Wired Intelligent Edge
last person joined: 8 hours ago
ARUBA 1930, is it possible to connect a non poe device safely on POE interface?
This thread has been viewed 19 times
  • 1.  ARUBA 1930, is it possible to connect a non poe device safely on POE interface?
    Posted Jun 24, 2022 11:38 AM
    i would like to know if it's possible to connect a non poe device (standard interface RJ45 from my laptop for exemple)  to the POE interface of my aruba 1930?
    Thank you.
  • 2.  RE: ARUBA 1930, is it possible to connect a non poe device safely on POE interface?
    MVP GURU
    Posted Jun 26, 2022 05:39 AM
    Yes, it is. What is worrying you about?
  • 3.  RE: ARUBA 1930, is it possible to connect a non poe device safely on POE interface?
    Posted Jun 30, 2022 04:12 AM
    i just would like to knpow the mechanism that's make it safe. :)
  • 4.  RE: ARUBA 1930, is it possible to connect a non poe device safely on POE interface?
    MVP GURU
    Posted Jul 01, 2022 12:00 PM
    Since the Aruba 1930 adheres to IEEE Standards and since the IEEE standard PoE behavior requires that the Switch first checks if there is a PoE capable devices attached to the physical interface, once the switch successfully identified a PoE capable device (which is a PD Powered Device, I add) it supplies power as required by the recognized PD. That's the mechanism that made it safe for non-PD device to be connected to a PoE capable Switch adhering to IEEE Standards.
  • 5.  RE: ARUBA 1930, is it possible to connect a non poe device safely on POE interface?
    Posted Jul 04, 2022 05:01 AM
    Ok, thanks you for this precise answer.
