Wired Intelligent Edge
Aruba-CX not using configured hostname in DHCP request
This thread has been viewed 79 times
  • 1.  Aruba-CX not using configured hostname in DHCP request
    Posted Jul 08, 2023 03:31 AM
    We are using Aruba-CX switches (relatively new firmware, 10.11) and have the mgmt interface set to do DHCP.
    This works fine but we get an issue because on the DHCP server we also do dynamic DNS registration. And there it seems the Aruba-CX switch sends its "default" hostname myhost-xx-xx-xx-xx and not the one configured and shown on the prompt when you log in.
    Anyone encountered this also? Any possible solution on the Aruba-CX side without changing to fixed IP or such?
  • 2.  RE: Aruba-CX not using configured hostname in DHCP request
    Posted Sep 26, 2023 10:49 AM
    I have a similar problem on aruba CX 6000 (without mgmt interface). Even by configuring hostname, it's never send to the dhcp server.
    We have some aruba 2530M and no problem for this model.
  • 3.  RE: Aruba-CX not using configured hostname in DHCP request
    Posted Sep 26, 2023 11:13 AM
    Hello all,
    dont' know about Aruba-CX, but on the Aruba-OS switches (ie the 29xx series) this is possible with the following command:
    (config)# dhcp host-name-option
    It is in the global config scope, so I suppose it will be used for every DHCP request that the switch starts.
    Hope the Aruba-CX have something similar.
    GG
  • 4.  RE: Aruba-CX not using configured hostname in DHCP request
    Posted Sep 26, 2023 02:53 PM
    Thanks for sharing @ilGino
    That command doesn't seem available on Aruba CX (yet).
  • 5.  RE: Aruba-CX not using configured hostname in DHCP request
    Posted Oct 01, 2023 11:57 AM
    We got answer back from Aruba support via our partner.
    Correct it isn't there, expected in Aruba CX 10.13.
  • 6.  RE: Aruba-CX not using configured hostname in DHCP request
    Posted Apr 26, 2024 11:20 AM
    We are using Aruba-CX switches with v10.09.1010 firmware versión.
    We have tried to configure a DHCP-Server in the switch that assign the IP address to the Clients and update our DDNS Server but We don't get it.
    The DHCP-Server of the switch assign the IP addresss to the Clients but it doesn't send anythink to our DDNS.
    Our configuratión of the DHCP Server is that:
    Aruba-6200#
    interface 1/1/7
        no shutdown
        ip address 192.168.55.10/24
    dhcp-server vrf default
        pool Pool-UNO
            range 192.168.55.125 192.168.55.150 prefix-len 24
            option 81 ip 192.168.55.15
            domain-name example.org.in
            dns-server 192.168.55.15
            default-router 192.168.55.10
            static-bind ip 192.168.55.155 mac fa:ba:da:fa:ba:da
            lease 00:10:00
            exit
    enable
    Aruba-6200#
    Would you tell us if we are missing any command?
    Regards
  • 7.  RE: Aruba-CX not using configured hostname in DHCP request
    Aruba-6200#
    interface 1/1/7
        no shutdown
        pool Pool-UNO
            lease 00:10:00
            exit
    enable
    Aruba-6200#
    Regards
  • 8.  RE: Aruba-CX not using configured hostname in DHCP request
    Posted Apr 27, 2024 02:48 AM
    It was introduced in AOS-CX Version 10.13.
    CX-6000(config)# ip dhcp option host-name
  • 9.  RE: Aruba-CX not using configured hostname in DHCP request
    Posted Apr 29, 2024 04:48 AM
    Holger, thanks by your answer but I think that this command not exist in ArubaOS-CX 10.13.1000.
    Aruba-6200# show version
    ArubaOS-CX
    (c) Copyright Hewlett Packard Enterprise Development LP
    Version      : Virtual.10.13.1000
    Build Date   :
    Build ID     : ArubaOS-CX:Virtual.10.13.1000:7720573f9b1b:202401292046
    Aruba-6200(config)# ip ?
      aspath-list             BGP autonomous system path filter
      community-list          Add a community-list entry
      dns                     Enable/disable DNS client
      ecmp                    Configure ECMP
      extcommunity-list       Add an extended community list entry
      icmp                    Configure Internet Control Message Protocol (ICMP)
      igmp                    IGMP Configurations
      multicast               Multicast configurations
      multicast-static-route  Configure multicast static route
      prefix-list             Prepare a prefix list
      route                   Configure static routes
      source-interface        Source-interface configuration
      tcp                     Global TCP parameters.
      udp-bcast-forward       Enable or disable UDP broadcast forwarding
    Any other idea?
  • 10.  RE: Aruba-CX not using configured hostname in DHCP request
    Posted Apr 29, 2024 05:14 AM
    The command "ip dhcp option host-name" is available since AOS-CX version 10.13.0005 as per documentation on the following AOS-CX platforms:
    4100i, 6000, 6100, 6200, 6300, 6400
    See also:
    https://www.arubanetworks.com/techdocs/AOS-CX/AOSCX-CLI-Bank/cli_6000-6100/Content/Chp_DHCP/DHCP_cli_cmds/ip-dhc-broadcast.htm
    I personally verified that on 6100 and 6300 switches with AOS-CX versions 10.13.0005 and 10.13.1010
    You are using the virtual switch from the OVA instead.
    In addition, AOS-CX version 10.9 is a Short Support Release (SSR) which is already End of Maintenance (EOM) and End of Support (EOST). Therefore is is highly recommended to update to a release which is still under maintenance. As AOS-CX 10.13 is a Long Supported Release (LSR) it is a good choise.
  • 11.  RE: Aruba-CX not using configured hostname in DHCP request
    Posted Apr 29, 2024 07:03 AM
    Our 6200 running CX version 10.13.1000 for sure supports it.
    It seems you are running a CX simulator right? in which case it may not be supported.
  • 12.  RE: Aruba-CX not using configured hostname in DHCP request
    Posted Apr 30, 2024 03:04 AM
    Holger, then, the Virtual Switch and the Physical Switch with the same AOS-CX Version not have the same commands?
    @ariyap, do you have configured the DHCP-Server in your switch and it update the DDNS with the IP's and Names of the DHCP Clients?
    And works fine?
    Regards.
  • 13.  RE: Aruba-CX not using configured hostname in DHCP request
    Posted Apr 30, 2024 03:11 AM
    note that CX virtual switch does not support all the command that a physical switch support.
    You can ask your AOS-CX Switch Simulator questions in this discussion forum
  • 14.  RE: Aruba-CX not using configured hostname in DHCP request
    Posted Apr 30, 2024 03:23 AM
    I have installed a physical switch 6200F with AOS-CX 10.09.1010 but for tests I have installed two virtual switch with AOS-CX 10.09.1000 and AOS-CX 10.13.1000 versions. I did not know that the Viertual and Physical didn't have the same commands.
    And works fine?
    Regards.
  • 15.  RE: Aruba-CX not using configured hostname in DHCP request
    Posted Apr 30, 2024 04:15 AM
    I have DHCP server configured but its for internal devices, not using DDNS.
  • 16.  RE: Aruba-CX not using configured hostname in DHCP request
    Posted Apr 30, 2024 04:57 AM
    Hi @ariyap,
    Well, We have DHCP Server for internal devices too but also I have configured a internal Dynamic DNS that accept the updates from our DHCP Servers.
    In other locations we have configured the DHCP Server in switches CISCO and they update our Dynamic DNS when the DHCP Server assigns an IP to the DHCP Client but with this Aruba switch don't works.
    Regards.
