Aruba Instant Validated Reference/Design/Deployment Guide
This thread has been viewed 116 times
  • 1.  Aruba Instant Validated Reference/Design/Deployment Guide
    Posted Dec 02, 2022 08:45 AM
    Hi all,
    I have a project that consists of deploying 100+ Aruba 515 Access Point across a building. All of the access points are going to be deployed in Instant mode using virtual controllers.
    Would anybody please share a design or deployment guide for Aruba Instant.
    Thanks in Advance
    Yadel B.
  • 2.  RE: Aruba Instant Validated Reference/Design/Deployment Guide
    Posted Dec 02, 2022 09:53 AM
    Here is the Aruba Instant VRD v2.0.
  • 3.  RE: Aruba Instant Validated Reference/Design/Deployment Guide
    Posted Dec 09, 2022 04:38 AM
    Hi Herman,
    Thank you for the resource. I will go through it
    Is there any updates to that VRD. It is dated at 2018. The Web Gui is changed now.
  • 4.  RE: Aruba Instant Validated Reference/Design/Deployment Guide
    Posted Dec 13, 2022 05:37 AM
    I think that while the options may have moved in the UI or look different, the concepts are the same.
  • 5.  RE: Aruba Instant Validated Reference/Design/Deployment Guide
    Posted Dec 15, 2022 02:00 AM
    Okay, Thank you
  • 6.  RE: Aruba Instant Validated Reference/Design/Deployment Guide
    Posted Nov 27, 2023 08:06 AM
    I tried the link here, but it just brings me to a "Blog entry" that is empty, and says "No comments"... it appears the blog entry was removed.  (I see this with a lot of links, for some reason).
    Could you post a link to this file again?  Thank you!
    ryh
  • 7.  RE: Aruba Instant Validated Reference/Design/Deployment Guide
    Posted Dec 04, 2023 10:50 AM
    This is the current page for many VRD documents:
    https://www.arubanetworks.com/resources/technical-guidance/
    The Instant VRD 2.0 is attached.
    Shawn Adams
    Attachment(s)
    pdf
    Instant VRD 2.0.pdf   6.95 MB 1 version
