Hello
I bought a pair of IAP-315 off eBay (from the Aruba refurb store) a few years back. around that time we did an Aruba refresh at couple locations at work. (form IAP225 to IAP315)
My boss signed off on about 12 of those device to go to us :), I got two of them.
however I am just getting into looking at them at home a year + later.
plugged it in an the IAP-215 upgraded to 8.6.0.18
my IAP-315 are the 8.9.0.2 (it auto upgraded to this)
is it not possible for them to Cluster?
Is it possible for them to MESH ? I would really like the 225 to cover some low signal area in my house without running new cables.
I assume the version mismatch is the issue
Jul 24 14:29:13 mini_httpd[7205]: handle_request, 3411: Try to check post auth user 192.168.1.103, dst 172.31.98.1
Jul 24 14:29:13 syslog: main, 3437: opcode is show
Jul 24 14:29:13 mini_httpd[7208]: handle_request: 3150: SSL_accept fail, child exit after 0 requests error:00000001:lib(0):func(0):reason(1)
Jul 24 14:29:13 mini_httpd[7209]: handle_request, 3392: 192.168.1.103, 61928, size 592
Jul 24 14:29:13 mini_httpd[7209]: handle_request, 3411: Try to check post auth user 192.168.1.103, dst 172.31.98.1
Jul 24 14:29:14 cli[6098]: <341097> <WARN> |AP OFFICE:db:f8@192.168.101.101 cli| recv_image_check: mac-84:d4:7e:xxxx, version-8.6.0.18-8.6.0.18_84257, ccode_idx-0.
Jul 24 14:29:14 cli[6098]: save_sn2file: this member have been involved, pass
Jul 24 14:29:14 cli[6098]: <341004> <WARN> |AP OFFICE:db:f8@192.168.101.101 cli| ccode_index_to_ccode_array_idx_vc, return i = 0
Jul 24 14:29:14 cli[6098]: <341004> <WARN> |AP OFFICE:db:f8@192.168.101.101 cli| is_reg_domain_match my_arr_idx = 0, other_arr_idx= 0
Jul 24 14:29:14 cli[6098]: <341052> <ERRS> |AP OFFICE:db:f8@192.168.101.101 cli| recv_image_check, 2977: AP class not match, Conductor-40, Member-25.
Jul 24 14:29:14 cli[6098]: find_class_seed_ap:class is 40
Jul 24 14:29:14 cli[6098]: do not find the same class from ap list 25
Jul 24 14:29:14 cli[6098]: <341004> <WARN> |AP OFFICE:db:f8@192.168.101.101 cli| Image_sync_via_isc
Jul 24 14:29:14 cli[6098]: initiate_image_mismatch:could not find the url from cache, send the url request to activate.
Jul 24 14:29:14 cli[6098]: <341004> <WARN> |AP OFFICE:db:f8@192.168.101.101 cli| isc_image_url_request: Centaurus,8.9.0.2-8.9.0.2_83074
Jul 24 14:29:14 awc[6095]: [activate] receive isc request
Jul 24 14:29:14 awc[6095]: [activate] tcp_connect: begin resolve 'device.arubanetworks.com'
Jul 24 14:29:14 awc[6095]: [activate] tcp_connect: 251: recv timeout set to 5
Jul 24 14:29:14 awc[6095]: [activate] tcp_connect: 258: send timeout set to 5
Jul 24 14:29:14 awc[6095]: [activate] awc_init_connection: 2970: connected to device.arubanetworks.com:443
Jul 24 14:29:14 awc[6095]: [activate] awc_init_connection: 3033: cert verify: enable, domainame verify: enable
Jul 24 14:29:14 awc[6095]: [activate] awc_init_connection: 3062: Loading local CA certificates
Jul 24 14:29:14 awc[6095]: [activate] verify_callback: 2821: preverify_ok:1, chain count:4.
if that is the case can this ever work? do they have repeater mode?
