Aruba 7030 stand-alone mode (os8.9) how to create simple captive portal for shopping mall guest
This thread has been viewed 16 times
  • 1.  Aruba 7030 stand-alone mode (os8.9) how to create simple captive portal for shopping mall guest
    Posted Mar 20, 2024 11:54 AM
    Hi. I am new to Aruba. I had setup office user can connect WiFi thru Aruba 7030 standalone mode (os8.9)
    but I need setup a simple captive portal for shopping mall guest - just need click accept and can connect 1hour. Then dis-connect. Guest need click accept again for next 1hour.
    Please help. Many thank
  • 2.  RE: Aruba 7030 stand-alone mode (os8.9) how to create simple captive portal for shopping mall guest
    Posted Mar 25, 2024 09:30 AM
    If you configure a captive portal, the internal captive portal may be fine, set the re-authentication timeout for the guest role to 60 minutes to force a reauthentication after an hour.
    Please note that ArubaOS 8.9 is end-of-support. For other than lab purposed, I'd recommend upgrading to a supported version.
  • 3.  RE: Aruba 7030 stand-alone mode (os8.9) how to create simple captive portal for shopping mall guest
    Posted Mar 25, 2024 10:15 PM
    Dear Herman,
        many thanks for your answer. Aruba was very powerful. i read with the " internal captive portal " ; it was command line mode. is it working with SSH or telnet console. or is it have some GUI step which easy for me ( beginner ) to handle ?
      many thanks again.
  • 4.  RE: Aruba 7030 stand-alone mode (os8.9) how to create simple captive portal for shopping mall guest
    Posted Mar 25, 2024 11:04 PM
    Dear Herman,
        I study more information. ( my case was 7030 standalone mode ) Can I setup at GUI :
  • 5.  RE: Aruba 7030 stand-alone mode (os8.9) how to create simple captive portal for shopping mall guest
    Posted Mar 26, 2024 04:24 AM
    Sorry ; i double check. the currently fireware version was " ArubaOS_70xx_8.11.2.0_87947 " Thanks.
