Aruba IAP 93
  • 1.  Aruba IAP 93
    Posted Apr 01, 2024 02:10 AM
    Name:Aruba Operating System Software
    Type: 93
    Version: 6.4.2.6-4.1.3.7_71499
    The IAP93 is having few issues with the following version
    I tried with the following images
    ArubaInstant_Orion_6.4.4.8-4.2.4
    But during the upgrade, I received an "Invalid Image File" error
    New files were downloaded from the ASP and I am receiving the same error
    Any idea?
  • 2.  RE: Aruba IAP 93
    Posted Apr 01, 2024 06:21 PM
    see if you find anything in the release notes about upgrade path
  • 3.  RE: Aruba IAP 93
    Posted Apr 02, 2024 10:43 AM
    The IAP-93 appears to have been parked on IAP 4.1, not supported in 4.2.
    Carson Hulcher, ACEX#110
  • 4.  RE: Aruba IAP 93
    Posted Apr 04, 2024 02:48 AM
    Thanks for the information
    Is there any way to download the 4.0 or 4.1?
    It is not available in ASP
  • 5.  RE: Aruba IAP 93
    Posted Apr 04, 2024 03:51 AM
    It is, but as it's old you may need some filters to get to it.
