Wired Intelligent Edge
Aruba CX 6200 vs 2930F
This thread has been viewed 92 times
  • 1.  Aruba CX 6200 vs 2930F
    Posted Jul 01, 2020 12:30 AM
    I am just trying to understand the different between Aruba CX 6200 vs 2930F, both of them are layer 3 and can be managed by Central, so which one to go for? How about the price difference?
    Aamir
  • 2.  RE: Aruba CX 6200 vs 2930F
    Posted Jul 01, 2020 01:42 AM
    Hi xshant,
    They are a similar model switch as far as speeds and feeds go. It would be fair to consider the migrating to the 6200F if you were trying to match the 2930F.
    The Aruba CX range of switches has an entirely new Operating System - it's built as a micro-services platform with central database which means more resilient software. Of course this OS is built to leverage the new capabilities of the new Gen7 Aruba ASIC such Virtual Output Queueing (VOQ) to allow full line rate at output ports.
    The 6200F range is likely to come at a slightly higher cost as it does have overall improved capability with features like the Network Analytics Engine (NAE) and NetEdit, that will suit you if you are looking at using automation.
    The 2930F is a great switch. The 6200F is newer and more advanced.
  • 3.  RE: Aruba CX 6200 vs 2930F
    Posted Jul 01, 2020 07:36 PM
    As of today, there are plenty of features missing on the 6200 compared to 2930F. Depends on what you need.
    Some examples:
    - Can't use secondary downloadable roles on 6200; only static roles at the controller
    - IP client tracking does not exist on 6200
    - Device fingerprinting (and forwarding to ClearPass) does not exist on 6200
    - CDP receive does not support all version; no CDP send
    I also saw some critical and not so critical bugs. Like loops, ghost error counters, stack members stuck on boot, dhcp snooping not working, NetEdit failing validations, NetEdit not completing firmware update...
    Fortunately they will be used for a refresh and not a new installation. Otherwise, I would not have a network.
    If I needed something to work today, and work well, I would go with 2930F.
  • 4.  RE: Aruba CX 6200 vs 2930F
    Posted Jul 01, 2020 10:09 PM
    Ricardo, you will be happy to know that IP Client Tracker is coming to 6x00 CX switches with 10.5! I'm checking on secondary role for you.
  • 5.  RE: Aruba CX 6200 vs 2930F
    Posted Jul 06, 2020 03:49 PM
    Cloud-native microservices architecture with APIs and whatnot sure sounds nice but it's other question what does it really do for you or for your customer?
    Currently, I don't honestly know. Even though we bought 6300F switches. Hopefully within their lifetime there will be something extra regarding AI or something. But as all the intelligence seems to be going towards Central it is interesting to see if CX switches have anything more to offer compared to 2930F.
    Only thing I can think of for the future is if we decide to switch from MPLS in our campus network to EVPN, that is of course not supported by 2930F.
  • 6.  RE: Aruba CX 6200 vs 2930F
    Posted Jul 06, 2020 03:56 PM
    Also last Github updates for NAE scripts are 8 months ago. So I'm wondering if they are being developed or do we have to just wait Central? And of course managing NAE scripts is quite manual work?
  • 7.  RE: Aruba CX 6200 vs 2930F
    Posted Jul 06, 2020 05:21 PM
    Other than SFP56 and perpetual UPOE, I can't see today any (real world) advantage of 6200/6300F to the older Aruba switches.
    I can do more with a 2930F than with CX (access use case), and it is way more stable.
    Ok, I can't use Netedit with 2930F, but it lacks so many stuff (no ranges; no way to use tacacs or ldap to access it) I don't use it anyway. On the flip side, Airwave support for CX is very basic that it doesn't even show the clients that are connected.
    Than NAE. You can't manage NAE centrally. Say you have multiple switches. You have to go to each switch to configure NAE and check the graphs or errors. And even tho you can see something is wrong with your switch within NetEdit, you must be able to access the management interface to see the details.
    Monitoring support from other vendors is also non existent. Say you use Nagios or PRTG. No support for CX. You have to code it youself.
  • 8.  RE: Aruba CX 6200 vs 2930F
    Posted Jul 06, 2020 05:25 PM
    I tried NetEdit, but at least version 2.0.3 wasn't realy usable. While editing, NetEdit might suddenly just remove one or two configs after of before what I was editing. And ctrl+z didn't help so you had to start over. If you're supposed to edit your whole network at once with that, I really wouldn't trust it.
    Seems 2.0.5 is the newest version not sure if they have fixed this already.
    One semi-positive thing with 6300F is that you can mix 6300M to the same stack to get dual PSUs. Though the price difference is so much that you can just do two stacks if you need dual PSUs. Dual PSUs have not been a strong point for Aruba, 2930M and 6300M are so much more expensive than F series.
  • 9.  RE: Aruba CX 6200 vs 2930F
    Posted Jul 06, 2020 05:28 PM
    2.0.5 is the same. Copy-paste and editing stuff doesn't always work fine.
    There are also some frequent "validation" errors that prevent you from applying configs.
    Aruba also seems to be following Cisco's example, and more and more features will require a "subscription" and will only be available from the Cloud (see AOS 10). Even Central On-Premises will be "software as as service" subscription only. NetEdit is subscription only as well.
    CX at datacenter or core is cool tho. That's 6400, 8300, 8400. VSX, VXLAN, VOQ, Multi-Tb backplane, options for up to 100G. Way better than the old 5400zl.
  • 10.  RE: Aruba CX 6200 vs 2930F
    Posted Jul 07, 2020 06:19 AM
  • 11.  RE: Aruba CX 6200 vs 2930F
    Posted Jul 07, 2020 06:50 AM
    This:
    https://community.arubanetworks.com/aruba/attachments/aruba/CampusSwitching/3714/2/ArubaOS-Switch_16-06_Device-Fingerprinting_v2018-01.pdf
    Non existent with CX. If you want to capture user-agent you have to span the traffic. If you want to gather dhcp, you have to set up helpers on all your sites. Also can't get LLDP or CDP info into Clearpass.
    With old 2930F, the switch will capture the first http packet, the dhcp info, lldp and cdp and forward it to ClearPass. It will then also receive the device type from ClearPass.
  • 12.  RE: Aruba CX 6200 vs 2930F
    Posted May 07, 2021 02:40 AM
    Also, ArubaCX 6200F doesn't  support Policy base routing, ECMP,  OpenFlow and PIM
    Dinusha Chandrasinghe - MVP | ACMP | ACSP |ACCA
    Network Engineer
    Plexus Global (Pvt) Ltd
    Colombo Sri Lanka
    +94717327420
  • 13.  RE: Aruba CX 6200 vs 2930F
    Posted 17 days ago
    I'm not sure where Dinusha above referenced his information, but the statement that the CX 6200 doesn't support Policy-based routing, ECMP, OpenFlow, or PIM is incorrect.  Please see the table at chrome-extension://efaidnbmnnnibpcajpcglclefindmkaj/https://networkingdojo.com.au/wp-content/uploads/2016/11/HPE-Provision-ArubaOS-Switch-Software-Feature-Support-Matrix-Nov-2016.pdf which shows that the CX 6200 switches support all of the above.
  • 14.  RE: Aruba CX 6200 vs 2930F
    Posted 16 days ago
    So, to clarify, the document you are referencing does not refer to the CX 6200 switch, it refers to the 6200yl (running AOS-S, not AOS-CX) so isn't relevant to this discussion.  The CX 6200 does support some of those features today, but did not when the post was written.  You can see the feature navigator (https://feature-navigator.arubanetworks.com/) to see what release various features became available in if they are supported.
  • 15.  RE: Aruba CX 6200 vs 2930F
    MVP EXPERT
    Posted 16 days ago
    This topic is retired!
    Marcel Koedijk | MVP Expert 2024 | ACEP | ACMP | ACCP | ACDP | Ekahau ECSE | Not an HPE Employee | Opinions are my own
