Aruba Airwave
Building and floor occupancy count / utilization help
This thread has been viewed 23 times
  • 1.  Building and floor occupancy count / utilization help
    Posted Nov 27, 2023 03:19 PM
    Hello & thank you in advance for any help!
    I work in the Corporate Real Estate department of a large company, and I was hoping someone could !
  • 2.  RE: Building and floor occupancy count / utilization help
    Posted Dec 05, 2023 11:17 AM
    That may be not as easy as it sounds. It starts by finding a proper way to find which devices belong to which users to de-duplicate the dataset.
    You may get a (detailed) report with all sessions and extract the required data from there. If you know how to do that manually, next step can be how to automate either in Airwave or external tooling. If you can find an adequate devices per user number, you may also calculate an average number of users from the total number of devices. Unless you need a very accurate number, for most applications that may be more than accurate enough.
