Education - Australia / New Zealand
A local community of education customers across Australia / NZ. This group will be moderated by HPE Aruba Networking staff and kept up to date with any upcoming training or events that are relevant to the EDU space.
ArubaOS8 IPFIX integration with Plixer Scrutinizer
  • 1.  ArubaOS8 IPFIX integration with Plixer Scrutinizer
    Posted Nov 04, 2019 09:41 PM
    Tested Version:
    • Standalone VMC ArubaOS version 8.5.0.3
    • Scrutinizer_VA_18.16
    These two devices are installed in VMWare ESXI within the same subnet. I have one AP and one client connected to my controller to generate client traffic.
    1. Install Scrutinizer as shown in this guide https://docs.plixer.com/projects/scrutinizer/en/latest/deployment_guide/scrutinizer_deployment_guide.html
    then configure system ip address, DNS, NTP, etc.
    2. I have working setup for VMC controller with one AP and one client connected. Configure IPFIX: Configuration>Services>External Services>IPFIX.
    (VMC1) [mynode] #show ip-flow-export-profile
    IP Flow Collector Profile
    Parameter Value
    State Enabled
    Interval (minutes) to upload all active sessions 1
    Interval (minutes) to upload cache snapshot 1
    Interval (minutes) to upload IPFIX template 1
    Transport Protocol for collector connection udp
    IPFIX Collector IP address 192.168.1.25
    Transport Port for collector connection 4739
    Flow Cache size in entries 15000
    Observation Domain 0
    Wireless Export Enabled
    Change the settings here to 1 minute for testing to get the data quickly.
    You can verify collector configuration
    (VMC1) [mynode] #show ip-flow-export collector 192.168.1.25
    Observation Domain: 3232235837 (Controller IP)
    Collector IP 192.168.1.25, protocol udp, port 4739, enabled (wireless-export), connected
    Upload template every 1 minute(s), upload all sessions every 1 minute(s), upload flow cache snapshot every 1 minute(s)
    UNIFLOW, flow cache size 15000, flows exported 4940, next sequence 4940, 413 packets, 190616 bytes
    Last template send: 03:40:38 11-06-2019, last dispatch: 03:40:38 11-06-2019, 71 flows(64 ID-300, 7 ID-301, 0 ID-302)
    0 Connect errors, 0 connection resets, 0 send errors, 0 flows dropped, 0 blocked sends
    3. Wait after one minute and you can see the data in scrutinizer.
