Wired Intelligent Edge
Aruba 2530 - problem
  • 1.  Aruba 2530 - problem
    Posted Jan 27, 2023 09:53 AM
    I've got a problem with a Aruba switch.
    HP 2530-48G-POE (J9772A)
    Software revision : YA.16.11.0008
    Sometimes PC connected to port 12 is loosing connection to everything.
    Port status is UP, 1000MB/s, there is no error on that port.
    When i try to see mac address on port there is no output there.
    PC restart doesn't help.
    The only one thing that helps is restart of a switch.
    When switch is restarted everything is working fine and i can see MAC address of this PC on that port
    Do you have any idea why this issue occurs and how to fix it, because restarting a switch every time is not an option i want to use ?
  • 2.  RE: Aruba 2530 - problem
    Posted Jan 31, 2023 07:57 AM
    Based on this information it's hard to say something useful.
    Thing you can try:
    - Change the PC to a different port (swap with another client); see if the issue is on the port or on the client
    - Replace the cable between switch and PC
    - See that if you see the issue, then disconnect the cable and connect back, if that resolves the issue.
