That is not something the CX 6000 can help with. Also, you should not use 191.168.0.0/16 as a subnet as it is in use on the internet.
For 'getting to the internet', that's something your router should take care of, as it probably will to do routing and NAT for it.
Who designed/built this network?
Original Message:
Sent: Mar 07, 2023 03:12 AM
Subject: Aruba 6000 VLAN 20- Help
Good morning!
I urgently need your expertise and which commands I should enter in the console.
My problem is that, I don't know how VLAN 20 gets out to the internet.
I have drawn my network structure and attached it as an attachment.
Many thanks for your help!
kind regards
MCB2323
