We can run cli command to a switch to detect cable faults. If the switch is cloud managed in Aruba Central we can use the GUI to test the cable.
Test Details:
- Aruba Central - AUTO-ATH-2.4.9-687-P
- 2930F switch
- AP-515
My AP is connected to port 4 of 2930F with 4 meters cable. I will check if I have cable faults using Aruba Central.
1. Under Maintenance > Tools > Device Check . Run "Cable Test" to a selected switch.
![cabletest1.JPG cabletest1.JPG](https://higherlogicdownload.s3.amazonaws.com/HPE/MigratedInlineFiles/835609d793414c3e91b72b3739eff47e_9d69eb5a2f394b66bc1544cca34f63cb)
2. Refresh the page to see the test results.
![cabletest3.JPG cabletest3.JPG](https://higherlogicdownload.s3.amazonaws.com/HPE/MigratedInlineFiles/835609d793414c3e91b72b3739eff47e_371a0ee6a2104f378b2ca470b9bbca10)
3. Or you can laso check the cable test result by issuing show cable-diagnostics. Maintenance > Tools > Adanced.
![cabletest2JPG.JPG cabletest2JPG.JPG](https://higherlogicdownload.s3.amazonaws.com/HPE/MigratedInlineFiles/835609d793414c3e91b72b3739eff47e_6b4e6143f53c464c9594c0692771ce77)
Based on the test result my cable is good and also it confirmed that it is 4 meters long. Very useful command to test layer 1.
