Aruba Central Controllerless Environment Is Not Working
This thread has been viewed 113 times
  • 1.  Aruba Central Controllerless Environment Is Not Working
    Posted Mar 12, 2024 11:30 AM
    I've had Aruba Central running my network since November and I have had nothing but trouble with it. My environment is a school with up to 1300 active daily users. There are 140 Access Points.
    Currently I have had issues with:
    Roaming.
    Users getting rejected by the access point when connecting.
    When some users get connected they get speeds as slow as .5mbps. Sometimes it speeds up, sometimes it doesn't.
    Users get kicked off for no reason whatsoever, just while sitting at their desk.
    If more than 20 users try to connect at one time most or all of them will not get connected. This of course doesn't work when students enter a new room every 45 mins.
    We have Clearpass and there are rejections in Clearpass but those may be related to roaming according to TAC. I've tried different APs but it doesn't seem to make a difference.
    The one thing I am unsure of would be our switches. Last summer we installed 17 new Aruba/HPE 2930 switches on top of the 8 2930's we installed a couple years ago. I don't think I am seeing issues in the areas of the 8 older switches, at least no one is complaining about issues in those parts of the building. Could there be a configuration on the switch that is causing problems with the APs? I am not sure.
    I have had our sales engineer, multiple outside groups, and numerous tickets with TAC open and no one can seem to find a problem. Basically the network has become unusable and I am unsure what to do next. I can go back to the controllers but don't I have to move to AOS10 eventually? Shouldn't there be a way to make this all work?
    Any help would be greatly appreciated.
  • 2.  RE: Aruba Central Controllerless Environment Is Not Working
    Posted Mar 12, 2024 12:02 PM
    Well there is a lot to unpack here - and my suggestions could go a lot of different directions.
    But it sounds like your most impactful issues are Roaming, Client Disconnects and Sticky Clients.
    I can certainly suggest some configuration tweaks to tune those items. But I am more curious about your recent change to Central.
    You had controllers before? What was the reason for removing them from the equation?
    I ask this because if you had Controllers before, it is likely they were tunneling WLAN traffic, have you considered/engineered and made changes to all of your L2 AP links to now handle this traffic?
    If my post was useful, please Accept Solution and Give Kudos.
    Zak Chalupka
    Principal Engineer - HPE Aruba
    ACDX | ACMP | ACSP | ACCP
    wifizak@hpe.com
    Ideas expressed here are solely my own and not necessarily that of HPE Aruba.
  • 3.  RE: Aruba Central Controllerless Environment Is Not Working
    Posted Mar 12, 2024 12:16 PM
    We've made a few changes in Central. The system is down now so I can't go in and share the exact changes, but we change the transmit speed for the APs, to allow for fewer sticky clients, we turned off the 2.4 channel in an effort to fight interference but that might not have been an issue, we turned off the 80mhz channel, and turned off the PMKr cache since a large number of our roaming issues were related to PMK not transferring between APs.
    We moved away from the controllers and AOS8 when our support contracts came due and were told it was a better deal (it was cost wise) to move to AOS 10 and Central.
    As to your last question, I wondered that myself. I don't believe we made that change, at least I did not. I do remember seeing that the traffic was tunneled on the controllers and bridged now. Is that a change that can be made in Central or does it require a controller?
    I noticed that some of our switches were configured with Spanning Tree turned on and some with it turned off. Could that be an issue as well? The areas with the most problems are with spanning tree turned on.
    I didn't mention this at first but all our APs are 515s.
  • 4.  RE: Aruba Central Controllerless Environment Is Not Working
    Posted Mar 12, 2024 01:49 PM
    From a cost savings perspective decommissioning the controllers is a great move, and aos10/Central is more capable of serving larger environments than that of aos8. But in some cases, primarily large campus networks, controllers can help (with aos8 or aos10) with roaming and access.
    If you continue without controllers, I would highly recommend an audit of the AP Uplink Configurations for starters. Make sure every AP has the same trunk (untagged/tagged) configurations that includes your WLAN User VLANs.
    Zak Chalupka
    wifizak@hpe.com
  • 5.  RE: Aruba Central Controllerless Environment Is Not Working
    Posted Mar 12, 2024 05:08 PM
    yes it is recommended not to use 80MHz channel on 5GHz band due to limited number of non-overlapping channels.
    what firmware version are you running?
  • 6.  RE: Aruba Central Controllerless Environment Is Not Working
    Posted Mar 13, 2024 09:18 AM
    We are on 10.5.0.1
    After a 2 plus hour marathon session yesterday with TAC we found that clients are getting rejected before they even get to the AP itself. The thinking now is there might be something in the switch config. They opened a new ticket with the switch team on that.
    We have switches that were installed in 2020-21 that don't seem to display this issue on their APs and ones installed this past summer that do. Both sets were installed by HPE engineers so I assume there must have been something in the config that is creating a bottleneck on the switch ports that might be the issue. I'm not sure what it would be. I hope to have a solution soon.
  • 7.  RE: Aruba Central Controllerless Environment Is Not Working
    Posted Mar 13, 2024 10:13 AM
    There certainly could be an issue with the switch - Port Misconfiguration, Spanning Tree Issues, Loops, Uplink Provisioning.
    The symptoms however still lead me to believe you may have a VLAN issues on the AP Uplinks. You'll want to be sure that all Client VLANs are tagged/trunked/allowed to theses AP ports. As well as ensuring those VLANs have a tagged path back to your core. This was not (would not) be the case with controllers.
    Zak Chalupka
    wifizak@hpe.com
  • 8.  RE: Aruba Central Controllerless Environment Is Not Working
    Posted Mar 13, 2024 12:40 PM
    I did have TAC look at that yesterday and they did think it looked good. Hopefully we can sort this out soon.
  • 9.  RE: Aruba Central Controllerless Environment Is Not Working
    Posted Mar 22, 2024 10:38 AM
    So we have still be struggling with this issue. I have three tickets open one with clearpass, one with IAP and one with switches. The clearpass team said they found users are not getting to clearpass and are getting rejected before then, as we suspected. I am still waiting on the switch team to get back with the info I shared with them. They are working with the IAP team directly to look at the data.
    Today I had a connection drop on me while I was in a Teams meeting and it is an example of what I am seeing. My computer had been connected without any problems since the previous day but at 9:11am I was disconnected. The computer was disconnected for about 5 minutes before reconnecting. I did not roam away from the AP. It just kicked me off. Here is the event log from Central:
    A DHCP timeout, followed by an L3 failure then more DHCP and then reconnected. This is pretty common across the entire network. I had noticed this happening to clients when the roam but does seem to happen when they don't roam. Just booted off.
    The switch engineer is pretty confident we can solve this problem.
  • 10.  RE: Aruba Central Controllerless Environment Is Not Working
    Posted 29 days ago
    After a month of technical support TAC has seemed to narrow down the issue.
    It appears that users are connecting but not able to communicate with Clearpass. Multiple packets are being sent to Clearpass but are either getting lost or rejected before Clearpass allows a connection. The only real change to Clearpass in the past few months was moving to 6.11, which was a real pain. Though the configuration didn't change. I also am not sure if Central is set up properly to communicate with Clearpass. Currently users are not getting the correct IP addresses when they connect. I am waiting for one of four TAC tickets I have open to set up a time to meet with me.
    I feel the best thing to do would be to redo all the configurations, but I don't have the level of expertise to do that right. It's also really hard to find a qualified Aruba tech out in the world to help me. So I will wait on TAC and see what happens.
  • 11.  RE: Aruba Central Controllerless Environment Is Not Working
    Posted 26 days ago
    Downgrade from 10.5.x to 10.4.1.1.  We had tons of roaming issues on 10.5 and downgrading to 10.4.1.0 fixed 99% of them.  We had an issue where sometimes users would fail to roam with "Association Flood Detected" if they roamed too often in a short period of time - this was resolved when we upgraded to 10.4.1.1.
    If you want/need help with your Aruba environment, let me know.  I have been working with Aruba wireless since 2012 and currently manage/architected our Aruba setup with AOS-CX switches/655 APs/9240 controllers/Clearpass - All AOS10/Central.
  • 12.  RE: Aruba Central Controllerless Environment Is Not Working
    Posted 26 days ago
    This is interesting. I didn't even think about downgrading. We started at 10.5 so maybe it's been an issue all along. Would this in anyway affect the connection between the APs and Clearpass?
    I'm starting to think the issue might be in how our Clearpass VM is not allowing enough traffic to reach Clearpass, which is resulting in packets getting dropped and connections getting lost when clients attach to a new AP.
  • 13.  RE: Aruba Central Controllerless Environment Is Not Working
    Posted 26 days ago
    10.5.1.0 and 10.4.1.1 are roughly similar in the number of fixes done from previous versions, 10.6.0.0 is newer than both.
    Carson Hulcher, ACEX#110
  • 14.  RE: Aruba Central Controllerless Environment Is Not Working
    Posted 26 days ago
    "10.5.1.0 and 10.4.1.1 are roughly similar in the number of fixes done from previous versions, 10.6.0.0 is newer than both."
    I have tested 10.5.0.0 - Has PMK cache issues and roaming issues in our environment.
    I have tested 10.5.0.1 - Has PMK cache issues and roaming issues in our environment.
    I have tested 10.5.1.0 - Has PMK cache issues and roaming issues in our environment.
    I have tested 10.4.1.0 - This fixed roaming for us.  Roaming was working so well that we randomly would get "Association Flood Detected" if a client roamed too often in a short period of time.
    I have tested 10.4.1.1 - This fixed the "Association Flood Detected" issue we had.
    I have not tested 10.6.x - I can finally breath and dont have tickets flooding my queue about random disconnects from zoom/issues connecting to the wifi/shipping&recieving manger being pissed off about losing work and pulling everyone in the company he can into a meeting to get status updates all the time.
    10.4.1.0 - Release Overview
    This release contains patch content previously planned for ArubaOS 10.4.0.4. The version number was adjusted to 10.4.1.0 due to additional architectural and serviceability improvements for 802.11r roaming. This release should otherwise be treated as a patch release to 10.4.0.0 and not a traditional dot zero release.
    AOS-247757:
    The 802.11r enabled client could not roam to the new AP. The updated key was not getting synced to the neighbor AP as the key update was sent with a lower sequence number than the previous key.
    The fix ensures that updated key is synced to the neighbor AP.
    Resolved Issues in ArubaOS 10.6.0.0
    I do not see AOS-247757 as fixed in 10.6.0.0.  I do not see any fixes for the PMK cache in 10.6.0.0.  Maybe they fixed it or maybe not - I have not tested this version and do not know.
    10.6.x - SSR
    10.5.x - SSR
    10.4.x - LSR
    https://www.arubanetworks.com/support-services/arubaos-software-release/
  • 15.  RE: Aruba Central Controllerless Environment Is Not Working
    Posted 26 days ago
    So currently we are running 10.5.1.0
    I believe we have been running 10.5.x since moving over. I don't remember being in a different version. What I will do, since I have nothing to lose, I will load 10.4.1.1 tonight and see what happens.
  • 16.  RE: Aruba Central Controllerless Environment Is Not Working
    Posted 25 days ago
    The fix for AOS-247757 shows as present in 10.4.1.0, 10.5.1.0, and 10.6.0.0.  A little troubling if you're seeing the same symptoms on 10.5.1.0.
  • 17.  RE: Aruba Central Controllerless Environment Is Not Working
    Posted 25 days ago
    "The fix for AOS-247757 shows as present in 10.4.1.0, 10.5.1.0, and 10.6.0.0.  A little troubling if you're seeing the same symptoms on 10.5.1.0."
    Please show me where in the release notes it says that AOS-247757 is resolved for any 10.5.x or 10.6.x version.
    Here is the release notes for 10.5.x resolved issues:
    Resolved Issues in ArubaOS 10.5.1.0 - https://www.arubanetworks.com/techdocs/AOS_10.x_RN_WebHelp/Content/10.5.1/0/resolved-issues-10510.htm
    Resolved Issues in ArubaOS 10.5.0.1 - https://www.arubanetworks.com/techdocs/AOS_10.x_RN_WebHelp/Content/10.5/01/resolved-issues-10501.htm
    Resolved Issues in ArubaOS 10.5.0.0 - https://www.arubanetworks.com/techdocs/AOS_10.x_RN_WebHelp/Content/10.5/00/resolved-issues-10500.htm
    Resolved Issues in ArubaOS 10.6.0.0 - https://www.arubanetworks.com/techdocs/AOS_10.x_RN_WebHelp/Content/10.6/00/resolved-issues-10600.htm
    If you want to see how reliable your internal documentation is look up:
    HPE Support Case 5380318131 [ ref:!00Dd00bUlK.!500Kh0VxP1j:ref ]
    See the post that I made below about we trying to explain to TAC for weeks what the public release notes have VS them telling me what version the bug I listed was fixed in.
  • 18.  RE: Aruba Central Controllerless Environment Is Not Working
    Posted 26 days ago
    "Would this in anyway affect the connection between the APs and Clearpass?"
    -No, it would not
    "Clearpass VM is not allowing enough traffic to reach Clearpass, which is resulting in packets getting dropped and connections getting lost when clients attach to a new AP."
    -Its a PMK cache issue.  If you look at your logs I am sure you are going to see a ton of PMK-R1/PMK-R0 issues in your logs (something like that, don't remember 100%).
    The client tries to roam to a new AP.  The PMK cache is incorrect on the new AP and the client fails to connect.  Instead of actually telling the client it needs to do a new full 4-way handshake, the client is stuck in a state where it is kind associated but not really.  This causes the AP to detect that there is no DHCP traffic from the client and disconnects the client from the AP.  It can not send DHCP traffic because the association failed.
  • 19.  RE: Aruba Central Controllerless Environment Is Not Working
    Posted 26 days ago
    The last packet capture TAC took showed that users packets were getting lost on their way from the AP and to Clearpass. This got me thinking that something is in between Clearpass and the AP where packets are not getting through when users are trying to verify through RADIUS.
    What you're describing in your environment is also what I am seeing, so now I am interested in downgrading.
  • 20.  RE: Aruba Central Controllerless Environment Is Not Working
    Posted 26 days ago
    TAC is close to worthless (from my experience).
    Here is a sum-up of my experience with them:
    TAC:
    ME:
    TAC:
    TAC:
    ME:
    TAC:
    ME:
    TAC:
    Aruba Employee:
    Aruba Employee:
    ME:
    TAC:
    TAC:
    ME:
    TAC:
    ME:
    TAC:
    TAC:
    ME:
    TAC:
    After weeks of back and forth, they close my ticket and I had to open a new one so that someone from the controller team could look at the issue.  I didn't want to just upgrade because we finally had a 99% stable environment and only had that one issue that didn't occur very often.
    I got too fed up with the new ticket I had with TAC so I just upgrade to 10.4.1.1 and that resolved the issue.
  • 21.  RE: Aruba Central Controllerless Environment Is Not Working
    Posted 25 days ago
    Looks familiar.
    I have 4 tickets open  1 Aruba Central AP, 1 Switch, 2 with Clearpass. I've had a lot of back and forth but without any solution other than it's not an AP issue it's a Switch issue, it's not a switch issue, its a Clearpass issue and so on. I've kind of thrown my hands up on this and reached out to another local company to just look at the whole system.
    It worked great before we moved to Central, no controller, Clearpass 6.11. One of those items is causing the issue. What? I don't know. I would be ecstatic if this downgrade worked.
  • 22.  RE: Aruba Central Controllerless Environment Is Not Working
    Posted 25 days ago
    I feel your pain.  I have been using Aruba since 2012 and no major issues.  I would go to bat and say that Aruba is No.1 for wireless hands down but since this setup with AOS10 - I will never suggest Aruba to anyone again.  I will actively tell people to stay as far away as possible.
    I work for a company that had almost 200 health centers across the US and in 48/50 states.  We were 100% Aruba other than core/datacenter switching.  Aruba was great and I had no fear that it would continue to work across versions correctly.
    Working for a new company and setup AOS10 to move away from Unifi and I fear any update/change to firmware now as I do not want to deal with the mess that I had to deal with the last 5 months with AOS 10.5.
    You don't have controllers/gateways in your setup so you haven't had the (dis)pleasure of dealing with that.  Trying to update roles on controllers is the worst experience ever.   If your web browser doesn't crash, it is going to take 5 minutes just to make a basic ACL change.  If you put in something wrong (wrong port) then you can't update the rule - you have to delete the rule and create a new one.  Again, if the webpage doesn't crash, that will take at least 10 minutes to delete the rule and create a new one.
    "It worked great before we moved to Central, no controller, Clearpass 6.11. One of those items is causing the issue. What? I don't know. I would be ecstatic if this downgrade worked."
    Yup - 100%.  Like I said - hit me up if you need some help.  It sounds like our environments/Aruba setup is similar except you are not using Aruba-CX switches and you do not have gateways.  I am on 6.12 for Clearpass right now but Clearpass has been rock solid other than a couple minor bugs that were easy to work around.  Local companies/contractors can be hit or miss with stuff like this (from my experience).
  • 23.  RE: Aruba Central Controllerless Environment Is Not Working
    Posted 25 days ago
    Quick note about downgrading to 10.4.1.1 from 10.5.x:
    Make sure you test this on one AP first.  10.5.x added the ability to set the management VLAN of the AP.  In 10.4.x the VLAN/Trunk port of the AP will send management traffic as untagged.
    If you are using the setting under AP GROUP -> CONFIG -> SYSTEM -> VLAN -> Customize Management VLAN:
    1. Update the switch ports for your APs so that the Native/Untagged VLAN is your MGMT VLAN
    2. Set the auto commit for your AP group to OFF
    3. Remove the management VLAN settings for the AP that you will test with
    4. Make sure your AP wired uplink profile is updated correctly with your Trunk/VLAN settings
    5. Apply the settings to the AP you are testing with
    6. Downgrade your firmware from 10.5.x to 10.4.1.1
    If you do not remove the settings for the management VLAN before downgrading it will cause your AP to lose connectivity to the network and you will have to manually reset the AP to factory defaults.
    This happened to me with an AP that I tested the downgrade from 10.5.x.  Make sure you test this on one AP first before you apply to all your APs.
  • 24.  RE: Aruba Central Controllerless Environment Is Not Working
    Posted 25 days ago
    Thank you!
    I checked and we have Customize Management VLAN as disabled.
    I also brought on Aruba here in 2012. They were affordable, easy to manage, and the service and sales teams were great. Then came HP which wasn't so bad at first but eventually we lost contact with the Aruba employees we worked well with. Our sales team is really good now, but for 3-4 years it seemed like we had a new group every 5 months.
    For as long as I can remember clearpass hasn't been an issue until 6.11. In fact I rarely ever looked at other than to prove to a student they don't know their password. What's been happening recently has been strange to say the least. I keep thinking it's something easy that I'm overlooking but I don't know for sure.
    I got a couple of APs I can test 14.0.1.1 on to see what happens. Thanks for all your insight. I will probably reach out to you for more.
  • 25.  RE: Aruba Central Controllerless Environment Is Not Working
    Posted 24 days ago
    Upon your advice I moved some of the more troublemaking APs to 10.4.1.1 and did a few walk throughs to test. They did a good job of allowing me to roam, but once I roamed to an AP with 10.5.x on it I had the same issues. Last night I moved all the APs to 10.4.1.1 and am monitoring it this morning. So far I do not see many PMK errors, which is great. The error I do see is the AP asking for PMK cache and it isn't there. That is normally rectified within a minute when the user connects. I assume as the day progresses that PMK issue will go away as the users connect to more APs around the building.
    I am still seeing high retry rates with devices already connected, EAP timeouts, and Client DHCP timeout. The last two seem to hold up connection for up to a couple of minutes.
    This is positive progress more than I have seen so far. I still think there is something up with Clearpass, I just haven't figured that out yet.
  • 26.  RE: Aruba Central Controllerless Environment Is Not Working
    Posted 24 days ago
    "This is positive progress more than I have seen so far. I still think there is something up with Clearpass, I just haven't figured that out yet."
    If you want some help troubleshooting clearpass - let me know.  Clearpass can be configured in so many different ways that I can't really give to much help without looking at your CPPM server.
    "The error I do see is the AP asking for PMK cache and it isn't there. That is normally rectified within a minute when the user connects. I assume as the day progresses that PMK issue will go away as the users connect to more APs around the building."
    I agree with you and also there can still sometimes issues where the PMK cache doesn't exist for the client (pretty normal in my option).
    If something with the PMK cache is missing/deleted/lost, then you will get this.  The PMK cache by default on windows is longer than the PMK cache for the APs.  Windows has the cache at 12 hours and Aruba has it defaulted to 8 hours.  Not sure if that is related to what you are seeing but that is something that could cause this to happen.  Its not an issue and the client/AP will understand what is happening and the roam/connection will just take 1-2 seconds instead of <100ms.  In AOS10.5.x this is a major issue because the AP/Client do not figure out the PMK cache is bad and the client doesn't know to do a full 4-way handshake.  It was a while when I looked at the pcaps but in 10.5 i believe it wasn't sending a deauth packet to the client correctly and the client kept trying to reconnect with its cached PMK.  This seems resolved in 10.4.1 and the client will understand the PMK was bad.
    "I am still seeing high retry rates with devices already connected, EAP timeouts, and Client DHCP timeout."
    Not sure on the EAP timeouts you are seeing.  I would have to see more details about that.
    The high retry rates could be a lot of things.  Could be poor wifi coverage/clients being dumb/config issue/driver issue/etc.
    Here is an issue I had after downgrading - Sticky clients/Un-steerable clients:
    Since you had issues with roaming for so long, I am sure your Un-Steerable client list is very large due to the clients failing to roam correctly for so often.  I dont know of a way to view the client list without using the REST API, so if you want to do that you will need to call /unsteerable/v1/{tenant_id}
    I dont fully know how that list works (when clients are removed) but I cleared out a ton of devices from that when I enabled 802.11r and downgraded to 10.4.1.0.  This helped fix issues I was seeing with clients being on APs far away and bad SNR/retry rates/etc.  Don't know if that is what you might be seeing or not.
    The DHCP timeouts you are seeing might be related to the stupidity that is Aruba Central and crappy coding.
    There could be a few different reasons for the DHCP timeouts:
    1. Actual issues with network/DHCP server.
    2. Client fails to fully connect to the AP and is rejected.  Since the client is rejected, the DHCP DISCOVER  (not request) from the client is dropped.
    3. 802.11K failing and Aruba Central showing that as a DHCP timeout.
    Take a look at your "Client DHCP Timeout" log - do you see the DHCP Server IP as correct?  If so then 1/2 might be the issue.  I see client DHCP timeout often due to clients getting rejected pretty often and every time I look into it, it is because someone is trying to connect to the wrong SSID (guest trying to connect to the employee network).
    (Here is the one I see the most):
    If you see the "DHCP Server" be the same as the hostname of the client, then this is 802.11k failing and Aruba Central being stupid.
    Here is the packet capture - as you can see there is no DHCP request that is being sent:
    Here DHCP timeout that actually shows to our DHCP server.  When I look at the ClearPass logs I can see that the client is getting rejected:
    Here is the packet capture:
    ^BTW - any Aruba (HPE) engineers out there - this is what DHCP looks like.  If you google for "DHCP wiki" you will find a good reference on how DHCP works.
  • 27.  RE: Aruba Central Controllerless Environment Is Not Working
    Posted 24 days ago
    I had left my computer sitting connected in one room and I left to meet with someone and then came back and found it disconnected. I checked the log and found that the computer is listed as the DHCP server as you said. Right after it a high retry rate. I did spot other of the same DHCP error sprinkled throughout the event logs.
    When it did reconnect it was after a bunch of Disassociation from Client warnings and took a few minutes. I also had to leave the room and it reconnected. When the client does acknowledge DHCP it does so with the right DHCP server. It is important to note that this computer didn't roam it was in the same room when all this happened. When I left the room it was to a small office and reconnected to the same AP that disconnected it.
    The majority of devices we have connecting are iPads so they are seeing the most issues. Windows machines are connecting through EAP-TLS but were still having roaming issues, where the user may have to forget the network to reconnect.
    As far as EAP timeouts go. When I see it in the log on Central I will normally see it in Clearpass. Sometimes it isn't in Clearpass which leads the idea that the requests are getting dropped somewhere.
    When TAC did pcaps of the APs  last week the found that the clients were sending multiple requests to Clearpass and those requests were either getting dropped or rejected. The client then floods Clearpass with requests.
    This still leads me to believe that something else is up with Clearpass. I didn't have this issue before in 6.10 but I think the issue is happening more in 6.11. Knowing that I had to redo the config when I moved to 6.11 I assume something got programmed wrong, even though it didn't change.
  • 28.  RE: Aruba Central Controllerless Environment Is Not Working
    Posted 19 days ago
    I'm starting to come to the realization that there is no fix for these and Aruba Central is a faulty product. Maybe an Aruba employee can help me with the following issue since TAC doesn't seem capable.
    As stated before by another poster on this thread clients are getting DHCP timeouts where Aruba Central identifies the client as the DHCP server. They also get timeouts when the DHCP server is identified as the DHCP server. Is that something in the way Central is set up? Can that be fixed?
    Users are 802.11 de-associated from the network all day long. This happens to me when I just sit in my office without moving. I then move to a different location or wait 5-10 mins and it reconnects. Why? Isn't the whole point of being connected is to stay connected? Why would the system boot me off. Before you say maybe there are too many clients, this happens in my office where I might have as many as 3 people connected to the same AP. TAC had also asked me to add a second AP to a location to see if this might help alleviate this issue. It did not.
    TAC took some PCAPS from Clearpass to look at the Timeouts we are experiencing there. That was on Friday so I haven't heard anything back on that. I hope something can be found there.
    I am open to looking at every aspect of this configuration to see what might be wrong. I didn't program the switches, or APs alone. I worked with HPE engineers and HPE certified technicians to design and build this. I am hoping I can find someone who can help with this but it is becoming harder and harder to do so. It's almost as if this entire system was designed to fail. As of right now it is too cost-prohibitive to look at another network company, but that might be the next step.
  • 29.  RE: Aruba Central Controllerless Environment Is Not Working
    Posted 15 days ago
    It looks like we fixed it!
    I connected with user mflowers above and his suggestions which included:
    • Downgrade to 10.4.1.1
    • Change the VLAN assignment rules
    • Reinstall RADIUS Cert on Clearpass
    appear to have fixed the issue. I had looked at some of these issues with TAC and they said everything looked good. I'm glad that we have a community like this where multiple heads can come together to look down an issue.
    Thanks!
  • 30.  RE: Aruba Central Controllerless Environment Is Not Working
    Posted 14 days ago
    I am glad that it worked out for you and shared the outcome here. since then firmware 10.5.1.1 was released.
    However the release notes did not mention "AOS-247757", so i don't know that bug ID goes by a different ID number or was the culprit in your scenario.
