AOS-CX Switch Simulator
Aruba 1930 switch connection to cisco
This thread has been viewed 24 times
  • 1.  Aruba 1930 switch connection to cisco
    Posted Aug 03, 2022 10:25 PM
    Hi everyone,
    I have two switches( non of them does any routing), the first is Aruba 1930 and the second is cisco. How should I configure the port connecting both switches together?
    Note: the cisco switch is configured as trunk but I have no clue how Aruba should be configured
  • 2.  RE: Aruba 1930 switch connection to cisco
    Posted Aug 04, 2022 10:18 AM
    Hi SSAA168,
    Find the complete 1930 Switch Guide here: https://higherlogicdownload.s3.amazonaws.com/AIO/UploadedImages/147be25c-bcb8-4e18-8ecc-a6cc77b4ed6c/1930_Management_and_Config_Guide.pdf
    At the end of page 70 you will find the instruction on how to configure a trunk.
    I hope this helps.
  • 3.  RE: Aruba 1930 switch connection to cisco
    Posted Aug 04, 2022 11:44 AM
    on the Aruba side you will need to use LACP
  • 4.  RE: Aruba 1930 switch connection to cisco
    Posted Aug 05, 2022 01:58 AM
    On Cisco a trunk in not a LAG (Link Aggregation Group) it's multiple VLAN on a port. So on Cisco you need find which VLAN you have, and which VLAN are allowed on the interface. Create the VLANs on the new switch and configure the interface with the same VLAN , tagged and untagged.
    This is not related to the Switch Simulator in any way ;-)
    Arne Opdal
