Network Management
Aruba 2530/2930 - Problems with deployment task after update to IMC E0710P03
This thread has been viewed 65 times
  • 1.  Aruba 2530/2930 - Problems with deployment task after update to IMC E0710P03
    Posted Feb 19, 2024 04:13 AM
    Hello everyone,
    Last week I updated my IMC to the latest version E0710P03 and then wanted to update the firmware of my Arubas 2530, 2930 and CX 6000 using a deployment task. This always worked before the IMC update, but now I get the following error on the 2530 and 2930:
    Is there anyone else getting this error? Is it a bug in the new IMC version?
    Thank you in advance and best regards
  • 2.  RE: Aruba 2530/2930 - Problems with deployment task after update to IMC E0710P03
    Posted Feb 20, 2024 03:57 AM
    1. no consistency in version E0710P03 below E0708.P03
    2. 2540,2920,2930  <backup failed>
    but
    2626,2650,2824,5308,5400  <backup ok >- in my opinion it is a bug
    3. Problem with sorting by version of Avaible Software (Firefox,Chrome)
    Service > Configuration Center
     not working: sort by <Latest Available Version>
    Best Regards
  • 3.  RE: Aruba 2530/2930 - Problems with deployment task after update to IMC E0710P03
    Posted Mar 05, 2024 03:44 PM
    Hello
    same problem in my environment after upgrade to E0710P03.
    I cannot deploy task to device and cannot backup software. What is a strange for me that I can for example backup all config from stacked switches only. I think that this is bug and should be immediately fixed.
    Krzysztof
  • 4.  RE: Aruba 2530/2930 - Problems with deployment task after update to IMC E0710P03
    Posted Apr 03, 2024 06:08 AM
    Hello !
    Same problem here. Since last iMC update E0710P03 we are unable to flash 2530 series.
    Please HPE Team fix it immediatly.
    The alert CVE-2024-26303 is important and we must upgrade all switches as soon as possible !
    Best Regards.
    Michael
  • 5.  RE: Aruba 2530/2930 - Problems with deployment task after update to IMC E0710P03
    Posted Apr 03, 2024 06:13 AM
    If you have urgent issues, always open a case with Support. This community is for non-urgent issues, and not actively monitored/read by support or the product teams. Reaching out to support is the way to report such issues.
  • 6.  RE: Aruba 2530/2930 - Problems with deployment task after update to IMC E0710P03
    Posted Apr 15, 2024 12:32 PM
    config backup is partly wasted after updating to E0710P03. too.
    this is kinda annoying.
    some devices backup just fine (didn't actually check for details), some devices don't.
    2024-04-15 18:02:45.986 [INFO (2126)] [THREAD(10396)] [CComponentAdapter::getSupportAdapter()] ver info is ser:HPEAruba2930FSwitch vrp:N/A rel:N/A
    2024-04-15 18:02:45.986 [WARNING (2001)] [THREAD(10396)] [CComponentAdapter::getSupportAdapter()] Fail to get dev version,devID=118
    2024-04-15 18:02:45.986 [WARNING (43)] [THREAD(10396)] [CComponentAdapter::discoverDeviceAdapter()] fail to call getSupportAdapter(),devID=118
    2024-04-15 18:02:45.986 [DEBUG (0)] [THREAD(10396)] strAdapterName is N/A
    2024-04-15 18:02:45.986 [ERROR (43)] [THREAD(10396)] [CComponentAdapter::getDevAdapterName()] fail to call discoverDeviceAdapter()
    2024-04-15 18:02:45.986 [ERROR (43)] [THREAD(10396)] [CComponentAdapter::isDevSupportServiceAction()] fail to call getDevAdapterName().DevID=118,ServiceName = ConfigBackup
    a workaround would be nice.
  • 7.  RE: Aruba 2530/2930 - Problems with deployment task after update to IMC E0710P03
    Posted Apr 16, 2024 04:42 AM
    support have a patch for  this problem, you can request it with a support ticket.
    Problem  will be fixed in the next release.
    Kind regards
    Paola
    Kind Regards
    Paola
  • 8.  RE: Aruba 2530/2930 - Problems with deployment task after update to IMC E0710P03
    Posted Apr 17, 2024 02:19 AM
    Hi all,
    Thank you @pbit for the information of the patch.
    My iMC server is now fully operational. I can update the firmware of all my switches.
    Best Regards.
    Michael
