Cloud Managed Networks
Aruba Central Firmware Upgrade Issue
This thread has been viewed 59 times
  • 1.  Aruba Central Firmware Upgrade Issue
    Posted May 30, 2023 09:33 AM
    Hello Community
    I am having a issue when I try to upgrade my APs in Aruba Central. Ive added the URL that the APs are trying to reach to the firewall. I was able to ping the URL IPs from the AP itself as well. I was able to do a traceroute to each IP address that the URL points to which I got from doing a nslookup of the URL. But when I try to download the firmware via Central I get this error when I do a sh log upgrade on the VC.
    ----------Download log start----------
    Executing ('/usr/sbin/wget -T 120 -t 3 -M 29712384 --no-proxy  --proxy-passwd=****** --header=X-Ap-Info:(serial number removed by me),(mac address removed by me),AP-515 -a /tmp/download_url_log --no-check-certificate https://common.cloud.hpe.com/ccssvc/ccs-system-firmware-registry/IAP/ArubaInstant_Draco_8.10.0.6_86193')
    fetching ('/usr/sbin/wget -T 120 -t 3 -M 29712384 --no-proxy  --proxy-passwd=****** --header=X-Ap-Info:(serial number removed by me),(mac address removed by me),AP-515 -a /tmp/download_url_log --no-check-certificate https://common.cloud.hpe.com/ccssvc/ccs-system-firmware-registry/IAP/ArubaInstant_Draco_8.10.0.6_86193')
    --11:42:00--  https://common.cloud.hpe.com/ccssvc/ccs-system-firmware-registry/IAP/ArubaInstant_Draco_8.10.0.6_86193
               => `ArubaInstant_Draco_8.10.0.6_86193'
    Resolving common.cloud.hpe.com... failed: Name or service not known.
    Error: failed to retrieve image
    cleaning up
    done
    ----------Download log end------------
    Download status: incomplete
    ----------Upgrade log start----------
    upgrade log not available
    ----------Upgrade log end------------
    Upgrade status: upgrade status not available
    Has anyone run into this issue before?
    Also im aware i can remove the AP subscription and upgrade the APs then add the subscription back, but i would rather be able to run upgrades via Aruba Central.
    Thanks in advance.
    Mr. MKP
    Network Administrator
  • 2.  RE: Aruba Central Firmware Upgrade Issue
    Posted May 30, 2023 08:58 PM
    have you enabled HTTP as well as HTTPS for the IAPs to download the firmware?
  • 3.  RE: Aruba Central Firmware Upgrade Issue
    Posted May 31, 2023 08:10 AM
    ill check HTTP. I know HTTPS is enabled.
    Mr. MKP
  • 4.  RE: Aruba Central Firmware Upgrade Issue
    Posted May 31, 2023 03:58 AM
    It is important to follow the Documentation on "Opening Firewall Ports for Device Communication" - https://www.arubanetworks.com/techdocs/central/latest/content/nms/device-mgmt/communication_ports.htm
    Did you followed the guidlines, depending on the location of your Central Account?
    As already mentioned by @ariyap it is important to open HTTP and HTTPS
  • 5.  RE: Aruba Central Firmware Upgrade Issue
    Posted May 31, 2023 08:13 AM
    yes, i have these documents and they have been followed. but these documents do not always have complete information. for instance we had an issue were ther APs stopped reporting to Central and we had to add 8.8.8.8 DNS to the firewall rule and all the APs started reporting again. The only way we noticed this was by watching packets.
    Mr. MKP
  • 6.  RE: Aruba Central Firmware Upgrade Issue
    Posted May 31, 2023 10:24 AM
    These documents have all information included. When I get you right it worked after you placed Google DNS additionally. Which is logic because your internal DNS Server does not know Internet URLs.
    That´s why you get the "Resolving common.cloud.hpe.com... failed: Name or service not known." message. Every Device which has to access the Internet should be able to use a public DNS Server.
  • 7.  RE: Aruba Central Firmware Upgrade Issue
    Posted May 31, 2023 10:32 AM
    no, the google dns was for a different issue we had which was the APs showing offline in Central. After we added googles dns the APs then began to show online in Central. Googles dns did not fix the firmware failure issue. We are still trying to fix that.
    Mr. MKP
  • 8.  RE: Aruba Central Firmware Upgrade Issue
    Posted May 31, 2023 10:37 AM
    Can you ping "common.cloud.hpe.com" from the AP?
  • 9.  RE: Aruba Central Firmware Upgrade Issue
    Posted May 31, 2023 10:48 AM
    if i do a nslookup of the URL and get the IP addresses, then yes i can ping it. but if i just try to ping the URL then no. What ive done is ping the URL from my pc to see what IP address responds and then ping that IP from the AP and it also responds.
    Mr. MKP
  • 10.  RE: Aruba Central Firmware Upgrade Issue
    Posted May 31, 2023 11:08 AM
    So if you cannot ping the URL, than your DNS is not working correctly.
    Please do a
    show summary support
    This gives you the DNS Server used. Section "NameServer"
  • 11.  RE: Aruba Central Firmware Upgrade Issue
    Posted May 31, 2023 11:18 AM
    thats set to 0.0.0.0 as i was letting DHCP assign the DNS for the AP. ill set it to the current DNS for the network its on and see if that makes a difference
    Mr. MKP
  • 12.  RE: Aruba Central Firmware Upgrade Issue
    Posted May 31, 2023 11:28 AM
    after adding a static DNS, yes i can ping the URL from the AP...
    Update
    This may have fixed the issue. Coming from Aruba AirWave i usually let DHCP assign the DNS address. Guess i will need to do this now since its talking to the cloud. thanks.
    Mr. MKP
  • 13.  RE: Aruba Central Firmware Upgrade Issue
    Posted Jun 27, 2023 08:19 AM
    DNS assignment via DHCP is supposed to work for Aruba APs. Never had to statically assign the DNS server.
    If it does for you, check your DHCP server if you really are sending the DHCP server and in the right attribute.
  • 14.  RE: Aruba Central Firmware Upgrade Issue
    Posted 28 days ago
    This helped me with my issue. Thank you for such a simple solution. We lost our DNS server to a flood and the new one had a different IP address. Changing the DNS address fixed my problem instantly.
