Wired Intelligent Edge
last person joined: 26 minutes ago
Aruba 6100 VLAN not passing to next switch in lag
This thread has been viewed 22 times
  • 1.  Aruba 6100 VLAN not passing to next switch in lag
    Posted 28 days ago
    I am used to Aruba 29XX series switches but we are switching to Aruba 6XXX series as it seems the new 29XX are missing some of the features of their predecessors. I am working on replacing old Cisco 2960-S switches at a site (as they are physically failing) with Aruba 6100 but I have an odd issue where the switch is "accepting" vlans (particularly vlan 12 in the case of this site) but not passing them to the next switch.
    General network layout:
    Firewall
    V
    SW1-> SW2-> SW3
     \-> SW4-> SW5-> SW6-> SW7-> SW8-> SW9-> SW10
    Voice router attaches to SW7 on VLANs 4 and 12 for either side of the router.
    SW1, SW7, SW8, SW9, and SW10 are Aruba 2930
    SW2, SW4, SW5, and SW6 are currently Cisco 2960-S and are nearly identical in config besides "description" and some have channel-group1/2 swapped.
    SW3 is working fine as a Aruba 6100 and has nearly identical configs
    SW5 replacement is not working.
    SW5 replacement (nearly identical to SW3)
    vlan 1
    vlan 3
        name DMZ
    vlan 4
        Server
    vlan 12
        name Voice
        voice
    vlan 101, 254
    spanning-tree
    spanning-tree config-name internal
    spanning-tree config-revision 1
    spanning-tree vlan 1,2,4,13,101,254
    interface lag 1
        no shutdown
        vlan trunk native 1
        vlan trunk allowed all
        lacp mode active
    interface lag 2
        no shutdown
        vlan trunk native 1
        lacp mode active
    interface 1/1/44
        no shutdown
        vlan trunk native 4
    interface 1/1/45
        no shutdown
        lag 2
    interface 1/1/46
        no shutdown
        lag 2
    interface 1/1/47
        no shutdown
        lag 1
    interface 1/1/48
        no shutdown
        lag 1
    interface vlan 1
        ip dhcp
    interface vlan 4
        ip address 10.1.4.35/24
    interface vlan 12
    Cisco Catalyst 2960-S SW6:
    spanning-tree mode mst
    spanning-tree extend system-id
    spanning-tree mst configuration
     name internal
     revision 1
     instance 1 vlan 1-4094
    interface Port-channel1
     description Port Channel to SW5
    interface Port-channel2
     description Port Channel to SW7
    interface GigabitEthernet1/0/44
     switchport access vlan 4
     switchport mode access
     switchport voice vlan 12
     spanning-tree portfast
    interface GigabitEthernet1/0/45
     switchport mode trunk
     channel-group 2 mode on
    interface GigabitEthernet1/0/46
    interface GigabitEthernet1/0/47
     description Port channel to SW5
     channel-group 1 mode on
    interface GigabitEthernet1/0/48
    interface Vlan1
     ip address 10.1.0.4 255.255.255.0
  • 2.  RE: Aruba 6100 VLAN not passing to next switch in lag
    Posted 19 days ago
    After quite a bit of troubleshooting it seems the issue is that neither the Cisco or Aruba side seems to like having "vlan trunk allowed all" and wants the specific vlans in the command on both sides. Also there may or may not have been an extended issue with the Cisco which they dont always work with "channel-group 2 mode on" and prefer like "channel-group 2 mode active"
  • 3.  RE: Aruba 6100 VLAN not passing to next switch in lag
    Posted 16 days ago
    Well, not sure whether "vlan trunk allowed all" is really the problem here. I did a lot of migrations in the past and never had issues with that. However, I prefer having an explicit list of vlans defined on the links rather than a dynamic list of vlans.
    Moreover, I wouln't say there is issues regarding port-channel mode with Cisco. It's simply that you should have the same config on both sides. Cisco's "channel-group mode on" means no negitiation or in other words static. This should be configured as "lag XX static" on Aruba side and will post probably work. If LACP is prefered (which it should), use "channel-group mode active/passive" on Cisco side and "lacp mode active" on Aruba side and it will again most probably work. If "channel-group mode auto/desired" is on Cisco side, you will never find an Aruba switch form a link-aggregation as this uses PAgP protocol (Cisco proprietary).
  • 4.  RE: Aruba 6100 VLAN not passing to next switch in lag
    Posted 16 days ago
    Just as a little extra information in addition to my other post on the solution. There was an issue with LACP solved as you mentioned by changing the Cisco switches to "channel-group mode active" but the Cisco switches were giving an error about mismatched VLANs despite all switches (unless there is a legacy one stuffed in a coat rack that went missing 10+ years ago) having matching VLANs across the board (ignoring my typo here that VLAN3 is vDMZ which is and should be 2)
