I've tried 3. Thanks in advance for any advice.
1- PARAMIKO:
This one output this message in to the "output.txt" file:
Command: show version
SSH command execution is not supported.
import paramiko
import os
def main():
target_ip = '10.10.10.10'
username = 'root'
password = input("Enter your SSH password: ")
ssh = paramiko.SSHClient()
ssh.set_missing_host_key_policy(paramiko.AutoAddPolicy())
try:
ssh.connect(target_ip, username=username, password=password)
print("Connected to the target device.")
output_directory = os.path.join(os.path.dirname(os.path.abspath(__file__)), "output")
os.makedirs(output_directory, exist_ok=True)
while True:
user_input = input("Enter a command or press Enter to exit: ")
if not user_input:
break
stdin, stdout, stderr = ssh.exec_command(user_input)
output = stdout.read().decode("utf-8")
output_file_path = os.path.join(output_directory, "output.txt")
with open(output_file_path, "a") as file:
file.write(f"Command: {user_input}\n")
file.write(output)
file.write("\n" + "="*30 + "\n")
print(f"Output saved to {output_file_path}")
except paramiko.AuthenticationException:
print("NOT AUTHORIZED")
except paramiko.SSHException as e:
print(f"SSH error: {e}")
except KeyboardInterrupt:
print("Session terminated by user.")
finally:
ssh.close()
if __name__ == "__main__":
main()
2- NETMIKO+PARAMIKO:
The error message:
File "C:\Users\...\Python311\Lib\site-packages\netmiko\base_connection.py", line 721, in read_until_pattern
raise ReadTimeout(msg)
netmiko.exceptions.ReadTimeout:
Pattern not detected: 'Show\\ version' in output.
Things you might try to fix this:
1. Adjust the regex pattern to better identify the terminating string. Note, in
many situations the pattern is automatically based on the network device's prompt.
2. Increase the read_timeout to a larger value.
You can also look at the Netmiko session_log or debug log for more information."
import paramiko
from netmiko import ConnectHandler
import os
from paramiko.ssh_exception import SSHException
def main():
username = 'root'
device = {
'device_type': 'autodetect',
'ip': target_ip,
'username': username,
'password': password,
'secret': '', # Enable secret, if needed
'verbose': False,
'global_delay_factor': 3, # Adjust this value as needed
try:
with ConnectHandler(**device) as ssh:
ssh.remote_conn_pre.timeout = 200 # Set the timeout here
while True:
user_input = input(r"Enter a command or press Enter to exit: ")
if not user_input:
break
try:
output = ssh.send_command(user_input)
file.write(output)
except SSHException as e:
main()
Original Message:
Sent: Jul 04, 2022 03:43 AM
Subject: Aruba Python automation
there is a difference between an interactive session from Putty and just command execution with SSH. The Switches need an interactive session. With Python just try to use netmiko (https://github.com/ktbyers/netmiko).
hth
Alex
Original Message:
Sent: Jul 01, 2022 10:12 AM
I'm new to this forum, also new to Aruba.
I'm trying to automate SSH into Aruba switches, but when I run my Python code, I'm getting this.
"SSH command execution is not supported."
When I SSH from Putty, there's no problem, but for some reason the switch doesn't like SSH from Python
