3 20:02:08 2024  stm[17903]: <305061> <17903> <WARN> |stm|  AP RBB-AP-WIIA-D ip 10.94.160.89 outer_ip 0:0:0:0 down , reason: controller role changed
    To add it was not during the FW upload to the AP as I had pre-loaded the new FW on all APs before and on migration time just switch version on the controllers
    2 x MM
    3 x 7210
    560 x APs various models (AP-205 / AP-305 / AP-505 / AP-375) all same problem
    Kind regards
    Christian Chautems
  • 23.  RE: APs flapping, heartbeat timeout
    Posted Apr 04, 2024 09:24 AM
    Do you use port-channel ? If so, check the command "trusted vlan"
    In our config it was present on the Gi-interfaces , but not on port-channel. No problem in 8.6 , but a lot of issues immediately after migration to 8.10
    Add "trusted vlan 1-4094" to the port-channel (reboot needed)
    Danny Bosman
    KBC Group - Belgium
  • 24.  RE: APs flapping, heartbeat timeout
    Posted Apr 04, 2024 09:56 AM
    Hello Danny,
    Thanks for the clue it may be the problem
    I have Port-channel on two of my three controllers 7210
    By checking the configs I have the "trusted vlan 1-4094" on PC but some mismatch between config of trusted vlan on both of the physical interfaces of the PC
    Will plan a maintenance window to correct the configs then try again upgrading to 8.10 (have reverted to 8.6 yesterday)
    Kind regards
    Christian Chautems
  • 25.  RE: APs flapping, heartbeat timeout
    Posted Apr 09, 2024 01:46 PM
    Got Similar issue running 8.10.0.8LTR. Looking on my config can you tell me if this is what you guys referring to?
  • 26.  RE: APs flapping, heartbeat timeout
    Posted Apr 10, 2024 01:17 PM
    Better to look at the Interfaces & Port-channel config via CLI on the controllers themselves for mismatched config
    I have correct the mismatches via CLI on MM/MC and upgraded again to 8.10.0.9.
    After 20 min all APs are back and seems stable now.
    Kind regards
    Christian Chautems
