last person joined: 8 hours ago
Aruba MM dashboard data not visible
  • 1.  Aruba MM dashboard data not visible
    Posted Apr 18, 2024 10:24 AM
    Hello, I am using ArubaMM-VA, version 8.7.1.1. I upgraded to version 8.10.0.10. Afterwards, data started not appearing on my Dashboard screen. I reinstalled the old version, 8.7.1.1, but the problem continued in this version as well. As seen in the attached picture, 2 MDs are working smoothly and the data is coming, but I cannot see it on my Dashboard screen.
    Thanks for your help.
  • 2.  RE: Aruba MM dashboard data not visible
    Posted Apr 18, 2024 11:49 AM
    Did you upgrade the controllers as well?
    Carson Hulcher, ACEX#110
  • 3.  RE: Aruba MM dashboard data not visible
    Posted Apr 18, 2024 01:33 PM
    It may help to clear your browser cache, or retry in a Private/Incognito browser window.
  • 4.  RE: Aruba MM dashboard data not visible
    MVP
    Posted Apr 19, 2024 06:48 AM
    The same thing happened to me last Summer while upgrading from 8.7 to 8.10. There's a known bug that TAC was able to resolve. I don't have the case in front of me as this issue was on the side of a more significant issue I had when going to 8.10.
    Contact TAC and they will fix it for you.
