  • 1.  Aruba AP IPM
    Posted 26 days ago
    Hi!
    Does anybody know if Aruba AP local GUI has IPM feature, because in Central there is IPM that you can push to all your APs. Also you can configure it through CLI, but if you have a cluster of APs and do it via CLI you can do it only on master AP and therefore it applies only on that AP, I guess.
    So my question is where to find IPM on IAP GUI?
  • 2.  RE: Aruba AP IPM
    Posted 26 days ago
    Instant AP when managed locally requires configuration of IPM via the CLI.  IPM is a VC level configuration and applies to all IAPs in the swarm.
    Carson Hulcher, ACEX#110
  • 3.  RE: Aruba AP IPM
    Posted 26 days ago
    the cli commnd are
    PS-Lvl1-b2:5b# conf t
    We now support CLI commit model, please type "commit apply" for configuration to take effect.
    PS-Lvl1-b2:5b (config) # ipm
    PS-Lvl1-b2:5b (ipm) # enable
    PS-Lvl1-b2:5b# commit apply
    committing configuration...
    configuration committed.
    PS-Lvl1-b2:5b#
