Based on this information it's hard to say something useful.
Thing you can try:
- Change the PC to a different port (swap with another client); see if the issue is on the port or on the client
- Replace the cable between switch and PC
- See that if you see the issue, then disconnect the cable and connect back, if that resolves the issue.
Original Message:
Sent: Jan 27, 2023 07:26 AM
Subject: Aruba 2530 - problem
I've got a problem with a Aruba switch.
HP 2530-48G-POE (J9772A)
Software revision : YA.16.11.0008
Sometimes PC connected to port 12 is loosing connection to everything.
Port status is UP, 1000MB/s, there is no error on that port.
When i try to see mac address on port there is no output there.
PC restart doesn't help.
The only one thing that helps is restart of a switch.
When switch is restarted everything is working fine and i can see MAC address of this PC on that port
Do you have any idea why this issue occurs and how to fix it, because restarting a switch every time is not an option i want to use ?
