Captive Portal in AOS8.9 without ClearPass and AirWave
  • 1.  Captive Portal in AOS8.9 without ClearPass and AirWave
    Posted Jul 07, 2022 11:14 AM
    I have a controller with APs and I want to create WiFi for guests with Captive Portal. I don't have the pucharsed ClearPass and AirWave.
    I need a "Login", "Password" and "Terms and Conditions" screen when guest trying to connect to WiFi. Each visitor will have an individual "Login" and "Password" generated for authentication with a RADIUS server.
    We have MM/MCs running AOS 8.9.0.3 FIPS
    Is it possible?
  • 2.  RE: Captive Portal in AOS8.9 without ClearPass and AirWave
    Posted Jul 07, 2022 06:41 PM
    Yes.
  • 3.  RE: Captive Portal in AOS8.9 without ClearPass and AirWave
    Posted Jul 07, 2022 06:45 PM
    and here is the how to do it.
    https://www.arubanetworks.com/techdocs/ArubaOS_8.8.0_Web_Help/Content/arubaos-solutions/captive-portal/samp-auth-capt-port.htm
