Network Management
Aruba switches can't login using AD admin credentails
  • 1.  Aruba switches can't login using AD admin credentails
    Posted 14 days ago
    I use my domain admin account to login to Aruba 2930F switches.  We also have a Manager account for backup.  We also have Duo MFA.
    So when I login using my domain AD credentials, it asks for Duo prompt, and it logs me in.
    But I'm not able to login using my AD credentials now for some reason.  I can only login using the local Manager account.  Its not a Duo issue because other Duo services are working.
    No configuration changes were made on the switches.  How can I troubleshoot this?
  • 2.  RE: Aruba switches can't login using AD admin credentails
    Posted 14 days ago
    We did change our domain suffix from .local to .com so we can use Azure AD.  But even if I change my domain account suffix to .local, it won't work.
  • 3.  RE: Aruba switches can't login using AD admin credentails
    Posted 13 days ago
    I opened a ticket with Duo, and looking at the logs, Duo is allowing the login, but it looks like the IP of the switch also accepts, but is on a loop.
    Any ideas?
  • 4.  RE: Aruba switches can't login using AD admin credentails
    Posted 13 days ago
    This is the log from Duo Proxy showing the connections
    10.0.0.3 is an Aruba 2930F
    2024-05-15T14:19:11-0400 [duoauthproxy.lib.log#info] Got response for id 68 from ('10.0.0.15', 1812); code 11
    2024-05-15T14:19:11-0400 [duoauthproxy.lib.log#info] (('10.0.0.3', 1812), Useradmin, 142): Returning response code 11: AccessChallenge
    2024-05-15T14:19:11-0400 [duoauthproxy.lib.log#info] (('10.0.0.3', 1812), Useradmin, 142): Sending response
    2024-05-15T14:19:11-0400 [duoauthproxy.lib.log#info] Packet dump - sent to 10.0.0.3:
    2024-05-15T14:19:11-0400 [duoauthproxy.lib.log#info] b'\x0b\x8e\x066\xee:9S\xac\x99\xf3\xa4eR\r\xfc\x1c\xa3_\x95\x1b\x06\x00\x00\x00\x1eO\xff\x01\x03\x05\xd8\x19@\xeah\xec\x14\xb6\x8f\xc3\xd9\x8f\xd2N\xdb]\xf2\xc1t\x0e\x11qwT\xd1\xed\xd5#\xf5\x9b4\xd2q0\xd8\x13\x9a\x18\xdb\xe2d\x8f,\x86@\x10!\x97Y9\xecB\xe8"\xfa\xed\x81R\xa8\xb4v\xa4\xee\xc3\xfd@\xeaE\xebS=\x14\x0b\xf6*\x9f\x12q\x17u\xd1\xa9\xa2\xd4E?=^\xbeX[\x13JqDwA\xed\xf0\x83\xfa\xdbi\xd9\xc0\xa2\x96\x854\xd8\x8f\xa6d\x84l`] }/o\xbb\xb9\xc4+L!\xbc\x0c\xd2\xe2\x07\x85\xbbQZ>\x03(\xad\x98\xaa\x06\xf4\xde\x12\x92\x04T\x8b1z\xe2\xd7,\x83\xbe\xe7\xca\x00\xa1\xb6\xf0\x1a\xac\x16\x14\x9f\xad\xbd5\xa34\xc8\xb6iEg\xda\x87\xc8\x1a\xef\xee\xc2<\x1b\x8e\x8d\xc2\xf5\xf4\xf5A\xbdD[\xe9\x1f/\xde\xdc;\xfc\xf5wNT\xeeT\x15\xfc\xa2z\xb4\x94\xe8\x89G\x00\x04\x8e0\x82\x04\x8a0\x82\x03r\xa0\x03\x02\x01\x02\x02\x10}MB\xa9+C\x1d~dS\xe7\xc1\x9aO\xff\x8dXw0\r\x06\t*\x86H\x86\xf7\r\x01\x01\x0b\x05\x000W1\x0b0\t\x06\x03U\x04\x06\x13\x02BE1\x190\x17\x06\x03U\x04\n\x13\x10GlobalSign nv-sa1\x100\x0e\x06\x03U\x04\x0b\x13\x07Root CA1\x1b0\x19\x06\x03U\x04\x03\x13\x12GlobalSign Root CA0\x1e\x17\r221012034943Z\x17\r271012000000Z0L1\x0b0\t\x06\x03U\x04\x06\x13\x02BE1\x190\x17\x06\x03U\x04\n\x13\x10GlobalSign nv-sa1"0 \x06\x03U\x04\x03\x13\x19AlphaSSL CA - SHA256 - G40\x82\x01"0\r\x06\t*\x86H\x86\xf7\r\x01\x01\x01\x05\x00\x03\x82\x01\x0f\x000\x82\x01\n\x02\x82\x01\x01\x00\xad$)O\xff\x95f\x15\x88?3\x87\x03x\xcf\xd5\x0c$\xb81S\xf3\xff\x83"l\x99\x95+|\xe5JY\xc2\xae\xc6\xd1*\x9d\xfa\x7f .Q\xc8g*P\x91\xa7yVD\xfb8\xb5>0\x8e\xfc\x94.\xcbW\x0ciS_D\xc6V\x96/\xae\xc07%\x86\xf1q\xf1\xdc\x02EB\x86a\xb86\xefQ\xe3sE\x0c\x90\xb3\xa5\xd2\xe7\x03z\xb89E\xd0\x17\xf5\x02\xd0\x94Aj\xc6\x18\xb1\x98\xc3 \xb5\xc5:\xf3\x82\xb1J\xa4D\xac!s*\x92U\x06N\xc8|\x8b\xb0\xcaf\x14TU\xf8+<\xb2T\x91\xb6\xcbR\xb2\xd8\xe3o\x8aD(\xb0}+\xc1\x96\x80\xb9>\x00\xd8\x9e=\xe81\x9dZM\xed\xd6~M\xe5\xd4\x8e\x03\xdd\x12\x9a\'\x83\xd4\xd6\xa1\xd7\x84rN\x81\xed\x9b\x8cb\x06\x97\xa3,h\x13~\x04\x1d\xac\xaf\xa1\'\xc5}1\x9c\xc2\x1b{\r\xa8!\xf3\x85\xa0\xba\xac\xe3\xbb\xe1\xfca\xf8$\xdd*\xaa]\x96\x04w\xc3=P\xe6\xdd\xbf\x86C\x16:7\xf2\xd7O\xff\x02\x03\x01\x00\x01\xa3\x82\x01[0\x82\x01W0\x0e\x06\x03U\x1d\x0f\x01\x01\xff\x04\x04\x03\x02\x01\x860\x1d\x06\x03U\x1d%\x04\x160\x14\x06\x08+\x06\x01\x05\x05\x07\x03\x01\x06\x08+\x06\x01\x05\x05\x07\x03\x020\x12\x06\x03U\x1d\x13\x01\x01\xff\x04\x080\x06\x01\x01\xff\x02\x01\x000\x1d\x06\x03U\x1d\x0e\x04\x16\x04\x14O\xcb\xac\xa8\xc2\xef\xab\xdd\x83ok\xbf\xce\x98=\\X%v\x150\x1f\x06\x03U\x1d#\x04\x180\x16\x80\x14`{f\x1aE\r\x97\xca\x89P/}\x04\xcd4\xa8\xff\xfc\xfdK0z\x06\x08+\x06\x01\x05\x05\x07\x01\x01\x04n0l0-\x06\x08+\x06\x01\x05\x05\x070\x01\x86!http://ocsp.globalsign.com/rootr10;\x06\x08+\x06\x01\x05\x05\x070\x02\x86/http://secure.globalsign.com/cacO\xffert/root-r1.crt03\x06\x03U\x1d\x1f\x04,0*0(\xa0&\xa0$\x86"http://crl.globalsign.com/root.crl0!\x06\x03U\x1d \x04\x1a0\x180\x08\x06\x06g\x81\x0c\x01\x02\x010\x0c\x06\n+\x06\x01\x04\x01\xa02\n\x01\x030\r\x06\t*\x86H\x86\xf7\r\x01\x01\x0b\x05\x00\x03\x82\x01\x01\x00\x1a%\xf6sd\x88@\xa9Y\x07\xa7C\xba\x15?Qa\xbd\x15\xff-d\xdd\xcdz]2j\x7fHB\xe7\x10\x98h9\xef\xb7\xeb\xa14v\xdf-Xh>{0\x1c\x0c\xf7\x86`\xf9\xa9\xf3y\xc0T\xb7\x83\xa68\xbb6\xab\xbc\x95\xd0|\xf8o\xc1\xe9OF\x07\xc8\xb6\x0c2\x00\xa9+\x05\x12\xf7\x0cmf\xf9\x81\x9d\xbf\x0edMr\'\xc6\x8b\xd1J\x02\xe1n\xdb\x0c\x9f\xb7\x8b8\x0c|3/`\x89\xdb8\xcc\x95C\x8c\xdd\x16\x84\xd5\xccO\xe9n:\xcf\x8e\x9b\xa3\x02\x0f\xd1\xbb\xbey\x00\xb5(\x82\xfc\xe3\x9f\x1c\xeft\xd9\xfe2#f\xb8\xf0\xaf\xa0)\xa0\x1f\xdeR\x12\x15x\xdd\xdfjpCmK\xa4\xcd\xeex\x81\xb2u\xa2~\xd7\xfc\xfc\x9e\xff\x82\xed%\x13\xe5\xb1\xe8\xcf\xb7\x18Sn\xcbR\xf8u\x9fe\x926p\xba\xfd\x0c\x05J\x83\xfa\x80\xd2\x9a\xe0\xf3\x8e\xfe\x83\xb5\xdf\x18\xe1\xac\xb4G\'\xfd8p\xa3\x1bD\x02\xed%d$=\xa7\t\xf1"U\x84\x1d\x91\xec\x12\x0c\x00\x01I\x03\x00\x17A\x04\xe6w\xfb\x99c\x0c\xb5\x18w\xcc\x1b\x1c\xc6\xa1\xbd\xefSAu\xf1\x9c\\7G\xd6Z\xd2\x080\xc2K\xa89E\xc0)Gyl\x19<\x94\x1e\xce\x9fe\xd3~\xd9\xb7\xff\xael\x844\xd2\xf4\xec\xa7\xb2[\xbe\xd3/\x04\x01\x01\x00;Q\x1a\xa2U\x96\xf1\xb2cyH]\xd9\xfc\xe4\xab\xcd!\xe9\x19\r\xff\xcf\xa9.9(\xaf\x18&`o\x08%\x00\x00\x017\x00\x01\x17\x00\xfe\x80\x00\x00\x00\x00\x00\x004c\xac\xc5\x8c\x82.T\x00\x00\x00\x04\x9b\xbd\xc0\xa2P\x12*\x9d\xa0O\xd8\x90F\x1aZ\x8d\xd9\xde\xbctM\xf3'
    2024-05-15T14:19:11-0400 [duoauthproxy.lib.log#info] Packet dump - received from 10.0.0.3:
    2024-05-15T14:19:11-0400 [duoauthproxy.lib.log#info] b'\x01\x8f\x00\x9cj\xcc\xaf\xf3"v\xd2\xcc\x92\x0c\xcb\x02\x9c\x1f\xcf\x80\x01\x0fUseradmin\x04\x06\n\x00\x00\x03 \x0fRidge-Core-48=\x06\x00\x00\x00\x05\x06\x06\x00\x00\x00\x07\x18&`o\x08%\x00\x00\x017\x00\x01\x17\x00\xfe\x80\x00\x00\x00\x00\x00\x004c\xac\xc5\x8c\x82.T\x00\x00\x00\x04\x9b\xbd\xc0\xa2O\x08\x02\x03\x00\x06\x19\x00P\x12\x8a\x83/\xb6\xe7\x98\xf3\xec\x81\xf7\xa7\x9el\x81\xe5\xaf\x1a\x0c\x00\x00\x017\t\x06\x0b\x00\x00\x00\x1f\x0c10.0.0.166'
    2024-05-15T14:19:11-0400 [duoauthproxy.lib.log#info] Sending request from 10.0.0.3 to radius_server_auto
    2024-05-15T14:19:11-0400 [duoauthproxy.lib.log#info] Received new request id 143 from ('10.0.0.3', 1812)
    2024-05-15T14:19:11-0400 [duoauthproxy.lib.log#info] (('10.0.0.3', 1812), Useradmin, 143): Valid response to challenge issued at id 142
    2024-05-15T14:19:11-0400 [duoauthproxy.lib.log#info] Sending proxied request for id 143 to ('10.0.0.15', 1812) with id 244
    2024-05-15T14:19:11-0400 [duoauthproxy.lib.log#info] Packet dump - sent to 10.0.0.15:
    2024-05-15T14:19:11-0400 [duoauthproxy.lib.log#info] b'\x01\xf4\x00\x9cj\xcc\xaf\xf3"v\xd2\xcc\x92\x0c\xcb\x02\x9c\x1f\xcf\x80\x01\x0fUseradmin\x04\x06\n\x00\x00\x03 \x0fRidge-Core-48=\x06\x00\x00\x00\x05\x06\x06\x00\x00\x00\x07\x18&`o\x08%\x00\x00\x017\x00\x01\x17\x00\xfe\x80\x00\x00\x00\x00\x00\x004c\xac\xc5\x8c\x82.T\x00\x00\x00\x04\x9b\xbd\xc0\xa2O\x08\x02\x03\x00\x06\x19\x00P\x12k\x7f\xcc\x90\xcf\x94D\xd6D\x93H\x7f]To\xe6\x1a\x0c\x00\x00\x017\t\x06\x0b\x00\x00\x00\x1f\x0c10.0.0.166'
    2024-05-15T14:19:11-0400 [duoauthproxy.lib.log#info] Packet dump - received from 10.0.0.15:
    2024-05-15T14:19:11-0400 [duoauthproxy.lib.log#info] b'\x0b\xf4\x01b{\x1dx\x06\xbd\xba\xed\x90\xed"\x95h\x0f{\x95y\x1b\x06\x00\x00\x00\x1eO\xff\x01\x04\x01\x0c\x19\x00\xd0\xd3e\xd0\x89C\x92\xfa>Fi\xe4\xf7D\xa7\x97>bF~t\xcf\x8c\xc4\x14\x82\xfc\xd5L\xebUzG\x9f\x90!\x9e\rE\x86\xd1\x97\xf2HGJ\xca\x80:\xd9\x94A\x87\x96\xbc\x8e!\x082pM\xbb\xec\xeb\xa0 g\x97\x81\xae\xf1?\x9d\xea\xde\xdc\xe7\x1bVN\xa4f\xb7zsS\xa7\xf1\x11:\xc1\xfa-\x93F\xcc\xa5\xa6ZYXk\xeag\x0c4\x14I\xfd9[\xbc\x110\xb0\x1e\xad\x1b~\xd8U(\xd87\x0er\xf88M2\x0f\x98\x7fh/}\xf9\xd0\x9dy2.\x9d}\xf7\xdd\xa4\xff\xf0\x04&\xd4b\xe7\xe9QH)j\x19\x90]\x0c\x9d\x13\x0c\xb7\xc1\xe24b\x81a\xf1\x16\xdfQW\xc9\xccNer1\x8eK\x14\x9a\x0b\xe3\xa9\xd8Gm\xf7-\x85\xaa\xf1g\xad\xf1\xc7}\xc5FP\xe0\xfc\xd0\x0f\xab\x92q\x91\x9c\x84e\xfb\x89\xf1\xa6\xf1\xec\x04\x96\xb7\xa8\r\x00\x00\x1a\x03\x01\x02@\x00\x12\x04\x01\x05\x01\x02\x01\x04\x03\x05O\x11\x03\x02\x03\x02\x02\x06\x01\x06\x03\x00\x00\x0e\x00\x00\x00\x18&`o\x08%\x00\x00\x017\x00\x01\x17\x00\xfe\x80\x00\x00\x00\x00\x00\x004c\xac\xc5\x8c\x82.T\x00\x00\x00\x04\x9b\xbd\xc0\xa2P\x12\xedI\x0fD\x1ef\x0c\x87\xe1\xee\x9exF\xda:\x9d'
  • 5.  RE: Aruba switches can't login using AD admin credentails
    Posted 13 days ago
    The account I use to login to switches is still in the previous .local format, so I'm confused why that's not working now.  Do I need to make any change in the switch config?
  • 6.  RE: Aruba switches can't login using AD admin credentails
    Posted 12 days ago
    Any recommendations?
  • 7.  RE: Aruba switches can't login using AD admin credentails
    Posted 15 hours ago
    What is your switch configuration?
    Do you only have the Duo as authentication server? Radius?
    Which server is expected to handle the AD authentication?
    Does your RADIUS server return the IETF Service-Type = 6 (Administrative User) attribute?
    This may be easier to resolve with your partner/support to have an interactive session and live-troubleshoot.
