If you configure a captive portal, the internal captive portal may be fine, set the re-authentication timeout for the guest role to 60 minutes to force a reauthentication after an hour.
Please note that ArubaOS 8.9 is end-of-support. For other than lab purposed, I'd recommend upgrading to a supported version.
Original Message:
Sent: Mar 20, 2024 11:27 AM
Subject: Aruba 7030 stand-alone mode (os8.9) how to create simple captive portal for shopping mall guest
Hi. I am new to Aruba. I had setup office user can connect WiFi thru Aruba 7030 standalone mode (os8.9)
but I need setup a simple captive portal for shopping mall guest - just need click accept and can connect 1hour. Then dis-connect. Guest need click accept again for next 1hour.
Please help. Many thank
