Cloud Managed Networks
ARUBA CX Switch + Dante Audinate Configuration
This thread has been viewed 38 times
  • 1.  ARUBA CX Switch + Dante Audinate Configuration
    Posted Apr 09, 2024 05:39 AM
    I have been having issues discovering Dante devices in the Dante Controller software.
    Our network consists of a CX 6200 Stack and CX 6100 edge switches.
    L3 routing happens on the 6200 stack with a seperate vlan dedicated to the Dante network.  Dante devices get IP addresses and ping request work to them both on that vlan and others.
    I have been through and done the Multicast setup's ( hopefully correctly) and can see multicast groups being established on that vlan.
    When directly connected to a switch with a Dante box on the same vlan, Dante Controller can discover that device, but no others on the network.
    Any thoughts on where I could be going wrong? is the mdns-sd blocking the discover? any example configurations?
    Thank you in advanced.
  • 2.  RE: ARUBA CX Switch + Dante Audinate Configuration
    Posted Apr 09, 2024 08:22 PM
    whats the the switch config for it? have you enabled IGMP snooping ?
  • 3.  RE: ARUBA CX Switch + Dante Audinate Configuration
    Posted Apr 10, 2024 09:31 PM
    Hi Aruyap thank you for getting back.
    Code snippets of the IGMP Configurations,
    Switch 1 ( querier )
    vlan 40
        name security
        ip igmp snooping enable
    interface 1/1/48
        description Dante System
        no shutdown
        vlan trunk native 40
        vlan trunk allowed all
        ip igmp snooping fastleave vlan 40
    interface vlan 40
        ip address 10.113.132.2/24
        ip igmp enable
        ip igmp version 2
        ip igmp querier interval 5
        ip igmp robustness 5
        ip igmp last-member-query-interval 2
        ip igmp query-max-response-time 50
        ip igmp static-group 239.254.3.3
        ip igmp static-group 239.255.255.255
    //Outputs
    IGMP group information for group 239.254.3.3
    Interface Name   : vlan40
    VRF Name         : default
    Group Address    : 239.254.3.3
    Last Reporter    :
                                  V1        V2        Sources   Sources
    Vers Mode Uptime    Expires   Timer     Timer     Forwarded Blocked
    IGMP group information for group 239.255.255.255
    VRF Name         : default
    Group Address    : 239.255.255.255
    Last Reporter    : 10.113.132.15
    2         2h 29m    0m 35s
    Switch 2
    vlan 40
        name security
        ip igmp snooping version 2
    interface 1/1/18
        no shutdown
        ip igmp snooping forward vlan 40
    interface vlan 40
        ip igmp enable
        ip igmp version 2
        no ip igmp querier
  • 4.  RE: ARUBA CX Switch + Dante Audinate Configuration
    Posted Apr 10, 2024 09:03 AM
    Dante does not go trough routing so to use DC (dante controller) you need to be in same L2 network with dante gear.
    Dante's 224.0.0.230-234 multicasts and audio packets TTL is 1 so it will not go through router. Dante Domain Manager changes game but it is bit expensive to have only routed streams.
    Jori Luoto
    AV-IT Specialist
  • 5.  RE: ARUBA CX Switch + Dante Audinate Configuration
    Posted Apr 10, 2024 10:10 PM
    Hi Jori,
    Thank you for responding, All devices are on the same vlan. I can see multicast traffic on the 224.0.0.230-234 ranges.  After running some packet captures I found that MDNS traffic was being blocked even on the same vlan.
    I tried adding the services to our mdns-service allows but it still didn't work.
    Services added
        id _netaudio-arc._udp.local
        id _netaudio-cmc._udp.local
    After disabling mdns-sd globally Dante Controller can now see the devices but only in Device Info | Clock Status | Network Status when you try to expand a devices config it can't pull any information :/
    In the Wireshark pictures 10.113.132.15 is the controller .10 .11 .12 are the Dante boxes.
  • 6.  RE: ARUBA CX Switch + Dante Audinate Configuration
    Posted Apr 11, 2024 12:33 AM
    Good Morning,
    Sorry, while you talked about routing in core I thought you are trying to have separate device network.
    Just to be clear your topolgy is normal star topology and igmp querier is in core? (=6200 stack is core and 6100's connecting to 6200 stack and Switch 1 mentioned in previous messages is 6200 stack)
    In dante perspective, mDNS distributes names and capabilities for other devices so that one should should run freely in whole vid40.
    Thing I noted from Wireshark capture is that it's missing PTP clocking streams (224.0.1.129) Should have several high priority packets in second...
    Also if you network is large, please do proper QoS configurations there too (PTP clocking to second highest prio and audio to 3rd...)
    This goes off topic but from your osx try to switch off firewall and all other network connections than dante connection and try again...
    If you see devices in Device info but device info/networking/clocking tabs is mostly empty it usually means that you dont get 224.0.0.230-234 streams to dante controller.
    Jori Luoto
    AV-IT Specialist
