Are you using Dante AV to transfer audio and video? If you are transfering audio as Dante and video as another format (like NDI) I think there is no way to sync those without external software.
You have checked that uplinks to core are not utilized no more that 85% of link speed?
Original Message:
Sent: Mar 12, 2024 12:29 PM
Subject: AVB enabled devices is not working
Hi David, Sure, this is the output of the show ip igmp
We have 6200F switches with the following configuration, but we see.. only audio works fine, only video works fine, but both... don't work, my guess is same as you... maybe its needed the full AVB support with other kind of switches, however if you see anything weird or any advice in the configuration we'd really appreciate.
vlan 1717
ip igmp snooping enable
ip igmp snooping version 2
interface vlan 1717
ip igmp enable
ip igmp querier
Per each port:
no rate-limit broadcast
no rate-limit unknown-unicast
no rate-limit multicast
ip igmp snooping fastleave vlan 1717
no energy-efficient-ethernet
qos trust none
qos dscp 56
S6200-SW# show ip igmp
VRF Name : default
Interface : vlan1717
IGMP Configured Version : 3
IGMP Operating Version : 2
Querier State : Non-Querier
Querier IP : 10.197.140.1
Querier Uptime : 22m 7s
Querier Expiration Time : 2m 54s
IGMP Snoop Enabled on VLAN : True
Active Group Address Vers Mode Uptime Expires
224.0.1.129 2 26m 20s 3m 12s
224.1.2.3 2 7m 21s 0m 59s
224.2.127.254 2 26m 19s 3m 5s
225.1.0.0 2 18h 47m 4m 20s
225.1.0.1 2 18h 47m 4m 20s
226.1.0.0 2 26m 20s 3m 14s
226.2.0.0 2 18h 47m 4m 20s
228.1.0.0 2 26m 20s 3m 13s
234.32.3.47 2 18h 41m 3m 21s
234.32.3.58 2 18h 47m 3m 12s
234.32.3.120 2 18h 44m 3m 5s
234.32.3.128 2 2h 42m 3m 56s
234.32.3.135 2 18h 40m 3m 16s
234.32.4.5 2 18h 41m 3m 30s
234.32.5.37 2 18h 45m 3m 50s
234.32.5.47 2 18h 47m 4m 5s
234.32.128.217 2 18h 39m 3m 26s
234.32.128.242 2 11h 47m 3m 51s
234.32.128.247 2 18h 42m 4m 2s
234.32.129.8 2 18h 46m 3m 53s
234.32.129.30 2 18h 42m 3m 34s
234.32.129.31 2 18h 41m 4m 6s
234.32.129.43 2 10m 57s 2m 56s
234.32.129.51 2 31m 26s 3m 9s
234.32.129.52 2 5m 37s 1m 12s
234.32.129.63 2 2h 42m 3m 55s
234.32.129.97 2 2h 43m 3m 15s
234.32.129.103 2 18h 40m 3m 16s
234.32.129.110 2 18h 44m 1m 36s
234.32.129.141 2 18h 47m 4m 19s
234.32.129.150 2 18h 44m 3m 9s
234.32.129.178 2 18h 46m 3m 52s
234.32.129.204 2 18h 43m 4m 4s
234.32.129.210 2 18h 40m 3m 51s
234.32.192.9 2 36m 7s 3m 59s
234.32.192.30 2 18h 42m 4m 5s
234.32.192.36 2 18h 47m 4m 8s
234.32.192.54 2 18h 42m 3m 30s
234.32.192.78 2 18h 45m 3m 14s
234.32.192.82 2 18h 47m 3m 43s
234.32.192.84 2 9m 32s 3m 28s
234.32.192.87 2 18h 48m 2m 28s
234.32.192.110 2 18h 43m 2m 51s
234.32.192.125 2 18h 47m 3m 21s
234.32.192.128 2 18h 46m 3m 29s
234.48.3.47 2 18h 38m 2m 45s
234.48.3.58 2 18h 43m 2m 36s
234.48.3.120 2 18h 48m 2m 39s
234.48.3.128 2 18h 43m 3m 1s
234.48.3.135 2 18h 44m 2m 40s
234.48.4.5 2 18h 42m 2m 54s
234.48.5.37 2 18h 46m 3m 13s
234.48.5.47 2 18h 43m 2m 30s
234.48.128.217 2 18h 40m 2m 50s
234.48.128.242 2 18h 44m 3m 15s
234.48.128.247 2 18h 47m 3m 26s
234.48.129.8 2 18h 47m 3m 19s
234.48.129.30 2 18h 47m 2m 58s
234.48.129.31 2 6m 18s 3m 30s
234.48.129.43 2 3m 57s 3m 26s
234.48.129.51 2 18h 44m 2m 37s
234.48.129.52 2 12m 15s 1m 28s
234.48.129.63 2 18h 46m 3m 14s
234.48.129.97 2 18h 47m 3m 15s
234.48.129.103 2 18h 44m 2m 40s
234.48.129.110 2 18h 43m 3m 15s
234.48.129.141 2 18h 48m 3m 43s
234.48.129.150 2 18h 45m 2m 6s
234.48.129.164 2 2m 54s 1m 25s
234.48.129.178 2 18h 47m 3m 16s
234.48.129.204 2 18h 43m 3m 28s
234.48.129.210 2 18h 44m 3m 15s
234.48.192.9 2 36m 43s 3m 20s
234.48.192.30 2 18h 42m 3m 29s
234.48.192.36 2 18h 48m 3m 32s
234.48.192.54 2 5m 16s 3m 30s
234.48.192.78 2 18h 45m 3m 13s
234.48.192.82 2 18h 48m 3m 44s
234.48.192.84 2 18h 47m 3m 29s
234.48.192.87 2 18h 48m 2m 33s
234.48.192.110 2 18h 43m 2m 51s
234.48.192.125 2 18h 43m 2m 30s
234.48.192.128 2 18h 46m 3m 29s
234.64.3.47 2 18h 44m 1m 50s
234.64.3.58 2 18h 42m 2m 53s
234.64.3.120 2 18h 42m 2m 54s
234.64.3.128 2 18h 43m 2m 34s
234.64.3.135 2 18h 47m 2m 56s
234.64.4.5 2 18h 47m 2m 52s
234.64.5.37 2 18h 43m 2m 57s
234.64.5.47 2 10m 8s 2m 25s
234.64.128.217 2 18h 43m 3m 0s
234.64.128.242 2 18h 44m 3m 15s
234.64.128.247 2 18h 47m 3m 26s
234.64.129.8 2 18h 47m 1m 48s
234.64.129.30 2 18h 47m 2m 58s
234.64.129.31 2 5m 16s 3m 30s
234.64.129.43 2 1m 50s 3m 27s
234.64.129.51 2 18h 44m 1m 48s
234.64.129.63 2 10m 12s 2m 34s
234.64.129.97 2 18h 40m 2m 59s
234.64.129.103 2 18h 41m 2m 40s
234.64.129.110 2 18h 44m 2m 33s
234.64.129.141 2 18h 48m 3m 43s
234.64.129.150 2 18h 45m 2m 6s
234.64.129.178 2 18h 47m 3m 16s
234.64.129.204 2 18h 43m 3m 28s
234.64.129.210 2 18h 44m 3m 15s
234.64.192.9 2 36m 38s 3m 40s
234.64.192.30 2 18h 44m 3m 30s
234.64.192.36 2 18h 48m 3m 32s
234.64.192.54 2 6m 1s 3m 30s
234.64.192.78 2 18h 47m 3m 14s
234.64.192.82 2 2h 29m 3m 24s
234.64.192.84 2 18h 41m 1m 44s
234.64.192.87 2 18h 48m 2m 28s
234.64.192.110 2 18h 44m 2m 25s
234.64.192.125 2 18h 48m 2m 36s
234.64.192.128 2 18h 46m 3m 29s
234.96.3.47 2 18h 44m 2m 26s
234.96.3.58 2 52m 48s 2m 53s
234.96.3.120 2 18h 42m 2m 54s
234.96.3.128 2 18h 43m 1m 50s
234.96.3.135 2 18h 47m 2m 56s
234.96.4.5 2 18h 47m 2m 52s
234.96.5.37 2 18h 43m 2m 57s
234.96.5.47 2 12m 11s 2m 34s
234.96.128.217 2 18h 43m 3m 0s
234.96.128.242 2 18h 44m 3m 15s
234.96.128.247 2 18h 42m 3m 26s
234.96.129.8 2 18h 47m 1m 48s
234.96.129.30 2 18h 43m 2m 58s
234.96.129.31 2 6m 2s 3m 30s
234.96.129.51 2 18h 44m 1m 48s
234.96.129.63 2 18h 47m 2m 52s
234.96.129.97 2 18h 43m 2m 55s
234.96.129.103 2 18h 41m 2m 40s
234.96.129.110 2 18h 44m 2m 31s
234.96.129.141 2 18h 48m 3m 43s
234.96.129.150 2 18h 45m 2m 11s
234.96.129.164 2 5m 5s 2m 30s
234.96.129.178 2 18h 47m 3m 16s
234.96.129.204 2 18h 43m 2m 29s
234.96.129.210 2 18h 44m 3m 15s
234.96.192.9 2 36m 47s 3m 40s
234.96.192.30 2 18h 44m 3m 30s
234.96.192.36 2 18h 48m 3m 32s
234.96.192.54 2 18h 43m 3m 26s
234.96.192.78 2 18h 45m 3m 14s
234.96.192.82 2 2h 39m 3m 24s
234.96.192.84 2 18h 46m 1m 44s
234.96.192.87 2 18h 48m 2m 28s
234.96.192.110 2 18h 44m 2m 31s
234.96.192.125 2 26m 47s 2m 36s
234.96.192.128 2 18h 48m 3m 33s
234.112.3.47 2 18h 44m 2m 29s
234.112.3.58 2 18h 42m 2m 53s
234.112.3.120 2 18h 42m 2m 54s
234.112.3.128 2 18h 47m 2m 28s
234.112.3.135 2 18h 47m 2m 56s
234.112.4.5 2 18h 47m 2m 52s
234.112.5.37 2 18h 43m 2m 57s
234.112.5.47 2 12m 10s 1m 56s
234.112.128.217 2 18h 43m 3m 0s
234.112.128.242 2 18h 44m 3m 15s
234.112.128.247 2 18h 42m 3m 26s
234.112.129.8 2 18h 47m 2m 36s
234.112.129.30 2 18h 43m 2m 58s
234.112.129.31 2 18h 44m 3m 30s
234.112.129.51 2 18h 44m 1m 48s
234.112.129.52 2 3m 57s 3m 34s
234.112.129.63 2 18h 41m 2m 52s
234.112.129.97 2 18h 40m 2m 59s
234.112.129.103 2 18h 44m 2m 40s
234.112.129.110 2 18h 44m 2m 37s
234.112.129.141 2 18h 48m 3m 43s
234.112.129.150 2 18h 45m 2m 6s
234.112.129.164 2 48m 52s 2m 31s
234.112.129.178 2 18h 47m 3m 16s
234.112.129.204 2 18h 43m 3m 28s
234.112.129.210 2 18h 40m 3m 15s
234.112.192.9 2 36m 43s 3m 40s
234.112.192.30 2 18h 44m 3m 30s
234.112.192.36 2 18h 48m 3m 32s
234.112.192.54 2 5m 16s 3m 30s
234.112.192.78 2 18h 47m 3m 14s
234.112.192.82 2 18h 44m 3m 24s
234.112.192.84 2 18h 46m 2m 30s
234.112.192.87 2 18h 48m 2m 27s
234.112.192.110 2 18h 44m 2m 25s
234.112.192.125 2 26m 48s 2m 35s
234.112.192.128 2 18h 46m 3m 28s
234.200.200.1 2 26m 57s 2m 36s
239.255.254.253 2 26m 57s 2m 33s
239.255.255.250 2 18h 48m 3m 43s
239.255.255.255 2 26m 57s 2m 36s
Original Message:
Sent: Mar 12, 2024 08:19 AM
There's not a lot to it other than was I posted previously. Do you have IGMP enabled like I recommended? Could you post the output of show ip igmp
from every switch the traffic traverses? When you say "it doesn't work" what do you mean? Does the stream not reach its destination at all? Does it get there but audio and video are out of sync? Is it jittery or distorted?
I've not done any video in this setup but I know it's been discussed. My guess is that to make video and audio work reliably you'll need full AVB support (or, at a minumum, PTP). That will likely require a 6300 running 10.13 or newer firmware but that's just a guess.
Original Message:
Sent: Mar 11, 2024 03:59 PM
Hi davidwk could you give us any advice about this topic? maybe to show us the right setup about igmp and any other advice for Dante audio? We have an issue with audio... when they send video and audio simultaneously, it doesnt work.
thank you so much
Original Message:
Sent: Jan 03, 2023 08:18 AM
We run Dante audio over 6200 and 6300 switches all the time without any issues. The biggest thing to keep in mind is that you need to make sure IGMP is setup and working correctly. I've not worked with PTP at all. I know Dante supports it but doesn't require it.
Original Message:
Sent: Jan 03, 2023 05:49 AM
One good resource to know what is supported or not is the feature navigator:
https://feature-navigator.arubanetworks.com/
Original Message:
Sent: Jan 03, 2023 04:06 AM
And, what about Dante ? [Dante (networking) - Wikipedia]
Original Message:
Sent: Jan 02, 2023 06:22 PM
Isn't everything possible?
Steinar
Original Message:
Sent: Jan 02, 2023 06:17 PM
I doubt if AVB is supported on 6300s.
Original Message:
Sent: Jan 02, 2023 06:06 PM
Aruba 6300M AOS-CX 10.11
[Audio Video Bridging - Wikipedia]
AVB devices report "Switch port is not 802.1AS capable».
Please advise on how to enable.
Steinar
