Cloud Managed Networks
Aruba Central gateway connection
This thread has been viewed 63 times
  • 1.  Aruba Central gateway connection
    Posted Nov 02, 2023 06:08 PM
    Hi All
    I am testing to add aruba 7005 running 8.6.0.8 to central.
    I have made a basic IP config on a test vlan that was connectivity to central.
    I tested with a switch and it goes smootlhy to central
    the controller does not connects to central
    I have no dhcp so the connectivity is static IP. tested and controller can ping the "internet"
    Already check aruba central and device is there under device preprovisioning
    Message in audit is "Failed to initiate Upgrade. Device is not connected to Central"
    What is needed on the controller side for him to get to activate and to central?
    Regards
  • 2.  RE: Aruba Central gateway connection
    Posted Nov 03, 2023 12:00 PM
    Controllers in Aruba Central are only supported in SD-Branch mode or in AOS-10 mode.
    I'm not sure if ArubaOS 8.6 has the code to connect to central. From the controller CLI you could check 'show aruba-central' to see if it is connecting/connected; and if the command is not available you may need to upgrade first. Also, make sure that DNS is working, you could test if 'ping device.arubanetworks.com' works...
    Once the controller is connected to Central, you should upgrade to AOS-10 (or a legacy SD-Branch code version).
  • 3.  RE: Aruba Central gateway connection
    Posted Nov 03, 2023 12:30 PM
    Hi Herman
    thanks for the help
    I chech this video from John, where the controller is on 8.6.
    I am only checking this because in a near future I will have the need to migrate a existing MM and MC running 8.6 to Central.
    Thats why I am testing with this 7005.
    To get all the troubleshooting done ;)
    It seems to be ok with Central since it shows enable:
  • 4.  RE: Aruba Central gateway connection
    Posted Nov 06, 2023 04:21 AM
    Unsure if this resolved your initial question... the screenshot just shows that it's configured. With 'show aruba-central details' you can see if the connection to Central is actually up and connected.
  • 5.  RE: Aruba Central gateway connection
    Posted Nov 06, 2023 05:22 AM
    Hi Herman
    In the first time i run the command "show aruba-central " it does not had the aruba central server.  I added manually..
    In fact the controller is under central, but is not upgrading. Not sure is this kind of tests need to have aruba controller under AOS10.
    I was expecting for the upgrade to go to AOS10, but maybe is not auto...
    Guess I am missing something here
  • 6.  RE: Aruba Central gateway connection
    Posted Nov 07, 2023 08:55 AM
    was this Gateway configured under a Mobility Conductor?
    If so you have to delete a file because the Gateway tries to use the last Config saved if anything went wrong. You cann check that by:
    - factory reset the gateway and enable debug to see the output.
    If you see than messages like:
    10:35:01 LOG: Mandatory upgrade information available [8.6.0.4-2.2.0.7_80444]
    10:35:01 LOG: Controller is not fresh from factory, ignoring mandatory upgrade request
    10:35:01 LOG: Received mode as MD, central as device-eucentral3.central.arubanetworks.com
    you have to delete the old config file with
    #delete filename /flash/ .upgrade
    and after that a
    #write erase all
  • 7.  RE: Aruba Central gateway connection
    Posted Nov 07, 2023 12:54 PM
    Hi
    do not know. ITs a testing controller
    I upgraded to AOS10 and problem is the same. So maybe that is the case old MM config
    I will do what you say and came back.
    for now the error is :
  • 8.  RE: Aruba Central gateway connection
    Posted Apr 22, 2024 11:56 AM
    Did you ever have a resolution.  Debugging is not really providing enough on my end for error. I see it that the websocket is showing its writeable although shortly after it states the client bails.
  • 9.  RE: Aruba Central gateway connection
    Posted Apr 23, 2024 12:00 PM
    Hi
    it solved because it was a problem on the vlan on client side. traffic beeing blocked on a FW internal
