Aruba upgrade causes Miracast projection failures
This thread has been viewed 321 times
  • 1.  Aruba upgrade causes Miracast projection failures
    Posted Feb 28, 2022 12:56 AM
    We have a TAC open, but it's been 3 weeks and I wanted to put this out here - any direction would be much appreciated!
    We are a public school district which has been using Aruba since 2016. We had 200-series APs in a controller environment and upgraded over the holidays this winter to 500-series APs using Aruba Central. In every classroom in the district, we have miracast devices (Microsoft wireless display adapters) which allow our teachers to project wirelessly from their Windows 10 laptops to their projectors. Miracast, as I understand it, using the wireless NIC and both 2.4 & 5GHz, but is a point-to-point connection: https://www.wi-fi.org/discover-wi-fi/miracast .
    Symptoms: as soon as we press Windows K to scan for devices to connect to, the laptop's network slows to a crawl (ping -t response times shoot up; speedtests fall to under 1M). Essentially, teachers cannot project.
    Laptops: we have multiple models of Dell 5310 & Lenovo windows 10 laptops showing the problem, all using Intel AX201 160Mhz NICs. We've updated drivers and operating systems. Test laptops do work fine in other school buildings.
    Location: only occurring in one school building out of 8. Problems are throughout the building, but seem to be concentrated on higher floors (whether that is related to the height, a physical aspect of the floors, the switches, or VC's, I don't know). This is the only building which is tall. It is also close to the hospital and state emergency communications towers (we are in the capitol city); there is a small airport and an Army national guard base about 2 miles away.
    Another district in another area of the country is having the same problem, and also has Aruba equipment. I know this because an engineer from Screenbeam responded to a thread I posted on another forum and gathered data for us to help troubleshoot his client's problem; you can see our session in this video .
    Theories so far: DRC interference; seen as rogue device; switch configuration in this building.
    Pam McLeod
    CTO/CISO
    Concord (NH) School District
  • 2.  RE: Aruba upgrade causes Miracast projection failures
    MVP GURU
    Posted Feb 28, 2022 07:32 AM
    Can you share the output for your configured radio/wlan settings? Virtual AP profile, SSID profile, radio-profile, and ap-group setting?
    Dustin Burns
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022
  • 3.  RE: Aruba upgrade causes Miracast projection failures
    MVP GURU
    Posted Feb 28, 2022 07:36 AM
    Also, as another check, have you tested with High Efficiency (802.11ax) turned off? Some clients have issues on 802.11ax WLANs.
    Dustin Burns
  • 4.  RE: Aruba upgrade causes Miracast projection failures
    Posted Mar 04, 2022 03:12 PM
    This problem was resolved today - it was a bug in version 8.7.1.3_79817 . There was a known issue around "latency" - not quite the same description, but apparently it was the issue. We upgraded firmware to 8.7.1.7 and it resolved today.
    Pam McLeod, CAGS/CETL
    CTO/CISO
    Concord School District
    Concord, New Hampshire
    pmcleod@sau8.org
  • 5.  RE: Aruba upgrade causes Miracast projection failures
    Posted May 09, 2022 10:49 PM
    Is Screenbeam still working ok for you?  We purchased a Screenbeam 1100 for our organization.  I configured and tested it at home in a Cisco LAN environment with Meraki AP's, and it worked flawlessly.  I took it into the building expecting the same, as the Cisco LAN is the same, but with Aruba AP's, and it worked one time on the Internal network, and never on the guest network.  It then stopped worked completely.  I took it back home, and again it works great.
    On the Aruba Instant AP network, I tried the following:
    • Turned on AirGroup with Enable Bonjour, Guest Bonjour multicast, allowall, but it still didn't work
    • On the guest network, I set Broadcast filtering to Disabled, and Deny inter user bridging to off, but it still didn't work
    We are using Aruba AP 535's on 8.8.0.2.  The user clients and Screenbeam devices are in the same vlan.
    Any ideas?
    The network requirements from the manufacturer are:
    Multicast DNS (mDNS) support is required for iOS and macOS native screen mirroring
    to auto-discover ScreenBeam
    Required ports
    5353 (UDP) for Multicast DNS (mDNS) discovery
    7100 (TCP and UDP) for macOS, iOS and Windows 10 mirroring
    7250 (TCP) for Miracast over LAN data stream
    47000 (TCP) for Airtunes in AirPlay
    18000-18009 (TCP) for macOS and iOS AV data
    Christopher
  • 6.  RE: Aruba upgrade causes Miracast projection failures
    Posted Dec 07, 2023 11:20 AM
    have you found a solution to this problem? We have Aruba 505 APs with 8.11. firmware which are working fine but as soon as someone connects to a screen via miracast the internet becomes unusable.
  • 7.  RE: Aruba upgrade causes Miracast projection failures
    Posted Dec 07, 2023 09:38 PM
    Can you share which client and driver version, and which device you're mirroring via Miracast to?
    Josh
  • 8.  RE: Aruba upgrade causes Miracast projection failures
    Posted Dec 11, 2023 06:32 AM
    thank you for your reply. We mostly use Surface tablets but same thing happens when we connect with Asus or HP laptops. It doesn´t matter whether we connect to the Airserver via Miracast or to a Microsoft Miracast Adapter, as soon as a laptop connects with Miracast the internet becomes very slows. it only happens in the building ehere we have the Aruba 505 APs. In the other buildings where we have Ubiquiti APs, the internet via WiFi works normally.
  • 9.  RE: Aruba upgrade causes Miracast projection failures
    Posted Feb 28, 2024 09:07 AM
    Hey guys,
    thanks for your help so far. We turned off the channels, as adviced above, we turned off High throughput and tried other methods suggested here but with no outcome. Wifi still down when connected via miracast. I don´t know whether the new firmware version 10 would help, as it´s a cloud based firmware and that´s not allowed at our school so we had to roll back to 8. Funny thing is that when I´m alone in the room I got around 10.000 Bits (out of 150.00 when not connected) which would be fine for working, but as soon as some students come into the room and connect to our wifi, the rate drops to 400 Bits. Don´t know what else to do.
  • 10.  RE: Aruba upgrade causes Miracast projection failures
    Posted Feb 29, 2024 03:25 AM
    Does setting no multiple-tx-replay-counters help at all?
  • 11.  RE: Aruba upgrade causes Miracast projection failures
    Posted Dec 11, 2023 11:57 AM
    Right here with you. Upgrade to AP-505's mostly (all we have installed so far, as we have stopped until this is resolved) upon making a Miracast connection, speeds tank. There is no disconnect, just slow and you can see the throughput drop while watching Resource Monitor. You disconnect Miracast (Wi-Fi Direct Connection), never touching wlan connection and things take right off. We are running firmware 10.5.0.1_88128 on all of AP's. You are running 8..., I am convinced this is some setting within Aruba Central or on-premise controller that has to be turned on/off and not related to firmware or even Aruab OS version. I do have a TAC open and have a meeting in about about an hour and will report back if something is found (I am using Aruba Central to manage AP's, no Gateway just Aruba AP's back to older HP Switches).
  • 12.  RE: Aruba upgrade causes Miracast projection failures
    Posted Dec 11, 2023 12:04 PM
    Awesome, thanks for your info, I'll be waiting for your news :)
  • 13.  RE: Aruba upgrade causes Miracast projection failures
    Posted Dec 15, 2023 07:33 AM
    No help so far working with Aruba engineer. The connection speed between client device and AP is solid, has been, which is all he was looking at when running commands in terminal against an AP. It's the throughout that tanks after the connection to Miracast display is made that he wasn't even addressing before our meeting was over.  I will be reconnecting.
    Does the creation of an "AirGroup" come into play here? I am looking at this now just because some things line up, mDNS traffic being the biggie. I do wonder if packets are sent, hit AP and are ignored because it doesn't know what to do with them and there is a bunch of wasted communication which bogs down the radio.  https://www.arubanetworks.com/techdocs/central/2.5.7/content/nms/apps/airgroup/airgroup.htm
  • 14.  RE: Aruba upgrade causes Miracast projection failures
    Posted Dec 20, 2023 10:48 AM
    It took some time on me comparing old to new controller but I think I have the answer to this issue and explains why 2.4Ghz works and only 5Ghz is the issue. No thanks to Aruba Engineer... I have users testing now to confirm but the more I read and understand, I do believe this is the answer: DFS Channels need to be turned-off/disabled on the 5Ghz radio to play nice with Miracast. So only Channels 36,40,44,48,149,153,157,161 are ON and the rest OFF 52-140 that are considered DFS Channels (144 is default off, if not turn off too). This is controlled in the Radio Profile in Aruba Central. You could have a different Radio profile applied to each group in Aruba Central but I just have it set to my default radio profile (one and only for us).
    Caveat; in deployments with a large number of clients, this limits available wireless channels. But as you will see from links below Miracast devices do not understand DFS channels and performance is affected. We do not have enough clients to say so, as even our old system kept up just fine (802.11n) as the DFS channels are off. Pushing 500-600 clients, over 90+ APs, max 30-clients on an AP (depending on where clients were in the building and proximity to an AP) along with Cell phones etc... on Guest network.
    I will post to confirm all is well (hopefully) as week goes on but really encouraged by what is being seen.
    UPDATE: I can say with confidence, this is the answer. I confirmed and verified a night and day difference for clients.
    Scroll down to the section titled: "Troubleshoot connection performance" and read about DFS channels. https://learn.microsoft.com/en-us/surface-hub/miracast-troubleshooting
    More info: https://wifinc.net/dfs-channels-and-why-to-avoid-them-even-though-you-say-you-cannot
    I understand this better now because of above WIFINC.net article (and we use Actiontec's too):
  • 15.  RE: Aruba upgrade causes Miracast projection failures
    Posted Dec 25, 2023 08:58 AM
    Hey,
    I wish you a merry Christmas and thanks a lot for posting your progress. I was sick and not able to try it out and definitely will do next year. But I also have the issues with 2.4 GHz. The students' access runs on 2,4 the teachers'' on 5 GHz and as soon as I connected to miracast, the internet slowed down on both accesses.
  • 16.  RE: Aruba upgrade causes Miracast projection failures
    Posted Jan 04, 2024 10:02 AM
    With the way Miracast operates and it really hating DFS channels, I am convinced this is it. I think 2.4Ghz just doesn't offer enough bandwidth for newer radios and then you add on trying to run a Miracast session at the same time and latency kicks in. Though it should play nice with 2.4Ghz, I think to much surrounding traffic and nature of "streaming" being bandwidth hungry, just adds to it. Also I do not think that the Miracat protocol is all that efficient in how it operates.
    Staff have been teaching/testing sense before break and now after and all issues related to speed have gone away. It is worth trying...
    Also other settings that were tweaked by Aruba support in the hope of fixing this, I turned back off, so maybe you had already played with these and want to turn off as well:
    Under the the WLAN name (each has settings of its own), I turned off:
    Multicast Transmission Optimization and Dynamic Multicast Optimization (DMO)
  • 17.  RE: Aruba upgrade causes Miracast projection failures
    MVP
    Posted Jan 04, 2024 05:21 PM
    Fighting this issue in my district as well. I have schools running 315s and others running 515s, the issue seems isolated to the 515s. We've been running 8.10.0.6 code just fine, and staff could screencast without issue while also having stable internet connetion. After upgrading to 8.10.0.9, once you screencast the wireless connection goes to trash and is very intermittent (slow to laggy internet browsing, dropped pings, etc). As soon as you disconnect from screen sharing, the issues go away. After downgrading schools back to 8.10.0.6, no more complaints from staff. Trying to get a case opened now.
  • 18.  RE: Aruba upgrade causes Miracast projection failures
    Posted Jan 23, 2024 10:56 AM
    We had a similar issue with our Aruba 515 APs after upgrading to 8.11 as well, and was able to resolve it by disabling the High throughput option on the IAP.
    Configuration > Networks > Edit network > Basics tab > Show advanced options > High throughput: off
    Hope this solution works for some of you as well!
  • 19.  RE: Aruba upgrade causes Miracast projection failures
    Posted Mar 05, 2024 01:12 PM
    I have also been having this issue.  I opened a TAC case a month or so ago and have been back and forth with Aruba since.  I have sent over lots of logs from differnet devices and software applications as per their request and they have come back and said they beleive they have found the issue and are working to resolve it.
    Heres hoping to a new version of the firmware being released soon!
  • 20.  RE: Aruba upgrade causes Miracast projection failures
    Posted Mar 05, 2024 01:29 PM
    I look forward to your reply because the more we install, the majority of our deployment is complete, despite my effort in turning off the DFS channels we seem to be seeing hiccups now with performance again. Not to the piss-poor level pervious to me turning off DFS channels but not anywhere near the smoothness we saw using Miracast with AP 105's (802.11n).
    We should not be having to tell people to use a "cable" to connect to their screens when for previous 8 years, there was no need.
  • 21.  RE: Aruba upgrade causes Miracast projection failures
    Posted Mar 06, 2024 08:35 AM
    Has anyone experimented with limiting 5Ghz to using 20Mhz and 40Mhz channel widths (turning off 80Mhz and 160Mhz (if his this is even on)) to see if this frees up client device to broadcast to both Wifi and Miracast screen?
    As you see from my previous post, I left 80Mhz on, could that be an issue?
  • 22.  RE: Aruba upgrade causes Miracast projection failures
    Posted Mar 06, 2024 09:45 AM
    Yes, we blocked the DFS channels as DCS Technology - K-12 Edu suggested in anwser number 14. but unfortunately it didn´t help.
  • 23.  RE: Aruba upgrade causes Miracast projection failures
    Posted Mar 06, 2024 10:38 AM
    Yes,  you did turn-off 80Mhz? Was this before or after making the change related to DFS channels?
    For us, making the DFS channel change has made a big difference (from completely unusable to working) BUT things in general do seem slower than before with older AP's.
    Now in our Elementary, where it is a lot more "movie time" than I think it ought to be, we have the new AP's installed. Things are working to a point but more hiccups related to performance seem to be happening, loading of websites and playing content when using Miracast at the same time. If you disconnect from Miracast screen, performance on the device itself picks up just fine.
    Most of our fleet, where Miracast is being used have "Intel Wi-Fi 6 AX201 160Mhz" network adapters with Win 10 or 11 (does not make a difference which OS, performance issues persist) running Intel Driver 22.250.1.2 and Intel Bluetooth 22.250.0.2.
  • 24.  RE: Aruba upgrade causes Miracast projection failures
    Posted Mar 08, 2024 02:53 AM
    DFS Channels were turned off from the beginning, after that we tried other channels, as well as everything sugested in this thread, but what helped others unfortunately didn´t work for our school. Did you play around with the channels?
    I´m really counting on DSapseid here and hoping for a new firmware soon. I´ve heard that both firmware versions 8 and ten are still being supported. Is that right? As we aren´t allowed to use the 10 version because of the cloud yet.
  • 25.  RE: Aruba upgrade causes Miracast projection failures
    Posted Mar 06, 2024 11:32 AM
    Hi @DSapseid, what issue did you report?
  • 26.  RE: Aruba upgrade causes Miracast projection failures
    Posted Mar 07, 2024 03:05 AM
    I have 515APs and when not doing miracast broadband speed tests show 300mb, when on miracast it drops to 2mb.  Tested other model of AP (315) on same version and fine.  Also 515s at a site with older firmware, again fine.  So the issue appears to be the 500 series APs on 8.10.6+ firmware version as previously mentioned above.
    It was requested I send over the below which I did
    • Tech support logs from the individual AP before and after starting a miracast transmission
    • iPerf logs for the laptop contacting a desktop computer.
    • OTA captures from an apple device for the wifi channel in use whilst trying to miracast
    All the logs sent over and they have identified the issue:
  • 27.  RE: Aruba upgrade causes Miracast projection failures
    Posted Mar 11, 2024 11:26 AM
    Following on from this, we had the same issues on AP-505s on the 8.11 Gemini Firmware when trying to Connect to a wireless display from various different windows laptops whilst connected to the APs. Connection speed drops and the frame rate on the TV is really poor and disconnects. Connecting via a Mobile phone Hotspot and it works fine.
    I have upgraded to the 8.12 Firmware and will be testing later today.
  • 28.  RE: Aruba upgrade causes Miracast projection failures
    Posted Mar 11, 2024 02:43 PM
    Please, looking forward to answers. We are running cloud (10.5...) but it is an issue for both on-prem and cloud, particularly 500 series AP it seems.
  • 29.  RE: Aruba upgrade causes Miracast projection failures
    Posted Mar 21, 2024 11:08 AM
    Any update ConnorH? It is a bigger issue here than I realized and people are doing work arounds that I wish they did not have to do. Thanks.
  • 30.  RE: Aruba upgrade causes Miracast projection failures
    Posted Mar 28, 2024 11:38 AM
    Agreed. I'd like to hear an update.
    We're experiencing this issue as well. Speeds slow to a crawl when using MiraCast. We're even on Version 10.4.X, Mix of 515 and 305 APs, managed by Aruba Central.
    Haven't implemented anything they've recommended in this thread, since it seems like nothing has really actually been a 'true fix'.
  • 31.  RE: Aruba upgrade causes Miracast projection failures
    Posted Mar 28, 2024 11:45 AM
    No improvement on 8.12. Guess we will have to wait for an update from Aruba on this.
  • 32.  RE: Aruba upgrade causes Miracast projection failures
    Posted Mar 28, 2024 01:19 PM
    I see firmware 10.6.X.X was released, in the Release Notes under Resolved Issues saw this;
    Clients experienced audio failure during multicast for group communication when roaming between APs within the same gateway cluster (Device Designated Gateway). This issue occurred due to incorrect internal device information stored on the AP. This issue was observed in AP-515 access points running ArubaOS 10.5.0.1 or later versions. The fix ensures proper device information updates during roaming, preventing audio failure.
    Not the same thing but intriguing.
    I have not installed the firmware but thought about giving it a shot. I am not totally sure what a "Device Designated Gateway" is either.
  • 33.  RE: Aruba upgrade causes Miracast projection failures
    Posted Mar 28, 2024 01:31 PM
    AOS-250572 which you've pasted in the description for fixes a multicast roaming issue. I don't think it will fix this Miracast issue. Does anyone on this thread have an AOS bug ID associated with their TAC cases?
    Device Designated Gateway (DDG) is to AOS 10 as AP Anchor Controller (AAC) is to AOS 8 https://www.arubanetworks.com/techdocs/central/2.5.7/content/aos10x/cfg/gw-clust-tun-orch/gw-cl-architct.htm.
  • 34.  RE: Aruba upgrade causes Miracast projection failures
    Posted Mar 28, 2024 02:26 PM
    No AOS bug ID was associated with my TAC, I just PM'd you the info on the case I had opened (and shortly closed).
  • 35.  RE: Aruba upgrade causes Miracast projection failures
    Posted Apr 02, 2024 09:56 AM
    Yes I have a AOS Bug ID.  AOS-252437
    Ive spent 2 hours with Aruba support today trying workarounds to the current firmware with no luck.  They are still working on the updated firmware with the fix it it.  It is currently being tested in the labs apparently.
  • 36.  RE: Aruba upgrade causes Miracast projection failures
    Posted Apr 02, 2024 10:31 AM
    DSapseid, which AP model and firmware were you testing today?
  • 37.  RE: Aruba upgrade causes Miracast projection failures
    Posted Apr 02, 2024 10:34 AM
    515 APs with firmware 8.11.2.2
  • 38.  RE: Aruba upgrade causes Miracast projection failures
    Posted Apr 02, 2024 11:21 AM
    Your bug ID and this Miracast issue appears to be linked to AOS-251742 which engineering is working on patching the various supported releases. Already patched in upcoming 10.5.1.1. Patches for 10.6, 10.4, 8.10, 8.12 are currently pending.
    Just an FYI for everyone running AOS 8.11 in this thread, 8.11 is no longer receiving patches, you'll need to either downgrade to 8.10 or upgrade to 8.12 for any fixes once available.
  • 39.  RE: Aruba upgrade causes Miracast projection failures
    Posted Apr 09, 2024 07:59 AM
    Thank you! Any idea on when 10.5.1.1 will be released?
    I assume the issue will be documented in the Release Notes, as to what was the cause or will it only be an acknowledgment of the issue being fixed? If only an acknowledgment; may you elaborate here on what had to be addressed? I just have to know :).
  • 40.  RE: Aruba upgrade causes Miracast projection failures
    Posted Apr 11, 2024 11:45 AM
    The Miracast traffic pattern appears to trigger an issue with power save queues. AOS-251742 should be noted in the release notes, but they haven't been created yet so I can't give you a definite answer. Reach out to your account team for information on when.
  • 41.  RE: Aruba upgrade causes Miracast projection failures
    Posted Apr 17, 2024 05:31 AM
    Do you know whether there will be only an update for the version 10. of the firmware or also for the 8. ? As I heard HP wants to continue the support of the version 8. as well. As our school is not not allowed to use version 10. firmware because of its cloud necessity we´re stuck on version 8. and the speed drop while broadcasting via miracast is really annoying.
  • 42.  RE: Aruba upgrade causes Miracast projection failures
    Posted Apr 22, 2024 10:30 AM
    10.5.1.1 (10.5.1.1 Release Notes) was released and I applied it to AP's over the weekend.
    Fingers-crossed, the usual folks I turn to are seeing a marked difference with this firmware applied in the performance of being both connected to Wi-Fi and Wireless screen (Miracast or vCast Receiver to Viewsonic Viewboard(s)) at the same time!
    What is odd, the Bug ID: AOS-251742 is mentioned as fixed in the notes but it's description has no reference to the issue being discussed here.
    AOS-251742 and AOS-252082
    When a user upgraded from ArubaOS 10.4.0.2 to ArubaOS 10.4.0.3, high latency was reported while accessing the stock application on the client connected to AP-515. The issue persisted even after upgrading some sites to ArubaOS 10.5.0.1. The fix ensures that the client operates with no latency.
    I can confirm that we did upgrade our AP-505 (we do not have 515's) that were originally firmware 8.7 (out of box)... to 10.4... and finally to 10.5.0.1 (in the hopes of fixing this issue) to now finally just yesterday 10.5.1.1.
    Also (David) Aruba OS 8 was released as well (8.10.0.11 Release Notes). Maybe there is an answer for you?
    Users experience increased latency in applications with short, bursty traffic patterns when connected to APs. This issue is observed in AP-515 and AP-505 access points running ArubaOS 8.10.0.8 or later versions.
  • 43.  RE: Aruba upgrade causes Miracast projection failures
    Posted Apr 22, 2024 12:28 PM
    Glad to hear 10.5.1.1 seems to address the problems your folks are experiencing. Please keep us updated if something changes.
    The patch for AOS-251742 did not make it into 8.10.0.11 and is still listed as a known issue in the RNs.
  • 44.  RE: Aruba upgrade causes Miracast projection failures
    Posted Apr 23, 2024 10:39 AM
    Thank you for the information. I´m happy to hear that the issue seems to be solved in the 12. firmware. I have one question concerning the 8. firmware though. You have mentioned that  the patch hasn´t made it into 8.10.0.11, is that the version which is being continued? As far as I know, our IT has already installed 8.12. Or is it possible that there will be a 8.13 adressing the Miracast issue?
  • 45.  RE: Aruba upgrade causes Miracast projection failures
    Posted Apr 23, 2024 12:14 PM
    Hi David, for AOS-251742.
    8.10 is still being supported for several more years because 8.10 is a Long Software Release (LSR). The cutoff date to be included in 8.10.0.11 was missed.
    8.12 has the patch in 8.12.0.1 which is not released yet.
    8.13 is roadmap, but yes, would include the patch.
  • 46.  RE: Aruba upgrade causes Miracast projection failures
    Posted 11 days ago
    Had a call from Aruba yesterday about my ticket regarding this.  They have released 8.12.01 on 16th May to fix this issue.
    Rolled it out to one site overnight last night and testing today shows the issue has indeed been fixed.
    Using miracast is now fine!
  • 47.  RE: Aruba upgrade causes Miracast projection failures
    Posted 24 days ago
    We use 40MHz channels (36+ thru 140+) for 500 series AP's. 174 AP's total.  Our district has ScreenBeam 1000 Edu miracast devices in every room. We statically assign 20Mhz channels (153-165) for Miracast devices. We are currently on firmware version 8.10.0.7_87023. This is the last 8.10.x version that does not cause Miracast issues.  There is a latency issue that Aruba has reintroduced more than once in firmware over the years. This is true with all major versions of firmware. There should be a good firmware version for any major release. They are working on a fix.  Spent months going round and round with support.  Got in touch with our certified Aruba installer. They contacted their U.S. based regional Aruba Technical contact.  They confirmed there is a problem and instructed us to downgrade to 8.10.0.7. No more problems. That answer took 1 day. After this district wide issue, we now have a test environment with two AP's. We can test changes and firmware updates.
  • 48.  RE: Aruba upgrade causes Miracast projection failures
    Posted 24 days ago
    Hi Charles.
    Miracast fix is now implemented in 10.5.1.1. It will be available in 8.10.x.x, 8.12.x.x, 10.4.1.x and 10.6.x.x on later date.
    Limited testing on 8.10.0.10 show no problems with Miracast on this version.
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2024
  • 49.  RE: Aruba upgrade causes Miracast projection failures
    Posted 23 days ago
    Hi Gorazd, I assume you're referring to AOS-251742 as the "Miracast fix" implemented in 10.5.1.1. AOS-251742 is not fixed in 8.10.0.10, your limited testing did not hit the conditions for the bug to present itself as it did for others in this discussion.
  • 50.  RE: Aruba upgrade causes Miracast projection failures
    Posted 23 days ago
    Hi Schmeizie.
    Yes I assuming that this is the case. Customer only test it on one AP in lab environment and very limited set. Customer's main goal was to move all APs back to 10.x.x.x version as it was originally and 8.10 version was just temporary workaround.
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2024
  • 51.  RE: Aruba upgrade causes Miracast projection failures
    Posted 19 days ago
    I will iterate. We have already been working with Aruba Support. The issue remains. Aruba will address this in a future release.  8.10.0.7 is the latest release that works and that was recommended by Aruba support.
  • 52.  RE: Aruba upgrade causes Miracast projection failures
    Posted 19 days ago
    Do you use control plane Security Cpsec.
    If so check the allowlist db for what was authorized previously.
  • 53.  RE: Aruba upgrade causes Miracast projection failures
    Posted 19 days ago
    Hi Hutch, please keep on topic. Control plane security is not relevant in this discussion.
  • 54.  RE: Aruba upgrade causes Miracast projection failures
    Posted 23 days ago
    @Charles
    Are you utilizing Miracast broadcast from the ScreenBeam 1000 devices, or connection through the AP infrastructure?  I assume through AP infrastructure.  If so, are you utilizing the Guest network functionality.  I ask because we have had challenges that I outlined here, https://community.arubanetworks.com/discussion/mdns-wifi-display-sharing-device-failures-on-aruba-aps#bm79324814-cb46-4335-b108-ed9265bfc7f7 .  It worked ok on Meraki, but after moving to Aruba, it has not worked well.
  • 55.  RE: Aruba upgrade causes Miracast projection failures
    Posted 9 days ago
    @aiwapro
    We do not use infrastructure with the 1000edu receivers. The network is only used for management of the receivers.  We do not use the Guest network functionality.  We do not use iOS devices. We are mostly Windows 10 and 11 devices.  Just tested 8.10.0.12 firmware. We still have the same issue. Downgraded back to 8.10.0.7.  We do use CMS to manage the receivers. Assuming it is not the Aruba AP firmware version causing a latency issue here are some setting we use on the receivers.
    Features > Wireless display mode to support client devices = Standard Wireless Display (we do not use Commander)
    Features > Wireless Display Over LAN = Disabled everything (not sure if required by iOS devices)
    Features > Miracast Connection = enable
    Network Settings > Local Wi-Fi Network > Select Network Mode = none
    Local Wi-Fi > ScreenBeam Local Wi-Fi = Disable
    We do assign static channels to all AP's and Miracast devices to avoid interference.
  • 56.  RE: Aruba upgrade causes Miracast projection failures
    Posted 9 days ago
    8.10.0.12 ended up being an emergency patch to fix a regression causing a different bug. 8.10.0.13 will have the fix for AOS-251742.
  • 57.  RE: Aruba upgrade causes Miracast projection failures
    Posted 9 days ago
    @schmelzle
    Thank you for the info. Will patiently await 8.10.0.13
