Wired Intelligent Edge
Aruba-CX 6200F - Remote mirror
This thread has been viewed 23 times
  • 1.  Aruba-CX 6200F - Remote mirror
    Posted Mar 13, 2024 05:29 AM
    Hi
    Yesterday I was out at a customer site helping them with various things. They asked me, since I was there,  to setup a remote mirror session between two 6200F switches.
    Source was SW1 interface 1/1/20 and destination was SW2 and 1/1/20 using remote mirror functionality.
    I couldn't get that working. I checked the the Aruba doc "AOS-CX 10.11 Monitoring guide, 6200 switch series". The example in there is not very good. My assumption first was that the mirror configuration creates the tunnel but since that didn't work I was then trying to set up a GRE tunnel between the switches according to "AOS-CX 10.11 IP Services Guide, 6200 switch series". This didn't work either. The example showed in the doc, "switch(config)# interface tunnel 33 mode gre ipv4" failed. I then just tried "interface ?" and "tunnel" wasn't even an optional command?
    I then tried setting up a VLAN between the switches with an IP-address on the SVI interface on both switches in the same subnet, e.g sw1: vlan interface 999 ip address 192.168.1.1/24 and sw2: vlan interface 999 ip address 192.168.1.2/24" but this didn't work either.
    Am I missing the obvious here how to set up a GRE tunnel on the 6200F switches and setting up a remote mirror between two Aruba-CX 6200F? Can someone help out and give a working example for this?
    Many thanks in advance.
    Torro
  • 2.  RE: Aruba-CX 6200F - Remote mirror
    Posted Mar 14, 2024 03:03 AM
    Hi, I don't believe you need to setup a GRE tunnel in the config in order to send the captured packets. The mirror session commands take care of everything you should need. It depends on what you are trying to achieve but I assume the end goal is to use wireshark on a PC to inspect packets?
    If so, follow the instructions here which gives a good example. Note no GRE commands needed.
    If you mean that the customer needs raw traffic to exit out of an interface on a remote switch, then this functionality (often called remote span) isn't available natively on CX. You would need to develop something like the first switch doing the "destination tunnel" part and the second switch decapsulating GRE somehow to reveal the raw data. In the majority of use cases the goal is to send traffic to a monitoring station which should in the majority of cases be able to handle receiving the packets inside a GRE tunnel.
  • 3.  RE: Aruba-CX 6200F - Remote mirror
    Posted Mar 14, 2024 05:00 AM
    Many thanks
    I will try again the next time I'm onsite, following the example you provided.
    Torro
  • 4.  RE: Aruba-CX 6200F - Remote mirror
    Posted Mar 15, 2024 09:08 AM
    Not sure how applicable it would be here but I have moved all my captures to capturing locally on the switch and then pulling the pcap with TFTP.
    https://support.hpe.com/hpesc/public/docDisplay?docLocale=en_US&docId=sf000095988en_us&page=index.html
  • 5.  RE: Aruba-CX 6200F - Remote mirror
    Posted Mar 18, 2024 10:31 AM
    Hi
    In this case the customer wants real time traffic sent to a monitor station doing analysis on the network traffic
    Torro
  • 6.  RE: Aruba-CX 6200F - Remote mirror
    Posted Mar 18, 2024 10:29 AM
    Hi IanNightingale
    Below is what I tested now that also worked.
    Sw1:
    interface vlan 999
       ip address 192.168.99.1/24
    mirror session 4
        destination tunnel 192.168.99.2 source 192.168.99.1 vrf default
        source interface 1/1/20 both
        enable
    Sw2:
    interface vlan 999
        ip address 192.168.99.2/24
    mirror endpoint from_sw01
        source 192.168.99.1 destination 192.168.99.2 id 4
        destination interface 1/1/20
        no shutdown
    Torro
